Deihmos 170 Posted June 28, 2015 Posted June 28, 2015 I had unhandled exceptions when i installed emby tv also. Solution was to delete it.
Luke 42243 Posted June 29, 2015 Posted June 29, 2015 I've pushed an update to EmbyTV to address your issue.
ejrodn1290 5 Posted June 29, 2015 Posted June 29, 2015 Yes, after updating or pasting my support key I was able to change settings in my plugins but it has stop and the cinema mode actually worked at one time. server-63570959768.txt Hey Luke!! Have you figure out my server snapshot yet,because my plugins and cinema mode is still not working. Also my studio cleaner plugin want uninstall (it pops backup after I uninstall it from my list) http://ts1.mm.bing.net/th?&id=JN.hunNoxVQTNCP%2byBD0OcGAg&w=300&h=300&c=0&pid=1.9&rs=0&p=0&r=0
Luke 42243 Posted June 29, 2015 Posted June 29, 2015 Hey Luke!! Have you figure out my server snapshot yet,because my plugins and cinema mode is still not working. Also my studio cleaner plugin want uninstall (it pops backup after I uninstall it from my list) http://ts1.mm.bing.net/th?&id=JN.hunNoxVQTNCP%2byBD0OcGAg&w=300&h=300&c=0&pid=1.9&rs=0&p=0&r=0 well now that you've removed the plugin let's start over and look from the beginning. please open a new topic and describe the problem, and attach relevant logs. thanks.
ejrodn1290 5 Posted June 29, 2015 Posted June 29, 2015 well now that you've removed the plugin let's start over and look from the beginning. please open a new topic and describe the problem, and attach relevant logs. thanks. My studio cleaner plugin want uninstall (it pops backup after I uninstall it from my list). Everything else uninstalls except for this plugin and when double tap the any plugin it gives me a alert (To configure this plugin please sign in to your local server directly) maybe this can be some help.
Happy2Play 9812 Posted June 29, 2015 Posted June 29, 2015 If you shut down the server, you can manually delete the plugin from %appdata%/mediabrowser-server (or) emby-server/plugins. Then start server again. 2
ejrodn1290 5 Posted June 30, 2015 Posted June 30, 2015 If you shut down the server, you can manually delete the plugin from %appdata%/mediabrowser-server (or) emby-server/plugins. Then start server again. Thanks Happy2Play!!
