Ryan81094 3 Posted April 20, 2025 Posted April 20, 2025 all i did was add a backdrop for pokerface in my library and now its just replaced what was originally on the homescreen. im soooo confused why is it always so complicated.
Ryan81094 3 Posted April 20, 2025 Author Posted April 20, 2025 4 years later has this issue been fixed? I love how the detailed screen is on my tv, but want to be able to atleast choose the backdrop. or atleast keep the original library image. and anytime i add something it just changes it and looks messy. how are things that could be so simple made so complicated. i may have to go back to plex
Luke 42176 Posted April 21, 2025 Posted April 21, 2025 Ho, where exactly did you put the backdrop image?
Ryan81094 3 Posted April 21, 2025 Author Posted April 21, 2025 went into the fame library, right clicked on the pokerface video, edit images and added a backdrop for that as i will be for each video, but but for some reason its removed the original backdrop (top screenshot) which is the correct one, it just doesnt look like it makes sense. I assumed that the fact i can edit the images on the homepage thumbnail that they would still show.
Luke 42176 Posted April 21, 2025 Posted April 21, 2025 1 hour ago, Ryan81094 said: went into the fame library, right clicked on the pokerface video, edit images and added a backdrop for that as i will be for each video, but but for some reason its removed the original backdrop (top screenshot) which is the correct one, it just doesnt look like it makes sense. I assumed that the fact i can edit the images on the homepage thumbnail that they would still show. You must have clicked the button on the existing image. That is a function to replace the current one. There are other buttons outside of that to add a new one without replacing.
Ryan81094 3 Posted April 22, 2025 Author Posted April 22, 2025 I see, could you tell me where those buttons are please?
Luke 42176 Posted April 22, 2025 Posted April 22, 2025 6 hours ago, Ryan81094 said: I see, could you tell me where those buttons are please? Above the backdrops list there is a search and a plus icon.
Ryan81094 3 Posted April 22, 2025 Author Posted April 22, 2025 im still confused. thats how ive been changing it already.
Ryan81094 3 Posted April 22, 2025 Author Posted April 22, 2025 no matter how many times i upload a backdrop for the fame library it keep generating its own backdrops from within the library which i do not want.
Luke 42176 Posted April 22, 2025 Posted April 22, 2025 It’s not replacing your backdrop. What’s happening is when the library is selected it is displaying a random item from that library and using the backdrop from that. So that’s also why you see the poker face logo and description. there are currently no settings to prevent the display of the random item although it is likely that some will be added in the future.
Ryan81094 3 Posted April 22, 2025 Author Posted April 22, 2025 I see, realistically how likely is this able to be implemented, is it easy to add this option from your end?
Ryan81094 3 Posted April 22, 2025 Author Posted April 22, 2025 thats great to hear, are you able to possibly indicate when? as im considering switching to another server as I really would like a consistent and clean interface and it would be a shame to leave to due this one thing missing.
Luke 42176 Posted April 25, 2025 Posted April 25, 2025 I don't have an ETA, but it has come up a fair amount, particularly with the android crowd. Maybe if we had a feature request @CBers
