Dreffi 0 Posted April 19, 2025 Posted April 19, 2025 Hi, I'm new to Emby and just set up my server. Yesterday I added my VU receiver: I am able to watch these streams. I also added the EPG from the VU receiver, but was missing info for some channels. So I added xmlcv.info as a source and mapped the channels manually to the guide. Almost everything worked so far. Unfortunately there were data for some channels missing. So I deleted and added the TV source and the guide again. Now I am unable to map the channels to the guide: I can choose the guide but can't choose any channel. The list just doesn't open. What can I do? I restarted the server several times. I think there is some data in the background that needs to be cleaned. Any suggestions? Help me please.
Luke 42241 Posted April 19, 2025 Posted April 19, 2025 Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
Solution Luke 42241 Posted April 22, 2025 Solution Posted April 22, 2025 Your xml guide provider is sending back this error response: 2025-04-19 06:46:50.190 Info HttpClient: GET https://xmltv.info/x_path2_x/x_path3_x 2025-04-19 06:46:50.424 Error LiveTvManager: Error getting channels *** Error Report *** Version: 4.8.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 4.4.302+ (root@build5) (gcc version 12.2.0 (GCC) ) #72806 SMP Thu Sep 5 13:44:44 CST 2024 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: TooManyRequests Have you been hitting them hard lately?
Dreffi 0 Posted April 22, 2025 Author Posted April 22, 2025 (edited) This is possible because I refreshed the guide several times because some channels had no data. I set up a new Emby server from scratch. The channel mapping worked but some channels still had no data. These existed in the xml but with no content. After about one day this problem was solved without further action. At the moment everything is working as expected. Thanks anyway. Edited April 22, 2025 by Dreffi
