Betonhaus 18 Posted April 19, 2025 Posted April 19, 2025 Quote emby: image: emby/embyserver container_name: embyserver # runtime: nvidia # Expose NVIDIA GPUs network_mode: host # Enable DLNA and Wake-on-Lan environment: - UID=1000 - GID=1002 - GIDLIST=993 volumes: - /mnt/docker/emby:/config - /mnt/pool/media:/mnt/media devices: - /dev/dri/renderD128:/dev/dri/renderD128 restart: unless-stopped tmpfs: - /transcoding:size=16G I was wondering if there is a way to set up a ramdisk that can be used for transcoding, and if it can speed up transcoding significantly. I have a lot of memory on my server that's sitting unused, would something like this work?
GrimReaper 4897 Posted April 19, 2025 Posted April 19, 2025 2 minutes ago, Betonhaus said: I was wondering if there is a way to set up a ramdisk that can be used for transcoding, and if it can speed up transcoding significantly Generally not recommended: But if you're really keen on it:
Betonhaus 18 Posted April 19, 2025 Author Posted April 19, 2025 Ok, if I have an Intel Arc A310 what's the best way to minimise the time spent transcoding? I had like 10 seconds of loading time when i was trying to get the server to render and burn in subtitles.
