myoldvcr 21 Posted April 20, 2025 Posted April 20, 2025 My Emby Linux server recording directories are drwxrwsrwx+ emby:video So, the user is "emby" and the group is "video". The user "emby" is a member of the "video" and "remder" groups. The "+" at the end is an ACL to give write access to the "video" group and the "s" is a sticky bit flag for the folder to prevent anyone but the owner to delete it, I think. If you want to see what your permissions are for your recording folder you can use this command. getfacl folder-path I give full permissions to everyone so I can access my shared folders from a Windows PC on the network.
Q-Droid 1011 Posted April 20, 2025 Posted April 20, 2025 11 hours ago, Lessaj said: I'm not really familiar with the "rws" that is showing up in your permissions and I think that's very strange. I've read a little bit about it and it doesn't seem necessary here, I'm wondering if it's the cause of your permission issues. The setgid bit (s) forces group ownership inheritance for files and dirs created under that directory. They will have consistent ownership at the group level but it doesn't affect permissions. For permissions the umask still applies and ACLs when defined. 1
sftech13 25 Posted April 24, 2025 Author Posted April 24, 2025 I’m still confused on this issue, maybe its not a issue. All permissions appear to be set correctly, yet I’m still getting permission denied errors. As a workaround, I’ve set up a cron job to run twice a day to reapply the correct permissions across directories. The strange part is that the cron logs show no changes needed everything looks fine. However, I continue to see "permission denied" errors after 11PM (after the cron has already run) but after 2AM. By the time the cron runs again at 2AM, the issue seems to resolve itself without any permission changes being logged. I’m not sure what’s causing this or why it temporarily fails even though permissions haven’t changed. Logs of script: [2025-04-23 23:00:01] Starting permission check on /mnt/Media /mnt/Misc [INFO] Processing: /mnt/Media/Movies [INFO] Checking metadata file permissions in: /mnt/Media/Movies [INFO] Processing: /mnt/Media/TV Shows [INFO] Checking metadata file permissions in: /mnt/Media/TV Shows [INFO] Processing: /mnt/Misc/Animation [INFO] Checking metadata file permissions in: /mnt/Misc/Animation [INFO] Processing: /mnt/Misc/CinemaSounds [INFO] Checking metadata file permissions in: /mnt/Misc/CinemaSounds [INFO] Processing: /mnt/Misc/Documentary [INFO] Checking metadata file permissions in: /mnt/Misc/Documentary [INFO] Processing: /mnt/Misc/Kodi [INFO] Checking metadata file permissions in: /mnt/Misc/Kodi [INFO] Processing: /mnt/Misc/Recordings [INFO] Checking metadata file permissions in: /mnt/Misc/Recordings [INFO] Processing: /mnt/Misc/Replays [INFO] Checking metadata file permissions in: /mnt/Misc/Replays [INFO] Processing: /mnt/Misc/repo [INFO] Checking metadata file permissions in: /mnt/Misc/repo [INFO] Processing: /mnt/Misc/Software [INFO] Checking metadata file permissions in: /mnt/Misc/Software [INFO] Processing: /mnt/Misc/StandUp [INFO] Checking metadata file permissions in: /mnt/Misc/StandUp [OK] All .nfo and clearlogo.png files are group writable. [2025-04-24 02:00:01] Starting permission check on /mnt/Media /mnt/Misc [INFO] Processing: /mnt/Media/Movies [INFO] Checking metadata file permissions in: /mnt/Media/Movies [INFO] Processing: /mnt/Media/TV Shows [INFO] Checking metadata file permissions in: /mnt/Media/TV Shows [INFO] Processing: /mnt/Misc/Animation [INFO] Checking metadata file permissions in: /mnt/Misc/Animation [INFO] Processing: /mnt/Misc/CinemaSounds [INFO] Checking metadata file permissions in: /mnt/Misc/CinemaSounds [INFO] Processing: /mnt/Misc/Documentary [INFO] Checking metadata file permissions in: /mnt/Misc/Documentary [INFO] Processing: /mnt/Misc/Kodi [INFO] Checking metadata file permissions in: /mnt/Misc/Kodi [INFO] Processing: /mnt/Misc/Recordings [INFO] Checking metadata file permissions in: /mnt/Misc/Recordings [INFO] Processing: /mnt/Misc/Replays [INFO] Checking metadata file permissions in: /mnt/Misc/Replays [INFO] Processing: /mnt/Misc/repo [INFO] Checking metadata file permissions in: /mnt/Misc/repo [INFO] Processing: /mnt/Misc/Software [INFO] Checking metadata file permissions in: /mnt/Misc/Software [INFO] Processing: /mnt/Misc/StandUp [INFO] Checking metadata file permissions in: /mnt/Misc/StandUp [OK] All .nfo and clearlogo.png files are group writable. EMBY Log snippet: 2025-04-23 11:23:34.109 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.8.11.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-214-generic (buildd@lcy02-amd64-062) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)) #234-Ubuntu SMP Fri Mar 14 23:50:27 UTC 2 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/media/Movies/iHostage (2025)/iHostage (2025) {imdb-tt31181421} [NF][WEBDL-2160p][HDR10][EAC3 Atmos 5.1][h265]-MWeb.nfo' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Interop.CheckIo(Error error, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize) at System.IO.FileStream..ctor(String path, FileStreamOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions, Int64 preAllocationSize) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Boolean isAsync) at NfoMetadata.Savers.BaseNfoSaver.SaveToFile(Stream stream, String path, LibraryOptions libraryOptions, CancellationToken cancellationToken) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.SaveMetadata(BaseItem item, LibraryOptions libraryOptions, ItemUpdateType updateType, IMetadataSaver[] savers, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2025-04-23 11:23:35.830 Error ProviderManager: Error in metadata saver *** Error Report *** Version: 4.8.11.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-214-generic (buildd@lcy02-amd64-062) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)) #234-Ubuntu SMP Fri Mar 14 23:50:27 UTC 2 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/media/Movies/Ash (2025)/Ash (2025) {imdb-tt17489650} [AMZN][WEBDL-1080p][EAC3 5.1][h264]-BYNDR.nfo' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Interop.CheckIo(Error error, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String fullPath, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.OSFileStreamStrategy..ctor(String path, FileMode mode, FileAccess access, FileShare share, FileOptions options, Int64 preallocationSize) at System.IO.Strategies.FileStreamHelpers.ChooseStrategy(FileStream fileStream, String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, Int64 preallocationSize) at System.IO.FileStream..ctor(String path, FileStreamOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Int32 bufferSize, FileOpenOptions fileOpenOptions, Int64 preAllocationSize) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileStream(String path, FileOpenMode mode, FileAccessMode access, FileShareMode share, Boolean isAsync) at NfoMetadata.Savers.BaseNfoSaver.SaveToFile(Stream stream, String path, LibraryOptions libraryOptions, CancellationToken cancellationToken) at NfoMetadata.Savers.BaseNfoSaver.Save(BaseItem item, LibraryOptions libraryOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.ProviderManager.SaveMetadata(BaseItem item, LibraryOptions libraryOptions, ItemUpdateType updateType, IMetadataSaver[] savers, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void ThrowExceptionForIoErrno(ErrorInfo, System.String, Boolean, System.Func`2[Interop+ErrorInfo,Interop+ErrorInfo]) InnerException: System.IO.IOException: Permission denied Source: TargetSite: Script: #!/bin/bash # --- CONFIG --- BASE_DIRS=("/mnt/Media" "/mnt/Misc") LOG_FILE="/home/sftech13/logs/fix_emby_permissions.log" TIMESTAMP=$(date +"%Y-%m-%d %H:%M:%S") # --- LOG HEADER --- echo -e "\n[${TIMESTAMP}] Starting permission check on ${BASE_DIRS[*]}" >> "$LOG_FILE" for BASE_DIR in "${BASE_DIRS[@]}"; do if [ ! -d "$BASE_DIR" ]; then echo "[ERROR] Base directory does not exist: $BASE_DIR" >> "$LOG_FILE" continue fi # Loop through each top-level subdirectory for DIR in "$BASE_DIR"/*; do if [ -d "$DIR" ]; then echo "[INFO] Processing: $DIR" >> "$LOG_FILE" chown -R emby:emby "$DIR" chmod -R ug+rw "$DIR" find "$DIR" -type d -exec chmod g+s {} \; echo "[INFO] Checking metadata file permissions in: $DIR" >> "$LOG_FILE" find "$DIR" \( -iname "*.nfo" -o -iname "clearlogo.png" \) ! -perm -g=w -print >> "$LOG_FILE" fi done done FOUND=$(find "${BASE_DIRS[@]}" \( -iname "*.nfo" -o -iname "clearlogo.png" \) ! -perm -g=w | wc -l) if [ "$FOUND" -gt 0 ]; then echo "[WARN] $FOUND metadata files without group write permission found." >> "$LOG_FILE" else echo "[OK] All .nfo and clearlogo.png files are group writable." >> "$LOG_FILE" fi
sftech13 25 Posted April 24, 2025 Author Posted April 24, 2025 I might have the issue will check again later. ACL's Permissions and ACLs were out of alignment directories were owned by sftech13:emby, but /mnt/Misc didnt have group write access, possibly causing Emby to throw permission errors. I adjusted them and will see what happens later. sftech13@sftech13:~$ getfacl /mnt/Media getfacl: Removing leading '/' from absolute path names # file: mnt/Media # owner: sftech13 # group: emby # flags: -s- user::rwx group::rwx other::r-x sftech13@sftech13:~$ getfacl /mnt/Misc getfacl: Removing leading '/' from absolute path names # file: mnt/Misc # owner: sftech13 # group: sftech13 # flags: -s- user::rwx group::r-x other::r-x After changing them: sftech13@sftech13:~$ getfacl /mnt/Media getfacl: Removing leading '/' from absolute path names # file: mnt/Media # owner: sftech13 # group: emby # flags: -s- user::rwx group::rwx other::r-x sftech13@sftech13:~$ getfacl /mnt/Misc getfacl: Removing leading '/' from absolute path names # file: mnt/Misc # owner: sftech13 # group: emby # flags: -s- user::rwx group::rwx other::r-x
Q-Droid 1011 Posted April 24, 2025 Posted April 24, 2025 You said before that your filesystems are ext4. Does that include the one mounted at /mnt/Media, also ext4? Could you try creating a new temporary library under /mnt/Media, something like /mnt/Media/Test and use that path in Emby? Don't follow the sym link route of /media/Test like you did with /media/Movies. Then throw a couple of movies in there to see what happens.
TMCsw 259 Posted April 24, 2025 Posted April 24, 2025 @sftech13You mention using 'Swizzin' (the seedbox I presume?) you should probable look into how this creates dirs/files... There seems to be a logic error in your .sh file??? 7 hours ago, sftech13 said: # Loop through each top-level subdirectory for DIR in "$BASE_DIR"/*; do if [ -d "$DIR" ]; then echo "[INFO] Processing: $DIR" >> "$LOG_FILE" chown -R emby:emby "$DIR" chmod -R ug+rw "$DIR" find "$DIR" -type d -exec chmod g+s {} \; echo "[INFO] Checking metadata file permissions in: $DIR" >> "$LOG_FILE" find "$DIR" \( -iname "*.nfo" -o -iname "clearlogo.png" \) ! -perm -g=w -print >> "$LOG_FILE" fi done done it seems you are looking for permissions that are wrong after you have corrected them??? I would recommend making it a little bit simpler like the following too better understand what files are the problem and who or what creased them... find /mnt/media -type f -exec chown -v emby:emby {} \;|grep changed >> $LOG_FILE find /mnt/media -type d -exec chmod -v 775 {} \;|grep changed >> $LOG_FILE ... ... Also as @Q-Droidmentions what and how you are mounting these? (DETAILS please)...
sftech13 25 Posted April 25, 2025 Author Posted April 25, 2025 2 hours ago, Q-Droid said: You said before that your filesystems are ext4. Does that include the one mounted at /mnt/Media, also ext4? Could you try creating a new temporary library under /mnt/Media, something like /mnt/Media/Test and use that path in Emby? Don't follow the sym link route of /media/Test like you did with /media/Movies. Then throw a couple of movies in there to see what happens. Thank you for the response. they are both ext4. I will try your suggestion this weekend. sftech13@sftech13:~$ df -T /mnt/Media /mnt/Misc Filesystem Type 1K-blocks Used Available Use% Mounted on /dev/md0 ext4 35015431952 31548360916 1709235056 95% /mnt/Media /dev/sde1 ext4 5813177436 4302960980 1217173996 78% /mnt/Misc
sftech13 25 Posted April 25, 2025 Author Posted April 25, 2025 1 hour ago, TMCsw said: @sftech13You mention using 'Swizzin' (the seedbox I presume?) you should probable look into how this creates dirs/files... There seems to be a logic error in your .sh file??? it seems you are looking for permissions that are wrong after you have corrected them??? I would recommend making it a little bit simpler like the following too better understand what files are the problem and who or what creased them... find /mnt/media -type f -exec chown -v emby:emby {} \;|grep changed >> $LOG_FILE find /mnt/media -type d -exec chmod -v 775 {} \;|grep changed >> $LOG_FILE ... ... Also as @Q-Droidmentions what and how you are mounting these? (DETAILS please)... LOL good catch... thanks you I adjusted the script and tested it.
