JanS48 2 Posted April 11, 2025 Posted April 11, 2025 Greetings everyone - emby - home layout: I've managed to make things much worse than they were. I was setting up a new Firestick 4K Max today and installed the Emby android client - that part was good. I was still just seeing Favorites under channels - I modified the order of the Home Screen Layout but little did I know that those changes were being written back to the server affecting all my emby clients. I didn't write down the original order of the contents of the Home Screen Layout and what I have now makes the system nearly un-usable. Nothing seems to lay-out the way I'd expect it to. It's now a HUGE chore just to get to Channels. Anyway, could someone take a moment and give me the original layout (order) - at this point I'd just like to get back to the beginning - again I had no idea that settings from an Android client were changing things on the server so now even my Windows emby clients are messed up. My current settings which have my UI almost unusable are: My Media (small) Live TV Active Recordings Continue Watching Continue Listening Latest Media None On another note are there any add-on's that list Channels taking up less real-estate especially on the Android client. Thanks everyone - I'm really hoping I can make this thing work... Jan
Luke 42241 Posted April 12, 2025 Posted April 12, 2025 hi that's pretty close to default. to go back to default, remove active recordings and change my media small back to my media. what issue are you having with it?
