hablemby 0 Posted April 10, 2025 Posted April 10, 2025 2025-04-10 11:49:54.366 Error Server: Error processing request *** Error Report *** Version: 4.7.14.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /var/packages/EmbyServer/var -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -pidfile /var/packages/EmbyServer/var/EmbyServer.pid -defaultdirectory /volume1/Public -updatepackage emby-server-synology7_{version}_x86_64.spk Operating system: Linux version 3.10.108 (root@build3) (gcc version 8.5.0 (GCC) ) #42962 SMP Mon Aug 19 15:12:09 CST 2024 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/packages/EmbyServer/var Application path: /volume1/@appstore/EmbyServer/system System.IndexOutOfRangeException: System.IndexOutOfRangeException: Index was outside the bounds of the array. at Emby.Server.Implementations.Networking.NetworkManager.IPAddressInfo.PrefixLengthToSubnetMask(Byte prefixLength, AddressFamily family) at Emby.Server.Implementations.Networking.NetworkManager.IPAddressInfo.IsOnSameSubnet(IPAddress address) at Emby.Server.Implementations.Networking.NetworkManager.IsAddressInSubnets(IPAddress address, String[] subnets) at Emby.Server.Implementations.Networking.NetworkManager.IsInLocalNetworkInternal(IPAddress address, String endpoint, Boolean resolveHost, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.BaseRequest.IsInLocalNetwork(CancellationToken cancellationToken) at Emby.Api.UserService.GetUsers(GetUsersResult request, Boolean filterByDevice, Boolean filterByNetwork, Boolean isAuthenticated, CancellationToken cancellationToken) at Emby.Api.UserService.Get(GetPublicUsers request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: System.Net.IPAddress PrefixLengthToSubnetMask(Byte, System.Net.Sockets.AddressFamily) please, can anyone help and have allready solved such problem?
Carlo 4561 Posted April 10, 2025 Posted April 10, 2025 Hi, My first suggestion would be to install the current release version downloaded from here: https://emby.media/download.html The current Emby Server version has updated network handling functionality which may handle the network related error in your post. I would also check your network settings on your NAS to make sure everything looks proper. If you had any type of VPN in use, I would test without it running. Carlo
Luke 42240 Posted April 10, 2025 Posted April 10, 2025 Hi, what NAS and what version of DSM does it run? Did you originally install manually or from Synology Package Center?
hablemby 0 Posted April 14, 2025 Author Posted April 14, 2025 Hi, sry for the delay! when i start the emby server, "Emby Server startet. Bitte versuche es gleich noch einmal." comes.
Luke 42240 Posted April 14, 2025 Posted April 14, 2025 @hablembyplease attach the complete emby server log file that is generated. Thanks !
