Pippinuk 5 Posted April 9, 2025 Posted April 9, 2025 Hello! Was there a resolution found to this one? I am experiencing the same issue. My media folder is on an SMB share but when I run a conversion the logs display a FILE NOT FOUND error. Let me know if I can submit the logs. I am running the Emby docker image on Ubuntu 24.04. Many thanks!
Luke 42237 Posted April 9, 2025 Posted April 9, 2025 @Pippinuk HI there, can you please provide a specific example? How to Report a Problem Thanks !
SeanInToronto 0 Posted April 9, 2025 Posted April 9, 2025 No solution. It still doesn't work. I moved to local storage. I don't think SMB protocol supports this, but maybe Luke can figure it out. Very easy to reproduce the situation.
Pippinuk 5 Posted April 9, 2025 Author Posted April 9, 2025 Thanks for getting back to me! I'll get the logs together some screenshots etc and submit it on this thread. It definitely feels like an smb issue. The error references cannot find /data/movies ..... But the actual path should be smb://ipaddress/data/movies Or something like that - maybe backslashes in windows world. Anyway, I'll get back with more info
Luke 42237 Posted April 9, 2025 Posted April 9, 2025 1 minute ago, Pippinuk said: Thanks for getting back to me! I'll get the logs together some screenshots etc and submit it on this thread. It definitely feels like an smb issue. The error references cannot find /data/movies ..... But the actual path should be smb://ipaddress/data/movies Or something like that - maybe backslashes in windows world. Anyway, I'll get back with more info That would be great. Thanks.
Pippinuk 5 Posted April 9, 2025 Author Posted April 9, 2025 Leave it with me a day or two.... Thanks guys! 1
