mbc0 68 Posted November 24, 2014 Posted November 24, 2014 Hi, I use the web interface a lot through Chrome but find that it encodes on my server and does not direct stream? If I play the same file on the same machine using MBT is direct streams, is there a way to enable this or is it a limitation of using the web browser? Many Thanks
Luke 42184 Posted November 24, 2014 Posted November 24, 2014 you don't need to.it's smart enough to know when it can direct stream and when it can't
mbc0 68 Posted November 24, 2014 Author Posted November 24, 2014 Hi Luke, I appreciate the reply but can you help me with as to why it encodes everything then please as mbs does not encode anything on the same machine, also all files play perfectly on the same machine with vlc,media playe etc... will a log show anything? Thanks
Luke 42184 Posted November 24, 2014 Posted November 24, 2014 lookup the supported formats for whatever browser you're using
ebr 16307 Posted November 24, 2014 Posted November 24, 2014 The short answer is yes, the browser is much more limited than those other programs in what it can directly play. 1
Angelblue05 4132 Posted November 25, 2014 Posted November 25, 2014 I use MP4 with AAC audio to get direct stream in Chrome browser. I convert my files using Handbrake.
