ebr 16342 Posted May 9, 2025 Posted May 9, 2025 4 hours ago, Thuzad said: It would be very interesting if it were included directly in the search page and not in a menu, but I think Emby is limiting this for security reasons. @Luke can you confirm this? If it's possible to interact with something other than a menu, I'll try to modify it to integrate it directly into the search. Hi. We cannot integrate this functionality into the Emby core. 1
yocker 1425 Posted October 2, 2025 Author Posted October 2, 2025 52 minutes ago, muiz said: Does this still work? If so. How? I stopped working on it as I found it rather pointless in the end as you can easily just go to the Serr site when you were in Emby website anyway. Maybe one day in the future I will come up with a better idea. 1
yocker 1425 Posted October 2, 2025 Author Posted October 2, 2025 @GrimReaper very sorry to bother you but can you close or remove this thread so no more will find it and think this plugin is still a thing? It's not a plugin I think the devs would want to be here anyway.
gihayes 47 Posted October 2, 2025 Posted October 2, 2025 I just tested it in chrome on my phone and Edge on my computer it works. The app is only to use in a browser. Not the apps. Open Emby in browser, Go to app settings, then It should be at the bottom of the list
GrimReaper 4910 Posted October 2, 2025 Posted October 2, 2025 4 minutes ago, yocker said: can you close or remove this thread so no more will find it and think this plugin is still a thing? Sure thing. You prefer it closed or removed? 1
