reset_ 6 Posted April 7, 2025 Posted April 7, 2025 Hello! Video that i try to play from emby TV app, has opus audio codec. For some reason, my smart tv (samsung with Tizen OS) shows that it supports opus, but actually it doesn't (tried to launch the video locally on tv - got error with "audio encoding") So the solution may be excluding opus transcoding for this device, and if source file has "excluded" codec - to force transcoding to other format. Is that possible? If so, how to do that? Thanks!
Luke 42176 Posted April 7, 2025 Posted April 7, 2025 Hi, what Emby app version are you running? I thought we already excluded this @SamES
reset_ 6 Posted April 7, 2025 Author Posted April 7, 2025 2 minutes ago, Luke said: Hi, what Emby app version are you running? I thought we already excluded this @SamES Emby server version 4.8.11.0 Samsung smart tv app version: 1.9.0
reset_ 6 Posted April 7, 2025 Author Posted April 7, 2025 19 minutes ago, reset_ said: Emby server version 4.8.11.0 Samsung smart tv app version: 1.9.0 Anyway, is there an option to force transcoding on server side?
Solution SamES 1076 Posted April 7, 2025 Solution Posted April 7, 2025 1 hour ago, Luke said: Hi, what Emby app version are you running? I thought we already excluded this @SamES Yes, we have - but probably after 1.9.0 (actually 1.9.2 has this change) 1
reset_ 6 Posted April 8, 2025 Author Posted April 8, 2025 7 hours ago, SamES said: Yes, we have - but probably after 1.9.0 (actually 1.9.2 has this change) Thanks, updating to latest tizen version via USB helped. The issue is closed 1 1
