shiremail 4 Posted April 4, 2025 Posted April 4, 2025 Hello together, the Zidoo Z30 Pro also provides the emby client. I tried it and it works fine. Unfortunately it does not support the transcode feature from my emby server (which works fine with the client app on my AppleTV). Is there any way to solve this? Bye.
shiremail 4 Posted April 4, 2025 Author Posted April 4, 2025 You have to side load the client and install it...That works...
Luke 42242 Posted April 5, 2025 Posted April 5, 2025 HI, what makes you think it doesn't support the transcode feature? What version number do you have now?
shiremail 4 Posted April 5, 2025 Author Posted April 5, 2025 The emby app on the ZIDOO only shows, that is a shortcut. When launched, it nowhere displays the app version. It is really striped down and you only can select the server (more or less). I checked the logs and found: 2025-04-05 09:58:27.861 Info SessionManager: Playback start reported by app Android 7871 on ZIDOO Z30_PRO playing 2025-04-05 10:00:34.147 Debug Server: http/1.1 GET http://192.168.1.xxx:8096/Items/76035/Images/Primary?tag=d7710047f1b406eabb7fe9ef3c84b78e. Source Ip: host1, UserAgent: Dalvik/2.1.0 (Linux; U; Android 11; Z30 PRO Build/RD2A.211001.002)
Luke 42242 Posted April 5, 2025 Posted April 5, 2025 Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
