AJV_20 57 Posted April 2, 2025 Posted April 2, 2025 Is there a way to prevent the icons for the libraries from changing? I like the default ones but it always changes on its own to movie posters
GrimReaper 4842 Posted April 2, 2025 Posted April 2, 2025 1 hour ago, AJV_20 said: Is there a way to prevent the icons for the libraries from changing? Not currently. But you can manually assign library images and those will stick. Lots of example images/sets in Fan Art & Videos Forum section (like this one).
AJV_20 57 Posted April 2, 2025 Author Posted April 2, 2025 Is it possible to get those specific images?
GrimReaper 4842 Posted April 2, 2025 Posted April 2, 2025 Those are not images but SVG icons (that you can download from Google as PNG). 1 1
Smitty018210 146 Posted April 2, 2025 Posted April 2, 2025 You could screen grab them and download them to your PC and then upload them as default image. 1
Smitty018210 146 Posted April 2, 2025 Posted April 2, 2025 Here you go, I was already doing something in Photoshop so I was able to do this for you. You can download those images and then upload them to your server as default images. 2
AJV_20 57 Posted April 2, 2025 Author Posted April 2, 2025 Thank you! 2 hours ago, Smitty018210 said: Here you go, I was already doing something in Photoshop so I was able to do this for you. You can download those images and then upload them to your server as default images. 1
Smitty018210 146 Posted April 2, 2025 Posted April 2, 2025 7 minutes ago, AJV_20 said: Thank you! Not a problem. Enjoy.
