Brooky 1 Posted March 30, 2025 Posted March 30, 2025 I installed the Emby Server and added the Premier Key. When I go to a channel, it will appear as white letters with no background. I go to SUbtiles and set my "settings to Yellow letters with blue background. It shows correctly. However, when I log out and return later, it will revert to white letters without a background. Do I have to set that setting every time I log in? How do I make the selections I choose to stick? Yoel
Abobader 3484 Posted March 30, 2025 Posted March 30, 2025 Hello Brooky, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Brooky 1 Posted March 30, 2025 Author Posted March 30, 2025 Server: Version 4.8.11.0 Accessing via Web at localhost:8096. Brooky
GrimReaper 4842 Posted March 30, 2025 Posted March 30, 2025 Ate you clearing your browsing data? Or you have some addon that's doing that?
Brooky 1 Posted March 30, 2025 Author Posted March 30, 2025 The same effect is achieved with the EMBY Client for Windows. Emby Windows 2.222.2.0
Brooky 1 Posted March 30, 2025 Author Posted March 30, 2025 9 minutes ago, GrimReaper said: Ate you clearing your browsing data? Or you have some addon that's doing that? I have the browser auto-clear the cache when I exit the browsers. Brooky
GrimReaper 4842 Posted March 30, 2025 Posted March 30, 2025 (edited) 4 minutes ago, Brooky said: I have the browser auto-clear the cache when I exit the browsers. Some settings are shared across devices/clients and those will not get cleared. Device specific settings will - subs appearance are one of those. You can either: 1) Not clear cache on exit or 2) Use a different/dedicated browser just for Emby where cache is not cleared Edited March 30, 2025 by GrimReaper 1
Brooky 1 Posted March 31, 2025 Author Posted March 31, 2025 Good Morning: I made modifications on my end on my computer and do not clear the cache. Same issues. Brooky
Luke 42178 Posted March 31, 2025 Posted March 31, 2025 8 hours ago, Brooky said: Good Morning: I made modifications on my end on my computer and do not clear the cache. Same issues. Brooky Hi, what changes?
Brooky 1 Posted March 31, 2025 Author Posted March 31, 2025 I modified it not to clear my caches upon exit, per GrimReaper, and the issues remain.
Luke 42178 Posted March 31, 2025 Posted March 31, 2025 12 minutes ago, Brooky said: I modified it not to clear my caches upon exit, per GrimReaper, and the issues remain. If your settings are changing after closing the browser then something is still getting cleared.
Brooky 1 Posted March 31, 2025 Author Posted March 31, 2025 I have already set it not to clear at all. The settings are not "sticking"
Luke 42178 Posted March 31, 2025 Posted March 31, 2025 What settings exactly? Can you try a different browser? I understand you would like us to solve your problem, but the Emby web app does save some data in browser storage. The "fix" you're looking for is not a problem with the Emby web app per-se, but it's in terms of finding what data is getting cleared due to your settings and stopping that from happening. In order for us to determine that, the more detailed information you can provide, the better.
Solution Brooky 1 Posted April 1, 2025 Author Solution Posted April 1, 2025 I reinstalled the EMBY Server clean and let it rebuild another index on the entire IPTV, and now it is working as it should. 1
