Solal 2 Posted March 29, 2025 Posted March 29, 2025 Hello, I've got two animated series were the first order when fetching the metadata from TMDB is wrong : https://www.themoviedb.org/tv/2345-kim-possible and https://www.themoviedb.org/tv/2098-batman-the-animated-series I wanna use the production order/bluray order for Batman and the DVD (chronological) order for Kim Possible. Unfortunately when I choose DVD order for both of the series and force a metadata refresh, no changes are happening. I'm on beta 4.9.0.42 right now but it is something I already noticed on stable. I use only TMDB as my metadata fetcher. I tried some times ago with TVDB but it did not resolved anything. Thanks. embyserver.txt
GrimReaper 4842 Posted March 29, 2025 Posted March 29, 2025 9 minutes ago, Solal said: Unfortunately when I choose DVD order for both of the series and force a metadata refresh, no changes are happening. I use only TMDB as my metadata fetcher. DVD order applies only if using TVDB as primary meta-downloader - in your configuration with only TMDB meta-downloader enabled it won't do anything. You can either: 1) Enable TVDB and put it on top on preferred meta-providers list, repeat process or 2) Lend your support here: 1
Solal 2 Posted March 29, 2025 Author Posted March 29, 2025 I see that I already did it some time ago... Well, there goes my memory... 1
