Neminem 1591 Posted March 27, 2025 Posted March 27, 2025 Except from this. Try mounting the share as a windows drive.
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 12 minutes ago, Luke said: Not sure if this might help: https://community.wd.com/t/my-cloud-ex2-specified-server-cannot-perform-the-requested-operation/235325 I hate messing with the registry as I want to image a workstation server based off this dev but I’ll give it a shot after lunch. Thanks @Luke
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 6 minutes ago, Neminem said: Except from this. Try mounting the share as a windows drive. I’ll try that after lunch. I swear I did it already but doesn’t hurt to try again. I don’t remember mounting tv shows (?)
Neminem 1591 Posted March 27, 2025 Posted March 27, 2025 (edited) Well after mounting them you will have them as a M:\ and N:\ or what ever you specify as a mount drive. Edited March 27, 2025 by Neminem
visproduction 328 Posted March 27, 2025 Posted March 27, 2025 Try this in Windows 10: Admin login: Control Panel Search for: Find and Fix problems with access files and folders on other computers See if that helps.
Neminem 1591 Posted March 27, 2025 Posted March 27, 2025 @visproductionIt looks like op is using win11
Happy2Play 9798 Posted March 28, 2025 Posted March 28, 2025 @Lukelooks like the db is broke as this is similar to something I reported awhile back library being create multiple times with different dbids. Will guess the original was never removed. Line 916: 2025-03-27 11:51:44.967 Info LibraryMonitor: Watching directory with new FileSystemWatcher for \\m4\media\movies for item 770354 Line 941: 2025-03-27 11:52:10.329 Info LibraryMonitor: \\m4\media\movies is already being watched by watcher for \\m4\media\movies. Adding item 770355 Line 13213: 2025-03-27 12:10:03.428 Info LibraryMonitor: Watching directory with new FileSystemWatcher for \\192.168.7.231\Movies for item 770356 Line 13385: 2025-03-27 12:15:19.165 Info LibraryMonitor: \\m4\media\movies is already being watched by watcher for \\m4\media\movies. Adding item 770357
Solution Happy2Play 9798 Posted March 28, 2025 Solution Posted March 28, 2025 Only thing I can think of would be to create a new folder name for the share ie \movies1.
BigIrn 10 Posted March 29, 2025 Author Posted March 29, 2025 (edited) 9 hours ago, Happy2Play said: Only thing I can think of would be to create a new folder name for the share ie \movies1. @Happy2PlayThank you! I don't know why I didn't think of this first. Both your above solution and the one I'm replying to fixed it. Edited March 29, 2025 by BigIrn
BigIrn 10 Posted March 29, 2025 Author Posted March 29, 2025 Yes! I marked the solution. Technically both his posts worked lol 1
