BigIrn 10 Posted March 27, 2025 Posted March 27, 2025 I have a mac that has content on it and I'm using a windows 11 machine to serve emby. This configuration is just temporary until I remote into the mac running on VPN. On the windows machine I can access from Windows Explorer both network share drives for Movies and TV Shows. In emby I can only see content in TV Shows. Movies is empty. Both folders are shared from the same volume (t9/media/), they have the same account and r/w permissions and I have rebooted the mac to ensure it retains shared folder rights. Here is the log: 2025-03-27 00:24:27.602 Error App: Error in validateChildren for 759174 \\m4\media\Movies *** Error Report *** Version: 4.8.11.0 Command line: C:\Users\image\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.26100 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: C:/Users/image/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\image\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\image\AppData\Roaming\Emby-Server\system System.IO.IOException: System.IO.IOException: The specified server cannot perform the requested operation. : '\\m4\media\Movies' at System.IO.Enumeration.FileSystemEnumerator`1.MoveNext() at System.Collections.Generic.LargeArrayBuilder`1.AddRange(IEnumerable`1 items) at System.Collections.Generic.EnumerableHelpers.ToArray[T](IEnumerable`1 source) at Emby.Server.Implementations.IO.ManagedFileSystem.EnumerateFileSystemInfos(DirectoryInfo dir, Boolean recursive) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive, FileSystemCredentials credentials) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntriesInternal(String path) at System.Collections.Concurrent.ConcurrentDictionary`2.GetOrAdd(TKey key, Func`2 valueFactory) at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren(IDirectoryService directoryService, LibraryOptions libraryOptions) at MediaBrowser.Controller.Entities.BaseItem.ValidateChildrenInternal(IProgress`1 progress, CancellationToken cancellationToken, Boolean recursive, Boolean refreshChildMetadata, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Dictionary`2 newItemIds, MetadataRefreshOptions refreshOptions, IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.ValidatePhysicalRoots(IProgress`1 progress, IDirectoryService directoryService, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Boolean MoveNext()
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 (edited) 10 minutes ago, BigIrn said: Both folders are shared from the same volume (t9/media/), they have the same account and r/w permissions and I have rebooted the mac to ensure it retains shared folder rights. Im not sure if this is a type o when writing here. \\t9\media\movies 10 minutes ago, BigIrn said: System.IO.IOException: System.IO.IOException: The specified server cannot perform the requested operation. : '\\m4\media\Movies' Edited March 27, 2025 by Neminem
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 So check it. They are identical. I'm so lost as to how to troubleshoot it.
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 Can you show a screenshot of tv shows path in Emby.
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 Here are both movies (empty) and TV Shows (populated):
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 Try putting a \ behind movies you have that trailing back slash in your tv show path.
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 But I a bit confused by this in your screen shots. But in Emby you have \\m4\media\tv shows and you say that works.
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 Yeah it works both ways because the media folder and the TV Shows/Movies folder have the same share permissions
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 Did you try with this movie path \\m4\media\movies\ By adding the \ to the end. Like you have in your tv show path.
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 Still empty Does this mean anything? 2025-03-27 11:17:19.808 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2025-03-27 11:17:19.813 Debug SqliteItemRepository: GetitemById Folder 578800 C:\Streaming\Movies 2025-03-27 11:17:19.815 Debug SqliteItemRepository: GetitemById Folder 609881 C:\Streaming\TV Shows 2025-03-27 11:17:19.816 Debug SqliteItemRepository: GetitemById Folder 762264 \\m4\media\tv shows\ 2025-03-27 11:17:19.816 Debug SqliteItemRepository: GetitemById Folder 770354 \\m4\media\movies 2025-03-27 11:17:19.818 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0100285 seconds 2025-03-27 11:17:19.818 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2025-03-27 11:17:19.818 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 7.41E-05 seconds 2025-03-27 11:17:19.818 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2025-03-27 11:17:19.818 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 3.89E-05 seconds 2025-03-27 11:17:19.818 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2025-03-27 11:17:19.818 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0001517 seconds 2025-03-27 11:17:19.818 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2025-03-27 11:17:19.818 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0002001 seconds 2025-03-27 11:17:19.818 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2025-03-27 11:17:19.819 Info App: ProcessRun 'LaunchWebBrowser' Execute: http://localhost:8096/web/index.html 2025-03-27 11:17:19.861 Debug App: Ping test result to http://192.168.7.249:8096/system/ping. Success: True 2025-03-27 11:17:19.862 Debug App: CreateSsdpUdpSocket 0.0.0.0:1900 2025-03-27 11:17:19.863 Debug App: CreateSsdpUdpSocket 0.0.0.0:0 2025-03-27 11:17:19.863 Debug App: CreateSsdpUdpSocket 192.168.7.249:0 2025-03-27 11:17:19.863 Debug App: CreateSsdpUdpSocket 127.0.0.1:0 2025-03-27 11:17:19.864 Info App: Init BeginReceive on 0.0.0.0 2025-03-27 11:17:19.864 Info App: Init BeginReceive on 0.0.0.0 2025-03-27 11:17:19.864 Info App: Init BeginReceive on 192.168.7.249 2025-03-27 11:17:19.864 Info App: Init BeginReceive on 127.0.0.1
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 I can access emby on my other machine using \\192.168.7.231\Movies... I'm going to try the IP address instead of the local host name.
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 Ohh yes try that. 6 minutes ago, BigIrn said: 2025-03-27 11:17:19.816 Debug SqliteItemRepository: GetitemById Folder 762264 \\m4\media\tv shows\ 2025-03-27 11:17:19.816 Debug SqliteItemRepository: GetitemById Folder 770354 \\m4\media\movies Also try adding that \
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 1 minute ago, Neminem said: Ohh yes try that. Also try adding that \
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 But remove the old that didn't work. We dont want to trash your DB.
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 2025-03-27 11:17:21.917 Debug Dx11VaCodecProvider: DXVA2_ModeMPEG2_VLD - ColorFormat #1: Opaque420 => yuv420p 2025-03-27 11:17:22.020 Info LibraryMonitor: Watching directory with new FileSystemWatcher for \\m4\media\movies for item 770354 2025-03-27 11:17:22.069 Debug Dx11VaCodecProvider: Supported Resolutions: 160x120, 176x144, 320x240, 352x288, 720x480, 720x240, 720x576, 1280x720, 1920x1080, 2048x1024, 2048x1080 2025-03-27 11:17:22.069 Debug Dx11VaCodecProvider: Unsupported Resolutions: 3140x2160, 3680x1536, 3840x2160, 4096x2048, 4096x2160, 4096x2176, 7680x4320, 8192x4320, 8192x4352 2025-03-27 11:17:22.069 Debug Dx11VaCodecProvider: Max Resolution: 2048x1080 2025-03-27 11:17:22.087 Debug Dx11VaCodecProvider: DXVA2_ModeVC1_D2010 - ColorFormat #0: NV12 => nv12 2025-03-27 11:17:22.178 Info LibraryMonitor: Watching directory with new FileSystemWatcher for \\m4\media\tv shows for item 762264 2025-03-27 11:17:22.179 Info LibraryMonitor: Watching directory with new FileSystemWatcher for C:\Streaming\Movies for item 578800 2025-03-27 11:17:22.179 Info LibraryMonitor: Watching directory with new FileSystemWatcher for C:\Streaming\TV Shows for item 609881
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 Ok guess I'm out of ideas, sorry. But would be great with full logs, to see more info, that might lead to a solution. Devs would also ask for those
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 Fuck it this is annoying because the other folder works and this one doesn't. Posting the entire log. embyserver(6).txt
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 1 minute ago, Neminem said: Ok guess I'm out of ideas, sorry. But would be great with full logs, to see more info, that might lead to a solution. Devs would also ask for those Ha! beat me to it 1
Luke 42289 Posted March 27, 2025 Posted March 27, 2025 Not sure if this might help: https://community.wd.com/t/my-cloud-ex2-specified-server-cannot-perform-the-requested-operation/235325
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 This is definitely the error but I have no clue what it means: 2025-03-27 12:13:30.054 Error App: Error in validateChildren for 770356 \\192.168.7.231\Movies\ *** Error Report *** Version: 4.8.11.0 Command line: C:\Users\image\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.26100 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: C:/Users/image/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\image\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\image\AppData\Roaming\Emby-Server\system System.IO.IOException: System.IO.IOException: Invalid Signature. : '\\192.168.7.231\Movies' at System.IO.Enumeration.FileSystemEnumerator`1.MoveNext() at System.Collections.Generic.LargeArrayBuilder`1.AddRange(IEnumerable`1 items) at System.Collections.Generic.EnumerableHelpers.ToArray[T](IEnumerable`1 source) at Emby.Server.Implementations.IO.ManagedFileSystem.EnumerateFileSystemInfos(DirectoryInfo dir, Boolean recursive) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive, FileSystemCredentials credentials) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntriesInternal(String path) at System.Collections.Concurrent.ConcurrentDictionary`2.GetOrAdd(TKey key, Func`2 valueFactory) at MediaBrowser.Controller.Entities.Folder.GetNonCachedChildren(IDirectoryService directoryService, LibraryOptions libraryOptions) at MediaBrowser.Controller.Entities.BaseItem.ValidateChildrenInternal(IProgress`1 progress, CancellationToken cancellationToken, Boolean recursive, Boolean refreshChildMetadata, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Dictionary`2 newItemIds, MetadataRefreshOptions refreshOptions, IDirectoryService directoryService) at Emby.Server.Implementations.Library.LibraryManager.ValidatePhysicalRoots(IProgress`1 progress, IDirectoryService directoryService, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Boolean MoveNext()
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 Ok what happend here ? Error in Directory watcher for: \\m4\media\tv shows *** Error Report *** Version: 4.8.11.0 Command line: C:\Users\image\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.26100 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: C:/Users/image/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\image\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\image\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. Source: TargetSite: No Stack Trace Available And the same for Error in Directory watcher for: \\m4\media\movies *** Error Report *** Version: 4.8.11.0 Command line: C:\Users\image\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.26100 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: C:/Users/image/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\image\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\image\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. Source: TargetSite: No Stack Trace Available This happens 2 times for both tv shows and movies.
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 1 minute ago, Neminem said: Ok what happend here ? Error in Directory watcher for: \\m4\media\tv shows *** Error Report *** Version: 4.8.11.0 Command line: C:\Users\image\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.26100 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: C:/Users/image/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\image\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\image\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. Source: TargetSite: No Stack Trace Available And the same for Error in Directory watcher for: \\m4\media\movies *** Error Report *** Version: 4.8.11.0 Command line: C:\Users\image\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows 10.0.26100 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: C:/Users/image/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 8 Data path: C:\Users\image\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\image\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (64): The specified network name is no longer available. Source: TargetSite: No Stack Trace Available This happens 2 times for both tv shows and movies. That is what is weird. TV shows is working:
BigIrn 10 Posted March 27, 2025 Author Posted March 27, 2025 4 minutes ago, Luke said: Not sure if this might help: https://community.wd.com/t/my-cloud-ex2-specified-server-cannot-perform-the-requested-operation/235325 I'm guessing this is a credential issue. My windows and Mac share the same userid/pw on the same workgroup. Embyserver.exe runs on "image". it's not a service so I can't change how it authenticates. I didn't have to impersonate or change anything to access the shared drives using windows explorer.
Neminem 1630 Posted March 27, 2025 Posted March 27, 2025 I'm not sure if I can help you, sorry. Don't know the inner workings of Mac and sharing from a mac. 1
