jmoor98904 2 Posted March 21, 2025 Posted March 21, 2025 Hello all, New here to putting my movies on a server. I need some help. Please speak to me like a child...i am old..lol 1. can emby using a roku ultra player play dolby vision rips? 2. I can not seem to find a good compression tool to help compress my mkv's to a smaller file and keeping dolby vision. Is there anything out there for this or does compressing loose all dolby vision? Thanks Jack
rbjtech 5341 Posted March 21, 2025 Posted March 21, 2025 16 hours ago, jmoor98904 said: 1. can emby using a roku ultra player play dolby vision rips? Yes, but as there are multiple DV profiles - ensure both your TV and the Roku can play them. I would sugest profile 8.x as that will be the most compatible. 16 hours ago, jmoor98904 said: 2. I can not seem to find a good compression tool to help compress my mkv's to a smaller file and keeping dolby vision. Is there anything out there for this or does compressing loose all dolby vision? It's possible but not technically easy. You have to extract the Dolby layer, compress the video and then re-apply the layer again. It's probably easier if you simply get a lower bandwidth version to begin with.
