Solution razclud 5 Posted July 10, 2025 Author Solution Posted July 10, 2025 Fixed with the latest Onkyo firmware upgrade 1 1
visproduction 335 Posted July 10, 2025 Posted July 10, 2025 Raz, I wonder if you had been able to bypass your Onkyo, somehow, to find out earlier, that it was an Onkyo issue? Doing these bypass tests take some effort, but you save time by discovering which hardware / software / connectivity issues are not causing the issue. Just a thought...
razclud 5 Posted July 10, 2025 Author Posted July 10, 2025 It was my next step but the firmware solved it. I now have some other issues but it is the receiver's fault. Thanks 1
