GhostZeta 0 Posted March 15, 2025 Posted March 15, 2025 (edited) After rebuilding the Emby music library, the manually edited and saved artist.nfo files were not restored and were directly overwritten Edited March 15, 2025 by GhostZeta
Abobader 3491 Posted March 15, 2025 Posted March 15, 2025 Hello GhostZeta, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
GhostZeta 0 Posted March 15, 2025 Author Posted March 15, 2025 tried 4.9.0.35 and 4.8.10.0, same problem
Neminem 1630 Posted March 15, 2025 Posted March 15, 2025 Without logs, its guess work. Permissions ? Drive not active ? Bad internet etc......
GhostZeta 0 Posted March 15, 2025 Author Posted March 15, 2025 there should not be any internet problem for I edit all the information of artists mannually, the data from Metadata Downloaders is not detailed. The first screenshot shows my attempt to manually edit an artist's information. The second screenshot demonstrates the result after I created a brand-new Emby server, set up a music library, and scanned the media library. Although Emby has read permissions for the artist.nfo files, it did not read the content during the library rebuild process. Instead, it directly overwrote and cleared my manually edited artist.nfo files. and The log files contain the complete logs from the creation of the new Emby server and scanning of the music library. embyserver (1).txt
Solution Luke 42287 Posted April 8, 2025 Solution Posted April 8, 2025 Hi @GhostZetacurrently artist nfo files are only written to, not read. We will be re-enabling this in a future update. I have been posting test builds of it enabled here in order to collect feedback, so maybe you can help:
sydlexius 302 Posted February 24 Posted February 24 On 4/8/2025 at 10:17 AM, Luke said: Hi @GhostZetacurrently artist nfo files are only written to, not read. We will be re-enabling this in a future update. I have been posting test builds of it enabled here in order to collect feedback, so maybe you can help: When will read be re-enabled? I'm currently working on some automation around the artist.nfo, and I'd rather use that as a source.
Luke 42287 Posted February 26 Posted February 26 On 2/24/2026 at 5:42 PM, sydlexius said: When will read be re-enabled? I'm currently working on some automation around the artist.nfo, and I'd rather use that as a source. To be honest I haven’t gotten much feedback on the test builds.
