HappyGilmour 20 Posted March 15, 2025 Posted March 15, 2025 Good morning, I have finally settled on an IPTV provider but their EPG only provides 24 hours of data. I can get the info through free EPG sources but the auto-matching of the channels leaves me with thousands of channels I need to manually map. The web interface is inefficient for that volume. I believe I can do better by scripting this myself. And that brings me to my question. Can anyone tell me what file holds the guide/channel matching information? Also where that file resides by default? Thank you in advance! Don Morgan PS I am a premier subscriber.
Luke 42241 Posted March 16, 2025 Posted March 16, 2025 hi, this is in the emby server database and not in a file.
HappyGilmour 20 Posted March 16, 2025 Author Posted March 16, 2025 Is it in the livetv.db SQLlite database in the ChannelMappings table? I took a stab at asking an AI and that is what it said. If so then I should be able to handle that. I don’t want to touch anything without confirmation from you that it is correct. Thanks.
Luke 42241 Posted March 17, 2025 Posted March 17, 2025 It is in library.db. There is no channelmappings table.
HappyGilmour 20 Posted March 18, 2025 Author Posted March 18, 2025 Thank you. I may just stick it out and do it all manually. Nothing wrong with having sweat equity in the project. But it’s good to know I have this option if I need it. Thanks again. You are always very helpful. 1
