sftech13 25 Posted March 15, 2025 Posted March 15, 2025 Is this a known bug by chance or any way to force it. I try and use the aspect ratio to fill on streams that are not the proper fitment it does not work. It does work on Android device and my PC. Just not on the app for Samsung on tizen. Emby for Samsung 1.8.0 Samsung Smart TV (QN83S90CAEXZA)
SamES 1084 Posted March 15, 2025 Posted March 15, 2025 I think it is fixed in the next update, or you can try the USB beta install to test if it resolves your issue 1
Solution SamES 1084 Posted March 15, 2025 Solution Posted March 15, 2025 I think this is the same issue, in which case I have fixed it already. 1
sftech13 25 Posted March 16, 2025 Author Posted March 16, 2025 So now the aspect ratio has been fixed. I've lost the ability on different live streams to go in between different aspect ratios. The OSD does not allow selection of the settings, CC or even the progress bar. Any suggestions?
Luke 42239 Posted March 16, 2025 Posted March 16, 2025 2 hours ago, sftech13 said: So now the aspect ratio has been fixed. I've lost the ability on different live streams to go in between different aspect ratios. The OSD does not allow selection of the settings, CC or even the progress bar. Any suggestions? What exactly happens when you try?
SamES 1084 Posted March 16, 2025 Posted March 16, 2025 4 hours ago, sftech13 said: So now the aspect ratio has been fixed. I've lost the ability on different live streams to go in between different aspect ratios. The OSD does not allow selection of the settings, CC or even the progress bar. Any suggestions? @Luke, again, this is caused when a tv channel is being played (or an in progress recording) there is no position indicator on the slider, so nothing on the OSD has focus and it is impossible to navigate. This is really a big problem affecting Samsung and LG and has been raised several times now.
SamES 1084 Posted March 16, 2025 Posted March 16, 2025 4 hours ago, sftech13 said: So now the aspect ratio has been fixed. I've lost the ability on different live streams to go in between different aspect ratios. The OSD does not allow selection of the settings, CC or even the progress bar. Any suggestions? Try pressing down arrow first which should bring up the info row, then up. It's a work around.
sftech13 25 Posted March 17, 2025 Author Posted March 17, 2025 5 hours ago, SamES said: Try pressing down arrow first which should bring up the info row, then up. It's a work around. That's been working so far. Thank you very much for work around. 1
