jarome 1 Posted March 13, 2025 Posted March 13, 2025 The ssd on my LEAP 15.16 server died and I had to replace it and reinstall Emby from scratch. I only use Emby for music album,s and each album folder has an image file among the flac, m4a, or mp3 tracks. Before the rebuild, all the images were displayed, but now3 none of them are. I have rescanned the libraries and metadata to no avail. What am I missing?
Luke 42243 Posted March 13, 2025 Posted March 13, 2025 HI here, how are your files named and organized? How did you configure your library options for the music library?
jarome 1 Posted March 13, 2025 Author Posted March 13, 2025 Artist/album/tracks There seem to be no options for the Library that are relevant.
Luke 42243 Posted March 13, 2025 Posted March 13, 2025 Hi, just click on the library in Emby library setup.
jarome 1 Posted March 13, 2025 Author Posted March 13, 2025 (edited) Those are the images I posted above. I do not want images pulled from the internet. They are all in the album folders. Edited March 13, 2025 by jarome
jarome 1 Posted March 13, 2025 Author Posted March 13, 2025 I rebuilt the library. No change. how do I tell it to import the imaged inside the albums?
Luke 42243 Posted March 14, 2025 Posted March 14, 2025 The second screenshot you showed is a global set of settings that apply to all libraries. Please open the context menu again on the library by right clicking on it. Then click Edit so that you can see the folders for the library and edit them. Under there are the options for that specific library. Thanks.
jarome 1 Posted March 14, 2025 Author Posted March 14, 2025 But the options are all for online image servers. I do not see anything for local images. But today, the images have appeared. Maybe redoing the library fixed it. Thanks.
Luke 42243 Posted March 14, 2025 Posted March 14, 2025 3 hours ago, jarome said: But the options are all for online image servers. I do not see anything for local images. But today, the images have appeared. Maybe redoing the library fixed it. Thanks. Can you please show the library options? Thanks.
Luke 42243 Posted March 16, 2025 Posted March 16, 2025 OK so the reason why it is probably working right now is because you set the music folder structure option, and I'm guessing you probably didn't before. If you leave it at the default of Other, then there's no support for album or artist images in your own folders.
jarome 1 Posted March 16, 2025 Author Posted March 16, 2025 I am pretty sure I did set it. Time heals all.... 1
