beefsnack 16 Posted March 13, 2025 Posted March 13, 2025 Just Curious if it's possible. I've looked around to see if I could find any settings to change the amount to a greater limit than 24 (to every media folder i have in the secondary home screen section) but wasn't successful, I figured it might be worded differently as well, still no luck so here I am, I'm looking to see if I can increase the limit of the icons in the secondary home screen sections such as latest media so One can cycle through ALL of the current "latest added media" because it's limited to 24, any help would be great, if you're not following what I'm say I'll post an image, no worries, I'm to tire at the moment. TIA.
Carlo 4561 Posted March 13, 2025 Posted March 13, 2025 Hi, I believe those are fixed numbers that can't b changed. Carlo
beefsnack 16 Posted March 13, 2025 Author Posted March 13, 2025 Yes I just noticed It's now 16, the update chopped it down from 24
Luke 42178 Posted March 13, 2025 Posted March 13, 2025 Hi, just to clarify, this hasn’t been changed.
arrbee99 1834 Posted March 14, 2025 Posted March 14, 2025 Also, you can change the limit in a browser (and only a browser), or of course you can go to Movies/whatever and sort by Date Added. Neither ideal of course. I think, maybe, the limit is 24 in the old Emby Android app and 16 in the new.
beefsnack 16 Posted March 14, 2025 Author Posted March 14, 2025 (edited) 2 hours ago, Luke said: Hi, just to clarify, this hasn’t been changed. well it's only allowing 16 icons in "Latest" now, when it use to be 24 (granted this is ONLY on the pc side of things in the Browser, when accessing via the server it's still 24), I would be able to scroll at least twice, I sit in front of my system all day editing my server, so what hasn't changed than? it's not that big of a deal Idc really, not trying to argue with you but it has. Edited March 14, 2025 by beefsnack
beefsnack 16 Posted March 14, 2025 Author Posted March 14, 2025 7 minutes ago, arrbee99 said: Also, you can change the limit in a browser (and only a browser), or of course you can go to Movies/whatever and sort by Date Added. Neither ideal of course. I think, maybe, the limit is 24 in the old Emby Android app and 16 in the new. This Is what I believe might have happened. Just the Browser on PC side of things.
arrbee99 1834 Posted March 14, 2025 Posted March 14, 2025 Hokay, just pointing out that you can up the number on a PC with a bit of fiddling if you want to. I up it to 64 when I feel the urge.
beefsnack 16 Posted March 14, 2025 Author Posted March 14, 2025 8 hours ago, arrbee99 said: Hokay, just pointing out that you can up the number on a PC with a bit of fiddling if you want to. I up it to 64 when I feel the urge. do tell
arrbee99 1834 Posted March 15, 2025 Posted March 15, 2025 Someone else did this not me, so its mentioned here somewhere...but anyway - - shut down the server - find the file homesections..js file. Mine is in the folder C:\Users\XXXXX\AppData\Roaming\Emby-Server\system\dashboard-ui\modules\homesections ........... XXXXX being your name. - make a backup of it ! - edit and search for '16'. I'm fairly sure there is only one '16'. Looks like - change the 16 to 64 (or whatever you fancy). Save and restart the server. The change only lasts for as long as that server version lasts. So any server update - rinse and repeat. I'm on Windows, no idea how / if this works (or doesn't) for Synology, Docker, Linux etc... Just tried it and it works, but proceed at you own peril... 1
beefsnack 16 Posted March 15, 2025 Author Posted March 15, 2025 7 hours ago, arrbee99 said: Just tried it and it works, but proceed at you own peril... I will, Thanks
beefsnack 16 Posted March 24, 2025 Author Posted March 24, 2025 On another note, Just noticed is it me or does Emby have difficulty playing .ASS sub files? Because I can't get any of them to play through, SRT, SDH, CC ect. all work fine just ass. doesn't seem to work at all, anything I need to do here? Do I need a plugin? TIA Beef
Luke 42178 Posted March 24, 2025 Posted March 24, 2025 15 minutes ago, beefsnack said: On another note, Just noticed is it me or does Emby have difficulty playing .ASS sub files? Because I can't get any of them to play through, SRT, SDH, CC ect. all work fine just ass. doesn't seem to work at all, anything I need to do here? Do I need a plugin? TIA Beef Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
