JDutton 10 Posted March 17, 2025 Author Posted March 17, 2025 I'm logged in using WINSCP and see /share/CACHEDEV1_DATA, but there is no .qpkg folder. Should there be another name for it?
JDutton 10 Posted March 17, 2025 Author Posted March 17, 2025 FOUND IT! Here is the most recent file. embyserver-63877769978.txt
Happy2Play 9811 Posted March 17, 2025 Posted March 17, 2025 Doesn't look your 4.8.11.0 upgrade took. 2025-03-16 00:59:38.515 Info App: Application version: 4.7.13.0 But all I see in the entire log is port mapper failing. Looks like there may a be a daylight savings time issue per this midnight rollover log also.
Luke 42238 Posted March 17, 2025 Posted March 17, 2025 4 hours ago, JDutton said: FOUND IT! Here is the most recent file. embyserver-63877769978.txt 910.32 kB · 1 download Can you please attach the previous few log files as well? Also it looks like you're running a very old version.
JDutton 10 Posted March 17, 2025 Author Posted March 17, 2025 Here is all I''ve got. embyserver.txt embyserver-63877510778.txt embyserver-63877597178.txt embyserver-63877683578.txt
Solution Luke 42238 Posted March 17, 2025 Solution Posted March 17, 2025 OK so are you able to install a newer version? Try installing 4.8.11, then reboot the NAS as we've seen that sometimes this is necessary with QNAP.
JDutton 10 Posted March 17, 2025 Author Posted March 17, 2025 Problem solved. I think rebooting the server was all it really needed. Thank you! 1
supertoto1977 2 Posted March 23, 2025 Posted March 23, 2025 Hello, The reboot worked because Emby cannot be stopped properly. There's an issue in the emby-server.sh. It uses the file /var/run/emby-server.pid to kill the current process. But this file is never created during the start. So the stop cannot work. I updated manually the emby-server.sh with the script below (to add in the start) part just before ;; ) sleep 10 PID=$(ps -ef | grep "$QPKG_DIR"/system/EmbyServer | grep -v grep | awk '{print $1}') if [ -z "$PID" ]; then echo "Emby is not running." exit 1 fi @Luke Could you please have a look on this issue?
supertoto1977 2 Posted March 23, 2025 Posted March 23, 2025 My bad, i forgot one line in the previous post sleep 10 PID=$(ps -ef | grep "$QPKG_DIR"/system/EmbyServer | grep -v grep | awk '{print $1}') if [ -z "$PID" ]; then echo "Emby is not running." exit 1 fi echo "$PID" > $PID_FILE
Luke 42238 Posted March 23, 2025 Posted March 23, 2025 16 hours ago, supertoto1977 said: Hello, The reboot worked because Emby cannot be stopped properly. There's an issue in the emby-server.sh. It uses the file /var/run/emby-server.pid to kill the current process. But this file is never created during the start. So the stop cannot work. I updated manually the emby-server.sh with the script below (to add in the start) part just before ;; ) sleep 10 PID=$(ps -ef | grep "$QPKG_DIR"/system/EmbyServer | grep -v grep | awk '{print $1}') if [ -z "$PID" ]; then echo "Emby is not running." exit 1 fi @Luke Could you please have a look on this issue? What version did you test with?
supertoto1977 2 Posted March 24, 2025 Posted March 24, 2025 5 hours ago, Luke said: What version did you test with? The latest one : 4.8.11.0 (package emby-server-qnap_4.8.11.0_x86_64.qpkg)
Luke 42238 Posted March 24, 2025 Posted March 24, 2025 OK there are changes related to this on the 4.9 beta channel so it could be resolved there already.
