JDutton 10 Posted March 12, 2025 Posted March 12, 2025 I got a message on one of my devices that the server needed to be updated, so I've installed version 4.8.11.0 and still get the message. Also, when I try to open it from my QNAP app center, the EMBY screen flashes and goes blank. Any suggestions?
Luke 42238 Posted March 12, 2025 Posted March 12, 2025 Quote I got a message on one of my devices that the server needed to be updated, so I've installed version 4.8.11.0 and still get the message. Hi there, please attach the emby server log from when the problem occurred: How to Report a Problem Thanks.
Luke 42238 Posted March 12, 2025 Posted March 12, 2025 Quote Also, when I try to open it from my QNAP app center, the EMBY screen flashes and goes blank. What address is in the browser address bar?
JDutton 10 Posted March 12, 2025 Author Posted March 12, 2025 The address is http://192.168.1.129:8080/cgi-bin/main.html?20250108 I'm pretty inexperienced with this and don't know where to find the Emby server dashboard.
JDutton 10 Posted March 12, 2025 Author Posted March 12, 2025 Is this correct? http://192.168.1.129:8096/web/index.html#!/home
Luke 42238 Posted March 12, 2025 Posted March 12, 2025 18 minutes ago, JDutton said: Is this correct? http://192.168.1.129:8096/web/index.html#!/home Well the web app will switch it to that, yes, but all you need to bookmark is http://ip:8096
JDutton 10 Posted March 12, 2025 Author Posted March 12, 2025 Sorry, I'm lost. I'll keep digging to find the server log.
Luke 42238 Posted March 12, 2025 Posted March 12, 2025 1 minute ago, JDutton said: Sorry, I'm lost. I'll keep digging to find the server log. How are you lost?
JDutton 10 Posted March 12, 2025 Author Posted March 12, 2025 I haven't been able to find the server logs and I don't know what to do with "http://ip:8096"
JDutton 10 Posted March 12, 2025 Author Posted March 12, 2025 How do you find the Emby Server Dashboard?
Luke 42238 Posted March 12, 2025 Posted March 12, 2025 44 minutes ago, JDutton said: I haven't been able to find the server logs and I don't know what to do with "http://ip:8096" Just put that address into the browser address bar, where ip stands for the ip address of your qnap machine. that will take you to the Emby web app where you can reach the server dashboard.
JDutton 10 Posted March 12, 2025 Author Posted March 12, 2025 That is when the screen flashes and goes blank.
Luke 42238 Posted March 12, 2025 Posted March 12, 2025 Just now, JDutton said: That is when the screen flashes and goes blank. I thought you said it was when clicking the button in QNAP?
JDutton 10 Posted March 13, 2025 Author Posted March 13, 2025 It does the same either way. It flashes "Emby" then goes blank. Is there another ip address I'm not aware of? I also searched for C:\Users\{user}\AppData\Roaming\Emby-Server. I looked at each user name and found the folder called Roaming, but there is no subfolder named "Emby-Server".
Luke 42238 Posted March 13, 2025 Posted March 13, 2025 Can you try clearing browsing data and seeing if that helps?
JDutton 10 Posted March 13, 2025 Author Posted March 13, 2025 Now it shows the initial "Emby" screen and stops there. Nothing but the word "Emby" on the screen. I tried it with the ip and clicking on the app. Same result.
Luke 42238 Posted March 13, 2025 Posted March 13, 2025 Is any emby server log file generated? Emby Server Data Folder
JDutton 10 Posted March 13, 2025 Author Posted March 13, 2025 Not that I can find. I even created an "Ember-Server"' folder inside /Roaming, but no files have been added.
Luke 42238 Posted March 13, 2025 Posted March 13, 2025 44 minutes ago, JDutton said: Not that I can find. I even created an "Ember-Server"' folder inside /Roaming, but no files have been added. There has to be a server log if you got that far. We know the server is running, so there is a log file. You just have to be able to get to it. It's usually located here on QNAP: QNAP /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata
JDutton 10 Posted March 13, 2025 Author Posted March 13, 2025 I can't find that folder. when I look at the server through File Explorer on my PC I see a list of folders. I've looked through them all with no luck. Is there some other way to access the folder other than with File Explorer?
JDutton 10 Posted March 16, 2025 Author Posted March 16, 2025 Is there any chance the log files are not being created? I've searched for both C:\Users\{user}\AppData\Roaming\Emby-Server and /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata What am I missing?
One2Go 120 Posted March 16, 2025 Posted March 16, 2025 (edited) When just the Emby screen shows with the rotating circle, go to the QNAP server login. Stop the Emby server and start it again. Go to your server's IP address and I presume from your previous post it is http://192.168.1.129:8096 That should start the dashboard. The server log is on the QNAP device and the only way I can get to that is using a Linux program that runs on Windows like WinSCP The log files can be found at the directory /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata/logs Edited March 16, 2025 by One2Go
Luke 42238 Posted March 16, 2025 Posted March 16, 2025 @JDuttonplease let us know if this helps. Thanks !
