nojaha 4 Posted March 12, 2025 Posted March 12, 2025 Hi guys I've been using the VAAPI decoder over QuickSync for my VC-1 decoding needs for a while now, since using QuickSync would result in massive audio delays (talking several minutes here). I upgraded the server today from version 4.8.10.0 to version 4.8.11.0, and now the VAAPI decoder just fails whenever I try to transcode. It can still decode with QuickSync as it did before, with the preexisting issue with the audio delay. From what I can read, QuickSync doesn't seem to be the best at decoding VC-1 anyway I've attached what I think are all the relevant logs, as well as a couple of screenshots of where it seems to fail in the transcode log, and when it fails on the user side. Please let me know if there is anything missing System Setup OS: Unraid 6.12.14 CPU: i3-1315U RAM: 64 GB DDR4-3200 System Storage (Docker & Transcoding): Samsung 990 Pro SSD 4TB Media Storage: WD Red Plus 12TB HDDs ffmpeg-transcode-1a6f266f-ddd2-4940-8f42-c8a32f1d7837_1.txt embyserver.txt hardware_detection-63877405728.txt
Solution Luke 42243 Posted March 12, 2025 Solution Posted March 12, 2025 hi, can you try unchecking the quicksync encoder and see if that resolves it? Failing that, can you provide a 4.8.10 log log of the same content for comparison purposes? Thanks.
nojaha 4 Posted March 12, 2025 Author Posted March 12, 2025 (edited) Unchecking the QuickSync encoder did indeed resolve it! Do you have any idea why it seems to have worked before? Would like to be able to use QuickSync for encoding and decoding in general, and only using VAAPI for decoding VC-1, if possible Edited March 12, 2025 by nojaha
Luke 42243 Posted March 12, 2025 Posted March 12, 2025 At some point we changed quicksync to be prioritized over vaapi. I didn't think that change had made it into 4.8 yet but I guess it must have.
nojaha 4 Posted March 12, 2025 Author Posted March 12, 2025 Is this a permanent change, and moving forward does this mean that I won't be able to have VAAPI selected for decoding VC-1, without also unchecking QuickSync completely from the encoders?
Luke 42243 Posted March 12, 2025 Posted March 12, 2025 4 minutes ago, nojaha said: Is this a permanent change, and moving forward does this mean that I won't be able to have VAAPI selected for decoding VC-1, without also unchecking QuickSync completely from the encoders? In our testing and development we believe qsv is generally a better option so that is why it is prioritized higher now. But there are always exceptions to the rule and that's why the options exist. In 4.8.10 it probably was encoding with vaapi so the end result is the same as unchecking qsv for it.
Luke 42243 Posted March 12, 2025 Posted March 12, 2025 Actually the change is still 4.9 only. If you could install 4.8.10 over the top real quick to test it and provide a log, we might learn something from that. Thanks.
nojaha 4 Posted March 12, 2025 Author Posted March 12, 2025 I'm sorry, over the top? Do you want me to downgrade, or spin up another Docker instance?
Luke 42243 Posted March 12, 2025 Posted March 12, 2025 You can just install 4.8.10 over your current install as a way of downgrading, yes. Then test it and provide the log, and then you should be able to upgrade again.
nojaha 4 Posted March 12, 2025 Author Posted March 12, 2025 Well, now it doesn't work on version 4.8.10.0 anymore either Not sure if the logs will provide anything useful, since it seems to be failing in the exact same way now. Perhaps residual leftovers from the 4.8.11.0 upgrade? ffmpeg-transcode-5357c63e-07f8-425d-9f0f-51a605c055fc_1.txt embyserver (1).txt
nojaha 4 Posted March 12, 2025 Author Posted March 12, 2025 I have a couple of server logs from before the upgrade, but no transcoding logs, unfortunately
Luke 42243 Posted March 12, 2025 Posted March 12, 2025 No, did you update drivers recently? Try rolling that back.
nojaha 4 Posted March 12, 2025 Author Posted March 12, 2025 Well, I upgraded from version 6.12.13 to 6.12.14 of Unraid, which effectively changes the Linux kernel from 6.1.106 to 6.1.118. Want me to try downgrading?
Luke 42243 Posted March 12, 2025 Posted March 12, 2025 I think for now yes. We are currently investigating an issue with the latest drivers. Thanks.
nojaha 4 Posted March 12, 2025 Author Posted March 12, 2025 Tried downgrading to version 6.12.13 of Unraid, as well as trying with both 4.8.10.0 and 4.8.11.0 of Emby, and none of them work now Not sure what the hell went wrong Pardon my ignorance here, and correct me if I'm wrong It sounds like whatever decoder is used, it should be matched for the encoder as well? Shouldn't it automatically select the correct encoder based on which decoder is used? And that the priority weighting should be on the decoder side, if a decoder is indeed used? ffmpeg-transcode-64f6904a-8512-4f73-852d-60865a3df8df_1.txt embyserver (2).txt
nojaha 4 Posted June 16, 2025 Author Posted June 16, 2025 Last I checked, it still didn't work. So for now I've opted to disable hardware decoding for VC-1, and instead rely on software decoding, which seems to be working alright However, I have since then also gone through the process of manually transcoding all my VC-1 files to H.264. It is therefore technically not a problem anymore, since I don't have anymore VC-1 files I've since then also upgraded to version 6.12.15 of Unraid, but haven't tried it with that version, since I had already transcoded all the VC-1 files at that time. Kernel version is 6.1.126 for this version of Unraid. Would love not to have to transcode these files manually, but seeing as it is such an inefficient codec anyway, and having to deal with the hassle of it, I will be transcoding any VC-1 files immediately when I'm done ripping. 1
Luke 42243 Posted June 17, 2025 Posted June 17, 2025 OK we will also have an updated ffmpeg build on the server beta channel in the near future, just FYI.
