scottymeuk 3 Posted March 21, 2025 Posted March 21, 2025 (edited) 43 minutes ago, Luke said: Yes it has. When would that be released? Edited March 21, 2025 by scottymeuk 1
giovannimasi 0 Posted September 20, 2025 Posted September 20, 2025 I experienced the same issue with Riven, since the Trakt API blocks requests from certain servers and locations. I was able to solve it in Riven thanks to a developer who added support for using a proxy specifically for Trakt API requests. A possible solution in Emby could be to configure a proxy at the network level, but it would be even better if the plugin maintainers could add an option to define a proxy URL used only for Trakt API calls.
Luke 42255 Posted September 23, 2025 Posted September 23, 2025 On 9/20/2025 at 9:24 AM, giovannimasi said: I experienced the same issue with Riven, since the Trakt API blocks requests from certain servers and locations. I was able to solve it in Riven thanks to a developer who added support for using a proxy specifically for Trakt API requests. A possible solution in Emby could be to configure a proxy at the network level, but it would be even better if the plugin maintainers could add an option to define a proxy URL used only for Trakt API calls. Proxy options are always a possibility, yes.
