Laovn 3 Posted March 12, 2025 Posted March 12, 2025 Hello, Every time I start Emby app it defaults to 100% volume. This started happening after I switched to the Microsoft store Emby app (Version:2.219.2.0) instead of Emby Theater (3.0.20). It is highly annoying having to reduce the volume every time I start the app. For this reason alone I'd rather switch back. But I can't find the old non MS installer. Is there any way to fix this? Or at least force it to say 50% volume on startup instead of 100%? Name:Emby Windows (Microsoft store) Version:2.219.2.0
Solution Luke 42233 Posted March 12, 2025 Solution Posted March 12, 2025 Hi, please follow along here: Thanks. 1
Laovn 3 Posted March 12, 2025 Author Posted March 12, 2025 Thanks. Following the thread and hoping for a solution. As a side note what happened to the old emby theater app? Windows store app replaced it?
Luke 42233 Posted March 12, 2025 Posted March 12, 2025 It replaced it yes. It's still on github if you really want it. https://github.com/MediaBrowser/emby-theater-windows/releases
Chillout 111 Posted March 15, 2025 Posted March 15, 2025 On 3/12/2025 at 12:58 PM, Laovn said: Every time I start Emby app it defaults to 100% volume. Same thing happens to me. I ended up reducing my system volume incase I forget to adjust the app volume it doesnt scare the dog. Also, if I turn off my TV while the app is still running, when I turn the TV back on there is no sound in the app. I need to close and reopen the app to get the volume to work again.
softworkz 5133 Posted March 15, 2025 Posted March 15, 2025 13 minutes ago, Chillout said: Also, if I turn off my TV while the app is still running, when I turn the TV back on there is no sound in the app. I need to close and reopen the app to get the volume to work again What happens when you select the TV output explicitly for audio output and/or enable exclusive audio mode? (you might need to enable exclusive mode for the HDMI/TV output)
Chillout 111 Posted March 15, 2025 Posted March 15, 2025 9 hours ago, softworkz said: What happens when you select the TV output explicitly for audio output and/or enable exclusive audio mode? That fixed it, thanks! I feel silly for not trying it sooner but the warning about losing sound in other programs dissuaded me from trying. But sound in my other apps still works. 1
