JuJuJurassic 49 Posted March 10, 2025 Posted March 10, 2025 (edited) Running Ubuntu 20.04.6 I've added a couple of old SSDs, I'm copying over content and while doing so thought I'd do a library scan. but the new content isn't being seen I got "2025-03-10 20:11:56.485 Error LibraryMonitor: Error in Directory watcher for: /data/sandisk3/temptv *** Error Report *** Version: 4.8.10.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-208-generic (buildd@lcy02-amd64-101) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.2)) #228-Ubuntu SMP Fri Feb 7 19:41:33 UTC 20 Framework: .NET 6.0.31 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 16 Data path: /var/lib/emby Application path: /opt/emby-server/system System.IO.IOException: System.IO.IOException: The configured user limit (24576) on the number of inotify watches has been reached, or the operating system failed to allocate a required resource. Source: TargetSite: No Stack Trace Available 2025-03-10 20:11:56.485 Info LibraryMonitor: Stopping directory watching for path /data/sandisk3/temptv 2025-03-10 20:11:56.485 Info LibraryMonitor: Watching directory with new FileSystemWatcher for /data/sandisk3/temptv for item 26093364 2025-03-10 20:11:56.970 Info FfmpegManager: ProcessRun 'CreateTitleFingerprint' Process exited with code 0 - Succeeded" I checked the inodes, they seem ok; root@emby:/data/sandisk4# df --inodes /data/sandisk3 Filesystem Inodes IUsed IFree IUse% Mounted on /dev/sda1 29310976 1078 29309898 1% /data/sandisk3 root@emby:/data/sandisk4# df --inodes /data/sandisk4 Filesystem Inodes IUsed IFree IUse% Mounted on /dev/sde1 29310976 351 29310625 1% /data/sandisk4 root@emby:/data/sandisk4# df --inodes /data/sandisk2 Filesystem Inodes IUsed IFree IUse% Mounted on /dev/sdb1 29310976 641 29310335 1% /data/sandisk2 root@emby:/data/sandisk4# df --inodes /data/sandisk1 Filesystem Inodes IUsed IFree IUse% Mounted on /dev/sdf1 29310976 16336 29294640 1% /data/sandisk1 root@emby:/data/sandisk4# the content on sandisk1 and sandisk2 is fine and seen by emby, but not sandisk 3 or sandisk4 Any suggestions? Thanks embyserver(3).txt Edited March 10, 2025 by JuJuJurassic adding files
Luke 42178 Posted March 10, 2025 Posted March 10, 2025 Hi there, please attach the complete emby server log file. thanks.
Luke 42178 Posted March 10, 2025 Posted March 10, 2025 It seems like you added and removed it several times and now you just need to run a full scan of all libraries and allow that to finish.
Solution JuJuJurassic 49 Posted March 10, 2025 Author Solution Posted March 10, 2025 Hi Luke, I tried that several times, but it.dodnt work, ok in the end I kicked.off my family. Not a popular move, and rebooted. The emby process.was.hung, it.wouldnt go.past.it. after waiting 30 minutes I powered ioff the server and.its.come.up.happy with the libraries updated. 1
