T_Tronix 17 Posted March 10, 2025 Posted March 10, 2025 I've been running Emby within Proxmox for several years now and it's been running flawlesly until now. I've noticed some of my cover images are no loading and the plugins seem to be failing. The plugin catalogue does not load as well. Also when rebooting the Emby server I've noticed this:
Luke 42243 Posted March 10, 2025 Posted March 10, 2025 Hi there, can you please provide a specific example? How to Report a Problem Thanks.
T_Tronix 17 Posted March 10, 2025 Author Posted March 10, 2025 Here is a sample of the image cover not loading on one of my content (several have that same issue): Plugin catalog never loads: I've attached my last log to this message: embyserver.txt
kjhedges 67 Posted March 10, 2025 Posted March 10, 2025 No space left on device : '/Cache/cache/coverart/4.1.28.0/MetroCaseCDs' Saw this in logs
T_Tronix 17 Posted March 10, 2025 Author Posted March 10, 2025 I had to delete the cache folder and restart my Emby. Tom several attempts to revive everything and get things back to normal. 1
T_Tronix 17 Posted March 19, 2025 Author Posted March 19, 2025 Ok so I keep getting this error: System.IO.IOException: System.IO.IOException: No space left on device : '/Cache/cache/httpclient/0fb243ded9649ae6d18059c674a4ae00' How can I increase or maintain the cache so I stop seeing this message? It affects the images since new ones don't get loaded.
Neminem 1623 Posted March 19, 2025 Posted March 19, 2025 How much free space is there in that drive ?
T_Tronix 17 Posted March 19, 2025 Author Posted March 19, 2025 (edited) There's a little less than 1TB. Edited March 19, 2025 by T_Tronix
Luke 42243 Posted March 20, 2025 Posted March 20, 2025 If you remove the cover art plugin and restart the server, how do things compare?
