calirat 0 Posted March 9, 2025 Posted March 9, 2025 Hi, wasn't sure where to put this exactly since it covers multiple platforms. I've been doing a lot of configuring and testing lately to try and get the best streaming capability on a remote network away from my Synology NAS. When connecting locally (not remotely,) my results are decent on all platforms, with Emby Theatre and Kodi working the best, along with Android for phones. The web client fails to load certain files, or streams with stuttering. The Android TV client is pretty good. Where things start to get really iffy is streaming remotely. Every client I've tried will only be able to stream smaller 1080p files, except Emby Theatre (perhaps Kodi too, didn't test it) and Android for phone. It seems bizarre to me that my phone can perfectly stream large 1080p files on wi-fi, while a TV hooked up to an amazon fire cube, with ethernet plugged in, can't even open it. What gives? I can provide more details and test other options if necessary.
Luke 42239 Posted March 9, 2025 Posted March 9, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
calirat 0 Posted March 9, 2025 Author Posted March 9, 2025 Wondering if someone can help me figure out a solution for streaming remotely on certain platforms. On a certain remote network, I can stream my library perfectly on the desktop Emby Theatre client, and the Android version Emby for mobile. However, streaming with Emby Amazon Fire TV app or Emby Android TV app causes video files to not open at all, or constantly buffer. Considering the TV has a direct ethernet connection, and my phone is just on wi-fi, I don't think it should be streaming better unless something is wrong with the app itself, or the tv's hardware. Hoping there's a way to get the TV apps to work better, or else I might just have to settle for casting emby theatre on desktop to the TV. Thanks!
calirat 0 Posted March 10, 2025 Author Posted March 10, 2025 Thanks, one detail I got wrong in the previous post was it's actually on Emby for Samsung Smart TV, not Emby for Android TV.
Luke 42239 Posted March 10, 2025 Posted March 10, 2025 4 hours ago, calirat said: Thanks, one detail I got wrong in the previous post was it's actually on Emby for Samsung Smart TV, not Emby for Android TV. Hi, can you please provide the information requested above ?Thanks !
calirat 0 Posted March 10, 2025 Author Posted March 10, 2025 Sorry, I failed at reading. Here's the logs: ffmpeg-transcode-fb84636b-7fa0-4fa5-a0d6-e283d6e6f34a_1.txtembyserver-63876988800.txt In the worst cases, the video file would try to play for about 20 seconds before giving me this error: https://i.imgur.com/A8NzLrn.png Other times, it just wouldn't buffer well enough to be watchable. Some of these files seemed to play if I switched off the image subtitles, however, others of similar filesize would play just fine with them on, and I've found some files that don't play well regardless of what subtitles, so image subtitles can't be the only issue.
calirat 0 Posted March 12, 2025 Author Posted March 12, 2025 bumping this in hopes of a real response, i've continued to have these problems on samsung smart tv and amazon fire tv.
Luke 42239 Posted March 12, 2025 Posted March 12, 2025 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
calirat 0 Posted March 28, 2025 Author Posted March 28, 2025 When I did more testing, it seemed to have significantly better results on the older version of the app, strangely enough, although some files still had trouble.
Luke 42239 Posted March 29, 2025 Posted March 29, 2025 18 hours ago, calirat said: When I did more testing, it seemed to have significantly better results on the older version of the app, strangely enough, although some files still had trouble. @calirat HI, what version number gave better results?
calirat 0 Posted March 29, 2025 Author Posted March 29, 2025 (edited) The log said Emby for Samsung 1.9.0 The better performing app for Amazon said AndroidTv 2.1.26a Edited March 29, 2025 by calirat
Luke 42239 Posted March 29, 2025 Posted March 29, 2025 10 hours ago, calirat said: The log said Emby for Samsung 1.9.0 The better performing app for Amazon said AndroidTv 2.1.26a OK those are two completely different platforms. One is the Samsung app, the other is Android, so it's not a question of older or newer versions. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
