Halliphax 4 Posted November 17, 2025 Posted November 17, 2025 I have subscribed to three collections (IMDB and Trending Shows and Movies). However, the last sync that was performed has wiped the pictures I had for my Library, LiveTV and Collections (the pictures were the default generated Emby ones). How can I reverse this and can I stop it from happening in future?
GrimEvil 73 Posted November 18, 2025 Posted November 18, 2025 (edited) 20 hours ago, Halliphax said: I have subscribed to three collections (IMDB and Trending Shows and Movies). However, the last sync that was performed has wiped the pictures I had for my Library, LiveTV and Collections (the pictures were the default generated Emby ones). How can I reverse this and can I stop it from happening in future? I think the only way to reverse it to upload your own images and set them from acdbtv? Edited November 18, 2025 by GrimEvil
Amything 131 Posted November 18, 2025 Author Posted November 18, 2025 20 hours ago, Halliphax said: I have subscribed to three collections (IMDB and Trending Shows and Movies). However, the last sync that was performed has wiped the pictures I had for my Library, LiveTV and Collections (the pictures were the default generated Emby ones). How can I reverse this and can I stop it from happening in future? It's not intended for Library images to be touched unless you set new ones on ACdb.tv. I'll look into why this happened, sorry about the bother. 1
sh0rty 728 Posted November 21, 2025 Posted November 21, 2025 Fun fact: I still use the Docker version and also some collection images were wiped. I pull the images from github. First I thought it was because of the Cloudflare outage.
Amything 131 Posted November 23, 2025 Author Posted November 23, 2025 On 22/11/2025 at 02:08, sh0rty said: Fun fact: I still use the Docker version and also some collection images were wiped. I pull the images from github. First I thought it was because of the Cloudflare outage. I've noticed a couple of people ask about disappearing collection images on the forum. Also have a user on Discord with the issue. I don't know what is going on but I'm pretty sure it's not related to the script/plugin. 1
GrimReaper 4907 Posted November 23, 2025 Posted November 23, 2025 4 minutes ago, Amything said: I've noticed a couple of people ask about disappearing collection images on the forum. Also have a user on Discord with the issue. I don't know what is going on but I'm pretty sure it's not related to the script/plugin. It might (but not necessarily) be related to a recently introduced change in as how the collection folders are saved within \metadata folder. Few related topics here, here and here. 1 1
Halliphax 4 Posted November 23, 2025 Posted November 23, 2025 1 hour ago, Amything said: I've noticed a couple of people ask about disappearing collection images on the forum. Also have a user on Discord with the issue. I don't know what is going on but I'm pretty sure it's not related to the script/plugin. Does this mean the activity log showing the changes is erroneous? My first thought was that the plugin was at fault due to this.
Amything 131 Posted November 23, 2025 Author Posted November 23, 2025 19 minutes ago, Halliphax said: Does this mean the activity log showing the changes is erroneous? My first thought was that the plugin was at fault due to this. Your library images issue is not related to these threads, it’s a plugin issue. I’m away from my main computer in the next few days, but I will make an update soon. 2
minitskarn1 0 Posted November 27, 2025 Posted November 27, 2025 bonjour, j'ai un soucis avec votre plugin. j'ai actuellement un serveur EMBY sur un PC windows qui passe par un VPS et depuis ce pc je n'ai pas la possibilité d'accéder a votre serveur de synchronisation. y a t il moyen de m'aider ou alors c'est impossible depuis un VPS ? Merci d'avance pour votre aide
Amything 131 Posted November 29, 2025 Author Posted November 29, 2025 On 27/11/2025 at 13:13, minitskarn1 said: bonjour, j'ai un soucis avec votre plugin. j'ai actuellement un serveur EMBY sur un PC windows qui passe par un VPS et depuis ce pc je n'ai pas la possibilité d'accéder a votre serveur de synchronisation. y a t il moyen de m'aider ou alors c'est impossible depuis un VPS ? Merci d'avance pour votre aide Hi, it's probably a firewall issue. Using a VPS is not a problem by itself, should work fine once the connection is allowed. It's connecting with HTTPS to https://acdb.tv and https://api.acdb.tv/api
Dibbes 515 Posted December 3, 2025 Posted December 3, 2025 (edited) This is really very good, thank you @Amything! I now got this running as source collections for @pünktchen Virtual TV plugin and this is giving me very decent feeds for some new virtual channels! I have a question: is it possible to replace a few sections of the Home Screen with input from this plugin? That would be awesome Edited December 4, 2025 by Dibbes
rbjtech 5345 Posted December 4, 2025 Posted December 4, 2025 (edited) 10 hours ago, Dibbes said: I have a question: is it possible to replace a few sections of the Home Screen with input from this plugin? That would be awesome It was hinted that 'smart views' would be released in 4.9.x - as the next priority - so I'm really hoping this is true from @Luke https://emby.media/community/index.php?/topic/142975-post-49180-roadmap/#findComment-1474402 The ability to view collections or playlists as dynamic virtual libraries on the landing page for all the apps will greatly enhance plugins such as this, assuming (essential imo) there is an API hook into the core feature.. Also - the latest beta has a fix that hints the virtual libraries may exist as 'channels' .. Quote Fix latest section not showing items for some channel plugins Edited December 4, 2025 by rbjtech 2 1
Dibbes 515 Posted December 4, 2025 Posted December 4, 2025 11 hours ago, rbjtech said: It was hinted that 'smart views' would be released in 4.9.x - as the next priority - so I'm really hoping this is true from @Luke Also - the latest beta has a fix that hints the virtual libraries may exist as 'channels' .. @rbjtech@Luke That'd be awesome! @AmythingHave you planned something similar for music/books, by the way? 1
Amything 131 Posted December 4, 2025 Author Posted December 4, 2025 2 hours ago, Dibbes said: Have you planned something similar for music/books, by the way? I pray for smart views every night Have never thought about music/books to be honest. My todo list is pretty packed so It would not be in the near future at least, but sounds interesting. 1 1
Kyouma 11 Posted December 5, 2025 Posted December 5, 2025 Hello, I'm looking for a way to create dynamic collections for anime season's. My goal is to have 3 collections for the last, current and upcoming season (would be Summer 2025, Fall 2025 and Winter 2026 at the moment) which updates automatically. Would that be possible with this plugin? If yes, how can I achieve that?
Amything 131 Posted December 6, 2025 Author Posted December 6, 2025 17 hours ago, Kyouma said: Hello, I'm looking for a way to create dynamic collections for anime season's. My goal is to have 3 collections for the last, current and upcoming season (would be Summer 2025, Fall 2025 and Winter 2026 at the moment) which updates automatically. Would that be possible with this plugin? If yes, how can I achieve that? Collections contain MDBLists, so you can head over to https://mdblist.com/ and make a list over there. I don't know anything about Anime tbh, but it's super flexible. You can search for a similar list here https://mdblist.com/toplists/ for example. To see how the filter works and modify it for your needs, you go to Actions and "Create your Show Filter". Then go you "My Lists", check if it's populated, and once it is, go to https://acdb.tv/list_search and search for the list url to create your collection.
Kyouma 11 Posted December 6, 2025 Posted December 6, 2025 Using Anime as a genre and specifying the dates, I can get it to work for new Series, but I could not find a way to add shows with a new Season, unless I make a static list.
Amything 131 Posted December 6, 2025 Author Posted December 6, 2025 (edited) 1 hour ago, Kyouma said: Using Anime as a genre and specifying the dates, I can get it to work for new Series, but I could not find a way to add shows with a new Season, unless I make a static list. I'm not too sure what you mean by new Season. Can see a currently airing list here: https://mdblist.com/lists/preferrednerd/currently-airing-anime You can then also use 2 lists where you exclude one list in another etc. For example use currently airing but exclude new Series. The MDBList Discord is super helpful, could try getting some help there if it's not what you are after. Edited December 6, 2025 by Amything
Kyouma 11 Posted December 6, 2025 Posted December 6, 2025 25 minutes ago, Amything said: I'm not too sure what you mean by new Season. So when i Filter by air dates, i get this: https://imgur.com/6wSl7tO But it does not include Shows with a new Season like here: https://imgur.com/uGxYTDA Dan Da Dan shows up with it's 2nd Season, but i can't get it to show up in MDBList. Just so you know what i mean. If I could get it to show up, that would satisfy my needs. 31 minutes ago, Amything said: You can then also use 2 lists where you exclude one list in another etc. For example use currently airing but exclude new Series. The MDBList Discord is super helpful, could try getting some help there if it's not what you are after. Thanks, I will try my luck there.
Dave_S 0 Posted December 8, 2025 Posted December 8, 2025 (edited) I have a strange request. I'm trying to create a collection in emby of my own movies in random order. I'd like it to be updated automatically on a periodic basis. This is a work around for a shortcoming of Infuse when using Emby as the source. Infuse doesn't let you sort randomly like using plex as a source. Plex has its own shortcomings. One solution is to create a randomized collection of my own movies in Emby. That collection would show up in Infuse. This is probably WAY more work that it's worth but thought I would ask. I have a list of my movies in MDBList if that makes a difference. Any ideas or feedback is appreciated. Edited December 8, 2025 by Dave_S
Amything 131 Posted December 8, 2025 Author Posted December 8, 2025 (edited) 7 hours ago, Dave_S said: I have a strange request. I'm trying to create a collection in emby of my own movies in random order. I'd like it to be updated automatically on a periodic basis. This is a work around for a shortcoming of Infuse when using Emby as the source. Infuse doesn't let you sort randomly like using plex as a source. Plex has its own shortcomings. One solution is to create a randomized collection of my own movies in Emby. That collection would show up in Infuse. This is probably WAY more work that it's worth but thought I would ask. I have a list of my movies in MDBList if that makes a difference. Any ideas or feedback is appreciated. You can randomize the list on MDBList, however there is no way to retain that order in Emby unless I would add some feature that modifies the sort name according to the list order. But it's not really a viable solution since the movie can be in multiple collections and it will just be chaotic. I'm assuming this is for content discovery? One idea is to randomize the order on MDBList and put Limit items to 10 or whatever. Then you have a collection of 10 random movies that is refreshed every 24 hours (maybe 12, can't remember). Could do this for different categories, like these type of collections https://acdb.tv/collection/comedy-picks-of-the-day You can make a list, that include your big list, then filter to category, randomize the order, limit to x items. Edited December 8, 2025 by Amything
fabien_m2002 8 Posted December 11, 2025 Posted December 11, 2025 Hello is this plugin limited only to 3 collections for free users? How to discover new contents from external lists/collections (MDBlists/Trakt, ...) outside our media library? Thanks
Neminem 1625 Posted December 11, 2025 Posted December 11, 2025 12 minutes ago, fabien_m2002 said: is this plugin limited only to 3 collections for free users? Read first post. On 3/5/2025 at 8:15 PM, Amything said: Cost Free: 3 collections if you click "Join for Free" on the Patreon. $2/month: Add up to 20 collections, include any MDBList, and fully customize your collections. See more on the Patreon page.
fabien_m2002 8 Posted December 11, 2025 Posted December 11, 2025 (edited) 33 minutes ago, Neminem said: Read first post. Ok thanks. The collections display only the matched media from library? Edited December 11, 2025 by fabien_m2002
Amything 131 Posted December 11, 2025 Author Posted December 11, 2025 (edited) 2 hours ago, fabien_m2002 said: Hello is this plugin limited only to 3 collections for free users? How to discover new contents from external lists/collections (MDBlists/Trakt, ...) outside our media library? Yes, 3 collections for free, then there is a 20 collections tier for $2 or about 2 Euro. To discover media outside of your library, you can add a collection, sync it to your library and then on the website you will be able to see which items you are missing. I want to add trailers to collections so that if you’re missing items, you can at least watch the trailers for the ones you don’t have. The problem is there’s no clean way to serve trailers that I know of. I haven’t found any API I can tap into, so the only options are workarounds, and none of them feel right. Edited December 11, 2025 by Amything 2
