Luke 42243 Posted March 6, 2025 Posted March 6, 2025 1 minute ago, Meathor said: @Happy2Play Thanks... this Setting was the solution... Prob... Some hint are usefull in the Settings? Why did you configure the global bitrate limit in the first place?
Happy2Play 9812 Posted March 6, 2025 Posted March 6, 2025 1 minute ago, Meathor said: @Happy2Play Thanks... this Setting was the solution... Prob... Some hint are usefull in the Settings? Yes per the log snippets I posted. server 2025-03-04 19:34:58.632 Info App: RemoteClientBitrateLimit: 2000000, RemoteIp: host1, IsInLocalNetwork: False 2025-03-04 19:34:58.632 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 4430119, max bitrate: 2000000 ffmpeg Global Remote Bitrate Limit: 2,000,000 bps But yes there is still confusion around why this value scales such low resolution.
Meathor 0 Posted March 6, 2025 Author Posted March 6, 2025 (edited) at Luke I was not aware that setting (google) Edited March 6, 2025 by Meathor
Luke 42243 Posted March 6, 2025 Posted March 6, 2025 1 minute ago, Meathor said: I was not aware that setting (google) Are you sure? Because you did set it to 2 mbps.
Meathor 0 Posted March 6, 2025 Author Posted March 6, 2025 (edited) 4 minutes ago, Luke said: Are you sure? Because you did set it to 2 mbps. Yes, but when i am set 12000 kb the issue are gone... 40000 kn and 4k are always good (Image are 4k) Edited March 6, 2025 by Meathor
Happy2Play 9812 Posted March 6, 2025 Posted March 6, 2025 But the question still exists on why you limited your remote connection internet streaming limit in the first place? But sounds like you just need to leave it blank unless you have a limited internet upload speed that may need to be shared by multiple remote user connections. Also as a "Registered for MBSupporter" I would reenable Hardware acceleration also. >>>>>> Hardware Encoders for h264 [ ] VAAPI IvyBridge GT2 HD Graphics 4000 - H.264 (AVC)
