How to name series not showing on IMDB or TVDB Andrew Wommack
Go to solution Solved by zeilercd,
Hello - my husband Loves Andrew Wommack: Gospel Truth. The show has an IMDB link - but no "episode guide/list" and tvdb has nothing on him/this show/series :(
https://www.imdb.com/title/tt4884732/
We used to have cable (and emby) and he could find it easily. Now Over The Air and streaming options only - I have no issue navigating the app to find the show (he has a new gtn app) but it's too cumbersome for my husband. Over the air plays at wrong times of day for him to be able to watch it.
I discovered that you can download the episodes for free from
https://www.awmi.net/video/tv-archives/?yn=2025&wn=8&dn=1&
However, you notice - each week is listed a show name, and then by episode by day.
I Have created a folder for the show "Andrew Wommack Gospel Truth"
In that i put a folder "2025" for this year (season)
In that i put folders "week 1" "week 2" etc
and in those the files are named that weeks show name e01, e02 etc
many shows if you check the site carry over to a 2nd or 3rd week w same title
So for example both week 4 and week 5 have shows called "welcome to your place called there e01" and then ... e02 and week 5 is same names e06, e07
these showed up nicely in Emby
"S2025:E1 - Welcome to Your Place Called There e01" shows up under the series and i can hit play and play those 10 in order
However, it does not see the files in week 6 (a single week under one name)
Or week 7 and 8 (again 2 weeks, 10 episodes, with another name).
Can you help me figure out how to get this to show up?
I really want the file names/show names to show in the titles so he can go - i want to watch This Teaching or That subject and find the right ones
or just jump by week to find what he wants
I'm so confused LOL
I really dont want to lose the "subject matter titles" if i dont have to
Sure, i could just dump them in as wommack s2025e1 and so forth... but then there's no "description"...
Would i have to go in and "name each eposide" perhaps? is that doable? (some kind of right click edit meta data)?
please advise - going a bit nuts here LOLOL
And Thanks!
  • Solution
Well after I spent an hr searching for resolve to this issue
And not able to find it and posted this topic.
I figured it out thanks to your link here
https://emby.media/support/articles/TV-Naming.html
The Section under "TV Extras" gave me an idea..
So i copied all files to the root 2025
named them s25e01 FIRST WEEKS SHOW NAME 1, s25e02 FIRST WEEKS SHOW NAME 2.... s25e11 THIRD WEEKS SHOW NAME 1...
It shows up now as showing each episode in order, AND shows the "subject name" though it's the same for a week here and 2 weeks there, then changes - with the numbers, keeps them not only in the order they were shown, but also in order by "subject" easy to find if you scroll through the list!!!!
You guys are amazing! lol
Only wish my many searchembywommack.thumb.png.1a38336782feebf554f6e191cd4574a2.pnges prior to posting had given me this page to see as a first result not 50th try LOL
now, how do i mark this solved/resolved?/closed? remove post?? lol
Thanks again!
Hi, thanks for following up !
  • Thanks 1
