Kurt13 11 Posted February 27, 2025 Posted February 27, 2025 (edited) Hi, I have a (music) dvd ripped on my Emby but there's no sound when i try to play it with "Emby for Android" on my smartphone or Android TV box, nor with "Emby for Android TV" on my box. On Emby web or "Emby Theatre" on W11, the sound plays fine. Can anyone tell me why? Emby server version: 4.8.10.0 Apps are fully updated (log and screenshot are from the Emby app on my smartphone. I also attached the information provided from MediaInfo when i download the file to my pc, in case it helps) emby_android_1740685424939.txt Edited February 27, 2025 by Kurt13 Forgot to mention the Emby server version
Luke 42242 Posted February 27, 2025 Posted February 27, 2025 Hi, what version of Emby for android did you try?
Luke 42242 Posted February 27, 2025 Posted February 27, 2025 OK can you try sideloading the latest build and see how that compares?
Kurt13 11 Posted February 27, 2025 Author Posted February 27, 2025 1 minute ago, Luke said: OK can you try sideloading the latest build and see how that compares? Ok, i'll try it now
Kurt13 11 Posted February 27, 2025 Author Posted February 27, 2025 Unfortunately didn't work. Do you see anything related to a possible issue with the video file on the log file? It's strange that it works on Emby Web and Emby Theatre. Also, since i updated through the apk you sent, when new releases are availabe on the Play Store, will the app receive it, or i have to reinstall the version from there? Thanks
seanbuff 1356 Posted February 28, 2025 Posted February 28, 2025 4 hours ago, Kurt13 said: Also, since i updated through the apk you sent, when new releases are availabe on the Play Store, will the app receive it, or i have to reinstall the version from there? you will continue to receive the latest updates from the Play Store. 1
Luke 42242 Posted February 28, 2025 Posted February 28, 2025 8 hours ago, Kurt13 said: Unfortunately didn't work. Do you see anything related to a possible issue with the video file on the log file? It's strange that it works on Emby Web and Emby Theatre. Also, since i updated through the apk you sent, when new releases are availabe on the Play Store, will the app receive it, or i have to reinstall the version from there? Thanks Hi, what exactly happened? What version number was it?
Kurt13 11 Posted February 28, 2025 Author Posted February 28, 2025 (edited) 8 hours ago, Luke said: Hi, what exactly happened? What version number was it? Hi, 3.4.42 Nothing "new" happened. The video still has no sound Edited February 28, 2025 by Kurt13
Kurt13 11 Posted March 2, 2025 Author Posted March 2, 2025 @LukeDid you found something in the logs that explain my issue? Thanks
Kurt13 11 Posted March 7, 2025 Author Posted March 7, 2025 (edited) Samsung Galaxy s23 Ultra, and Xiaomi Mi Box S 2nd gen connected to a Samsung HW-Q990D soundbar. Edited March 7, 2025 by Kurt13
Kurt13 11 Posted March 28, 2025 Author Posted March 28, 2025 Hi @Luke It's been a month since I opened this thread. Do you have any news for me? Thanks
Luke 42242 Posted March 29, 2025 Posted March 29, 2025 Hi, is the audio muxed into the container with an audio delay?
Kurt13 11 Posted March 29, 2025 Author Posted March 29, 2025 (edited) 42 minutes ago, Luke said: Hi, is the audio muxed into the container with an audio delay? I'm not sure how to answer to that. For what I know, sound delay is when the sound is out of sync with the video, which isn't the case. The sound simply doesn't work. It's simply strange (at least to me) that the sound doesn't work on Emby for Android installed on a Samsung Galaxy S23 Ultra, nor with both Android TV apps on a Xiaomi Mi Box S 2nd gen. But on Emby Web (even accessing through my phone) or "Emby Theatre" on W11, the sound plays fine. Edited March 29, 2025 by Kurt13
Kurt13 11 Posted May 11, 2025 Author Posted May 11, 2025 23 minutes ago, Luke said: Hi, are you still having an issue with this? Hi, It's been more than 2 months so I don't know. I have to check it again but don't know if it's better to do it when I'm back home (in 5 days). Also, since there wasn't any solution, I remember that at the time I ripped 2 additional files (from the same original one) to test but can't remember what I did on order to see if it would make any difference. 1
