Asazen 8 Posted February 26, 2025 Posted February 26, 2025 It would be good to add the option that the displacement through the library and the rest of the menu has a small sound like Google TV.
Asazen 8 Posted February 27, 2025 Author Posted February 27, 2025 It would be nice to include it in all of them, but I would especially like it for the Android/Google TV version.
ebr 16337 Posted February 27, 2025 Posted February 27, 2025 3 minutes ago, Asazen said: It would be nice to include it in all of them Well, this only makes sense in a 10' interface with a remote control (TV), right?
Asazen 8 Posted February 27, 2025 Author Posted February 27, 2025 4 minutes ago, ebr said: Well, this only makes sense in a 10' interface with a remote control (TV), right? Yes, correct, the ideal are versions in which it is used with remote control.
Asazen 8 Posted February 27, 2025 Author Posted February 27, 2025 Actually, it would be in all except the Android Mobile version, which is touch-sensitive. The others all use a remote control, even the web version if you connect a remote control to a PC.
