Tophicles 40 Posted February 25, 2025 Posted February 25, 2025 Hi gang! I'm often having to refresh/replace images and it would be amazing to get a "shortcut" button like the "played" and "fave" ones. Clicking it would just initiate a force refresh of the images in that series / object, rather than right-click, scroll down, replace metadata, check replace images. 1
GrimReaper 4898 Posted February 25, 2025 Posted February 25, 2025 30 minutes ago, Neminem said: @GrimReaperThis can't be FR, more a support call Hm, I reckon it's actually both. FR: 4 hours ago, Tophicles said: I'm often having to refresh/replace images and it would be amazing to get a "shortcut" button like the "played" and "fave" ones. Support: 4 hours ago, Tophicles said: I should say that even when this is globally applied to the library, it often misses hundreds that the manual, per object request completes successfully. Will split topics.
Tophicles 40 Posted February 25, 2025 Author Posted February 25, 2025 2 minutes ago, GrimReaper said: Hm, I reckon it's actually both. FR: Support: Will split topics. Yeah I really wasn't asking for support on the scanning, more a feature to enable faster access to "Replace All Images" per series.
Happy2Play 9812 Posted February 25, 2025 Posted February 25, 2025 3 minutes ago, Tophicles said: Yeah I really wasn't asking for support on the scanning, more a feature to enable faster access to "Replace All Images" per series. Not sure I follow as it is easy, either manually select the images you want or run the task against the Series but if your server is busy you will/could see issues.
Tophicles 40 Posted February 25, 2025 Author Posted February 25, 2025 1 minute ago, Happy2Play said: Not sure I follow as it is easy, either manually select the images you want or run the task against the Series but if your server is busy you will/could see issues. It's easy, except the option to replace images is buried in the "Replace All Metadata" menu. So, instead of a one-click on a small icon to replace all images, I have to right click, choose replace all metadata, then check off Replace All images then click ok. I recognize that on a one off it's negligible but on a larger scale it's a massive time saver.
sh0rty 727 Posted February 25, 2025 Posted February 25, 2025 (edited) 30 minutes ago, Tophicles said: It's easy, except the option to replace images is buried in the "Replace All Metadata" menu. So, instead of a one-click on a small icon to replace all images, I have to right click, choose replace all metadata, then check off Replace All images then click ok. I recognize that on a one off it's negligible but on a larger scale it's a massive time saver. And why not multi-select the movies on "a larger scale" and do your steps one time for all of them? Edited February 25, 2025 by sh0rty
Tophicles 40 Posted February 25, 2025 Author Posted February 25, 2025 Just now, sh0rty said: And why not multi-select the movies on "a larger scale" and do your steps one time for all of them? I'm scrolling through the list and manually doing each series. If I multi-select series, can I see there which are missing the cover art?
Tophicles 40 Posted February 25, 2025 Author Posted February 25, 2025 2 minutes ago, sh0rty said: And why not multi-select the movies on "a larger scale" and do your steps one time for all of them? Ahh, I see how that works now... yes that is significantly faster. 1
sh0rty 727 Posted February 25, 2025 Posted February 25, 2025 In my opinion, there is already so much icon nitty gritty on the posters plus there are 2 options in detail screen to change posters (near the logoart + the detail screen menu). Dunno, a third option would be a bit overkill, specially since having the multi select option. Just my 2c. But that doesn't count.
Tophicles 40 Posted February 25, 2025 Author Posted February 25, 2025 Just now, sh0rty said: In my opinion, there is already so much icon nitty gritty on the posters plus there are 2 options in detail screen to change posters (near the logoart + the detail screen menu). Dunno, a third option would be a bit overkill, specially since having the multi select option. Just my 2c. But that doesn't count. Of course it counts - besides I learned something new today, so danke. I still think it would be helpful to have a one-click "replace all metadata and images" on the poster hover (you don't see it unless you hover anyway) but that's MY two cents
