smokkan 0 Posted February 23, 2025 Posted February 23, 2025 I have a Samsung S95D and use Emby for Samsung. When I try to watch a movie with many subtitles embedded in the MKV file, let's say 20-30 different subtitles, only the first 10-15 seem to work.If I play the same file on a computer, phone, or Emby for Android on another TV, all subtitles work as expected. This issue only occurs on Emby for Samsung. However, if I extract a subtitle that doesn’t work and load it as an external file, it works as expected. What could be causing this problem when playing movies with many embedded subtitles on my Samsung TV?
smokkan 0 Posted February 23, 2025 Author Posted February 23, 2025 I have Emby 1.9.0 installed, and there is no newer version available in the Samsung Store on my TV.
Luke 42239 Posted February 25, 2025 Posted February 25, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
SamES 1084 Posted March 9, 2025 Posted March 9, 2025 On 24/02/2025 at 04:52, smokkan said: I have a Samsung S95D and use Emby for Samsung. When I try to watch a movie with many subtitles embedded in the MKV file, let's say 20-30 different subtitles, only the first This is a fairly well discussed issue on Samsung TV's. Over about 20 subtitle tracks the TV will start to have issues. It is a limitation of the TV and not something that we can resolve in the app. It's best to try and remove unused subtitle tracks. You can investigate if you want to see how it works and if it will help you, otherwise you can remove them manually. 1
