Hoochee 12 Posted February 22, 2025 Posted February 22, 2025 Is there anything about 4.9.0.38 and maybe the previous version that would cause volume issues? Specifically, I must turn up the volume on my AVR an additional 8-13 db from what I did prior to the latest beta version, possibly the prior version. Dialogue is lower volume and somewhat muffled. I verified the audio settings on the Roku Ultra have not changed although I turned off Leveling to compensate for the changes with media played back on emby. No noticeable changes/issues with volume in other streaming apps (Pluto, Max, tubi,) or live TV. Videos in .mkv and .mp4 are both affected. I don’t have .avi files. .264 and .265. Audio format varies - AAC, Dolby (various). Let me know if I’ve missed relevant data points, but maybe it’s a definite, “can’t be emby” so no other info is needed. TIA
Hoochee 12 Posted February 22, 2025 Author Posted February 22, 2025 (edited) Direct or transcoding - same issue. there’s a span of about 7 db where there’s no discernible change in volume. 23 and below I can hear the volume fade with with each press for down volume. 24-30 no discernible change. 30 and above there’s a discernible change. I had chalked it up to my tinnitus being worse but my kid commented on it this evening and I hadn’t mentioned the issue to him. Edited February 22, 2025 by Hoochee
visproduction 335 Posted February 22, 2025 Posted February 22, 2025 (edited) Wild guess on code: (Version 4.9.0.38 beta) file date Feb 7, 2025 1:50PM AppData\Roaming\Emby-Server\system\dashboard-ui\modules\htmlaudioplayer\plugin.js function fade(instance,elem,startingVolume){ instance._isFadingOut=!0; var newVolume=Math.max(0,startingVolume-.15); return console.log("fading volume to "+newVolume),(elem.volume=newVolume)<=0?(instance._isFadingOut=!1,Promise.resolve()):new Promise(function(resolve,reject){ cancelFadeTimeout(),fadeTimeout=setTimeout(function(){ fade(instance,elem,newVolume).then(resolve,reject) } ,100)} )} Does this newVolumn=Math.max(0,startingVolume-.15) make the NewVolume change by 0.15 which changes 100 to 99.85, 99.70, 99.55, 99.40, 99.25, 99.10, 98.95. So the html player would not notice any volumn change for 7 adjustments. Where is the newVolumn saved? Does it become the new startingVolumn? Should it instead be adjusted in full steps of 1 to 5 instead of the -0.15? I am sure I am missing something. Just a guess... Edited February 22, 2025 by visproduction
Luke 42239 Posted February 22, 2025 Posted February 22, 2025 and this is specific to the WMC UI (Beta) ?
Hoochee 12 Posted February 22, 2025 Author Posted February 22, 2025 Damnit. Sorry - didn’t see that I ended up in the WMC forum. Watching on a Roku Ultra, emby server is on a Win 11 machine. I haven’t checked if there’s an issue on web or iPhone. Will this evening. That should help ID it as a emby issue, or not. 1
