reduxmanual 0 Posted February 21, 2025 Posted February 21, 2025 (edited) I have seen that Infuse generates an emby connect pin is there an API endpoint to generate the pin on this page: https://emby.media/pin.html Edited February 21, 2025 by reduxmanual
Luke 43505 Posted February 23, 2025 Posted February 23, 2025 HI, we don't have this documented right now. Until that happens, what you'll need to do is test with the hosted web app: http://app.emby.media and monitor the network requests using the browser debugger. So Sign in once, switch the display mode to TV, then sign out. When you go to sign back in again, then you'll get the pin process in TV display mode. Then you can monitor the network requests using the browser debugger. Please let us know if this helps. Thanks.
