Justin757 8 Posted February 21, 2025 Posted February 21, 2025 My wifi turns off automatically after 11.30pm at night and i manually turn on wifi in the morning. When i check back android server in morning it would have drained more than 50% of the battery from my android tab! Server log is 20MB, same code added below is repeated a number of times! 2025-02-21 00:00:00.051 Info App: Emby Server Version: 4.8.10.0 2025-02-21 00:00:00.052 Info App: Emby Command line: /data/app/~~uLaVOGXDhUR1KmcPZ9Awxg==/com.emby.embyserver-vMc-04RefJaCtGQwjacvVg==/base.apk Operating system: Android 11 (REL) SDK:30 BuildId:RP1A.200720.012 Incremental:T725XXU2DVB2 Patch-Level: 2022-02-01 Framework: Mono 6.12.0 (2020-02/d9a6e8710b3) 4.0.50524.0 OS/Process: Arm64/Arm64 Runtime: mscorlib.dll Processor count: 8 Data path: /storage/emulated/0/Android/data/com.emby.embyserver/files Application path: /data/user/0/com.emby.embyserver Fingerprint: samsung/gts4lvxx/gts4lv:11/RP1A.200720.012/T725XXU2DVB2:user/release-keys Model: SM-T725 - samsung/samsung Hardware: gts4lv/gts4lvxx/qcom/sdm710 SupportedAbis: arm64-v8a, armeabi-v7a, armeabi 2025-02-21 00:00:00.052 Info App: Logs path: /storage/emulated/0/Android/data/com.emby.embyserver/files/logs 2025-02-21 00:00:00.052 Info App: Cache path: /storage/emulated/0/Android/data/com.emby.embyserver/files/cache 2025-02-21 00:00:00.052 Info App: Internal metadata path: /storage/emulated/0/Android/data/com.emby.embyserver/files/metadata 2025-02-21 00:00:00.052 Info App: Transcoding temporary files path: /storage/emulated/0/Android/data/com.emby.embyserver/files/transcoding-temp 2025-02-21 00:00:00.052 Info App: Plugins: Backup & Restore 1.7.0.0 Bluray Folder Support 1.0.2.0 Cinema Intros 1.0.47.0 DLNA 1.4.7.0 Dvd Folder Support 1.0.0.0 Emby Guide Data 1.0.18.0 Fanart.tv 1.0.16.0 Folder Sync 3.2.9.0 M3U TV Tuner 1.0.38.0 MovieDb 1.8.0.0 MusicBrainz 1.0.24.0 Nfo Metadata 1.0.82.0 OMDb 1.0.21.0 Open Subtitles 1.0.63.0 Port Mapper 1.2.8.0 Studio Images 1.0.3.0 TheAudioDb 1.0.18.0 TheTVDB 1.5.8.0 Webhooks 1.0.35.0 XmlTV 1.2.0.0 2025-02-21 00:00:30.573 Error App: Error sending socket message from 0.0.0.0:1900 to 239.255.255.250:1900 *** Error Report *** Version: 4.8.10.0 Command line: /data/app/~~uLaVOGXDhUR1KmcPZ9Awxg==/com.emby.embyserver-vMc-04RefJaCtGQwjacvVg==/base.apk Operating system: Android 11 (REL) SDK:30 BuildId:RP1A.200720.012 Incremental:T725XXU2DVB2 Patch-Level: 2022-02-01 Framework: Mono 6.12.0 (2020-02/d9a6e8710b3) 4.0.50524.0 OS/Process: Arm64/Arm64 Runtime: mscorlib.dll Processor count: 8 Data path: /storage/emulated/0/Android/data/com.emby.embyserver/files Application path: /data/user/0/com.emby.embyserver Fingerprint: samsung/gts4lvxx/gts4lv:11/RP1A.200720.012/T725XXU2DVB2:user/release-keys Model: SM-T725 - samsung/samsung Hardware: gts4lv/gts4lvxx/qcom/sdm710 SupportedAbis: arm64-v8a, armeabi-v7a, armeabi System.Net.Sockets.SocketException: System.Net.Sockets.SocketException (0x80004005): Network is unreachable at Rssdp.SsdpCommunicationsServer.SendFromSocket (System.Tuple`3[T1,T2,T3] socketTuple, System.Memory`1[T] messageData, System.Net.IPEndPoint destination, System.Threading.CancellationToken cancellationToken) [0x000a9] in <c9ccedd9aa1f4f67bb1a33491270fd81>:0 Source: mscorlib TargetSite: Void Throw() embyserver-63875734185.txt
Luke 42237 Posted February 21, 2025 Posted February 21, 2025 HI, as a test, if you disable all dlna features, then restart the server, how does that compare?
Justin757 8 Posted February 23, 2025 Author Posted February 23, 2025 I just uninstalled dlna and restarted the server. Again its consuming a lot of battery. From 100% to 25% when idle at night no wifi. Only difference is log is now 250KB instead of 20MB! Also what about photo sliding issue? embyserver(1).txt
Luke 42237 Posted February 23, 2025 Posted February 23, 2025 OK we'll take a look at it. Thanks for reporting.
