Wastonxx 0 Posted February 19, 2025 Posted February 19, 2025 Sorry to bother you guys I have an emby server used by multiple people, but half a month ago I found that there seemed to be a memory leak on the server. When users watch videos, the memory occupied will continue to increase until the server is stuck. I have tried to upgrade and downgrade my docker image, but it is still not solved. I also found a post on this site in 2022 that also describes a similar problem. I also tried the method you provided to delete unnecessary plug-ins and turn off scanning, but it did not solve it. I would like to ask if you have other ideas and thoughts that can help me solve this problem? Thank you, btw, I am a paying user.
visproduction 335 Posted February 19, 2025 Posted February 19, 2025 Just guessing here... "Resource not found" 147 times Linux directory rights? line 562 example Quote *** Error Report *** Version: 4.8.8.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.8.0-45-generic (buildd@lcy02-amd64-075) (x86_64-linux-gnu-gcc-12 (Ubuntu 12.3.0-1ubuntu1~22.04) 12.3.0, GNU ld (GNU Binutils for Ubunt Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 96 Data path: /config Application path: /system MediaBrowser.Common.Extensions.ResourceNotFoundException: MediaBrowser.Common.Extensions.ResourceNotFoundException: Resource not found. Type: LibraryItem, Id: 327139 at Emby.Api.UserLibrary.UserLibraryService.Get(GetItem request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Api TargetSite: Void MoveNext() === "Response 404" found 524 times dbase issues? Example: Line 2274 Quote 2025-02-19 21:22:11.679 Info Server: http/1.1 Response 404 to host41. Time: 533ms. GET http://host4/emby/Users/6a2fd205dbbc4ea39a76246193a47986/Items/278438
Wastonxx 0 Posted February 20, 2025 Author Posted February 20, 2025 I looked carefully and found that the multiple 404 errors probably meant that my firewall had disabled the user's IP address, so it could not be accessed. @Regular
GrimReaper 4897 Posted February 20, 2025 Posted February 20, 2025 (edited) OP's reply quoted from Report received: Quote Thank you for your reply. The permissions are all 777. 404 should be caused by a docker error. It has been resolved later. It seems to have nothing to do with the memory leak. Today I tried to remove the system swap, and I don’t know if the memory leak will occur again @Wastonxxkindly do not use "Report Malicious" for troubleshooting purposes, you'll get all the assistance in respective thread. Thanks. Edited February 20, 2025 by GrimReaper
Luke 42243 Posted February 20, 2025 Posted February 20, 2025 Hi, can you please try remind the infuse plugin, then restart the server and see how things compare. Thanks.
