CaffNoir 22 Posted February 18, 2025 Posted February 18, 2025 Hey I wonder if it's possible to create a plugin or use the api to inject some css/js or even interact with the api to do few things : First exemple : Adding a new "line" or main menu categorie such has "Movies recently cames out" that has been added in latest emby release but for TV show or user watching history. 2nd exemple : Adding a "account sections for user" to let them remove devices where they are logged 3rd exemple : Adding a way for the user to add profils such has netflix. Letting them select the user they want once connected and editing profils in settings. 4th exemple (last) : Edit how the front-end is working (see the picture) This plugin (https://github.com/Shurelol/Emby.CustomCssJS) already do this but it need to edit some part of apps. I wonder if it's possible to do it without editing the app ? I'm using the latest beta server (4.9.0.38)
Luke 42233 Posted February 18, 2025 Posted February 18, 2025 Hi, there is no way to inject css or js into Emby apps.
CaffNoir 22 Posted February 20, 2025 Author Posted February 20, 2025 what about Adding a new "line" or main menu categorie such has "Movies recently cames out" that has been added in latest emby release but for TV show or user watching history.
bakes82 167 Posted February 21, 2025 Posted February 21, 2025 Nope. It’s been “coming soon” for a few years. The ability to pin collections would be the feature request you want. 1
CaffNoir 22 Posted February 22, 2025 Author Posted February 22, 2025 top pick plugin already do what i want but not the same way
bakes82 167 Posted February 23, 2025 Posted February 23, 2025 correct and it also duplicate's items in the db and shouldnt be used
