pfm55 0 Posted February 17, 2025 Posted February 17, 2025 I switched from Plex to Emby because I was experiencing DTS stuttering issues that I couldn't find a fix for. i was hoping that Emby would not have the same issue, but it did. After downloading the Emby server, I installed the Emby app for Android TV. When I found the correct playback button, I thought I had resolved the stuttering issue. However, when I started installing the Emby app on my other TVs, I noticed there were two versions: one for Android TV and another for Android. I preferred the Emby app for Android, so I converted it. But after installing it, I realized it doesn't have the same correct playback button that the Emby for Android TV app does. Is there a setting in the Emby for Android app that can replicate the functionality of the correct playback button found in the Emby for Android TV app?
GrimReaper 4898 Posted February 17, 2025 Posted February 17, 2025 26 minutes ago, pfm55 said: Is there a setting in the Emby for Android app that can replicate the functionality of the correct playback button found in the Emby for Android TV app? Not currently. Added as #98 in below mega-thread.
justinrh 267 Posted February 17, 2025 Posted February 17, 2025 What would be the 'correct' playback button?
Luke 42243 Posted February 17, 2025 Posted February 17, 2025 5 minutes ago, justinrh said: What would be the 'correct' playback button? He means playback correction. 1
justinrh 267 Posted February 17, 2025 Posted February 17, 2025 (edited) Emby has a playback correction button? What is it correcting? Edited February 17, 2025 by justinrh
GrimReaper 4898 Posted February 17, 2025 Posted February 17, 2025 If an item is DirectPlaying: first press triggers remux; pressing it again triggers transcoding. If an item is DirectStreaming: single press triggers transcoding. 1
Sammy 791 Posted February 18, 2025 Posted February 18, 2025 15 hours ago, GrimReaper said: Not currently. Added as #98 in below mega-thread. I have basically switched over to the universal android app but do miss this feature occasionally but less so as I switch to Dolby Vision / HDR10 / Atmos capable hardware such as TCL QM8 TV's.
