Jator 13 Posted March 13, 2025 Posted March 13, 2025 Quick question, since this is still in "alpha" or perhaps "beta" phase, if I build a channel in one version and your code is updated and I update, do I need to rebuild the channel to get the updated version aligned with my channel (ie either work or have it access whatever update was made)? Currently I have 5 channels built with Virtual TV (80s, RomCom, Romance, Period/Time Pieces, and SciFi). I also have a Ted Lasso channel (we call it our palette cleanser after watching disturbing movies....or just the news). I just don't want to have to keep rebuilding it every few days, and if so, will just create one "test" channel with myTV until we are further along in it's maturation.
VicMoore 755 Posted March 13, 2025 Author Posted March 13, 2025 @JatorWelcome back! By the way, I have a tool for building the images for channel logos, and the other images in Emby. I need to clean it up, but I may post it soon. Vic 1
VicMoore 755 Posted March 13, 2025 Author Posted March 13, 2025 (edited) @JatorIt is always possible that changes can require you to rebuild your channels. I will try to keep this to a minimum. The problem is that I have to store the EPG that you create so it's available the next time that you want to edit or add to your channels. The easiest way to do this is to save the HTML. This technique has a side effect. If I change the base HTML, my changes will be overwritten when you restore your EPG. I other words, you won't see any of my changes. The good news is that the base HTML is mature, and I don't have any current plans to change it Vic. Edited March 13, 2025 by VicMoore 1
VicMoore 755 Posted March 13, 2025 Author Posted March 13, 2025 @TZTZoroI hope that you have noticed that your CSS from pseudoTV still lives on in myTV. I learned from your code how to exploit CSS to make the JS simpler. I am in your debt. Thanks again, vic
Jator 13 Posted March 13, 2025 Posted March 13, 2025 (edited) disregard Edited March 13, 2025 by Jator oops
VicMoore 755 Posted March 16, 2025 Author Posted March 16, 2025 (edited) Attached below is the latest code. I have corrected a variety of bugs, and I have improved the GUI in several places. Vic Edited June 12, 2025 by VicMoore 2
Ninko 78 Posted March 17, 2025 Posted March 17, 2025 On 12/03/2025 at 18:33, speechles said: The Roku app is crashing? Then when you sign back into the Roku app it just starts to work? If this is involving the Roku app crashing then we can officially help him resolve those crashes and work with him on this. @VicMooreI can work with you on fixing this crash on the Roku. Going to install the plugin and set this up. Then try to see if I can get some crashes on the Roku client and see where this occurs. The Roku app should never crash. Even with bad data it should error rather than crash. Will post back once I have this setup and can test. That's right. I'm happy to help with this, just let me know what you want me to do. Thanks
VicMoore 755 Posted March 17, 2025 Author Posted March 17, 2025 If anyone is interested, attached below is a plugin for viewing and editing the metadata and images of Emby library content. You can edit a single item or many items at once. I use this tool to help build TV Guides for myTV. If anyone wants the source code, I will post it. Vic myTvTool.dll 2
VicMoore 755 Posted March 19, 2025 Author Posted March 19, 2025 Does anyone need any help on how to use the myTV Tool? If so just ask. Vic
TZTZoro 26 Posted March 20, 2025 Posted March 20, 2025 That is awesome @VicMoore! i am not that active anymore on this foru, unfortunately so things are delayed but i am glad that i could have been of help
Jator 13 Posted March 20, 2025 Posted March 20, 2025 Been traveling most of the week but will play with things over the weekend.
Jator 13 Posted March 21, 2025 Posted March 21, 2025 Is there a way to name individual tuners created by MyTV so as not to have the same tuner name displayed when there are multiple?
VicMoore 755 Posted March 22, 2025 Author Posted March 22, 2025 @JatorThat's a good question. I don't know the answer, but I will try and find out. Vic
Jator 13 Posted March 27, 2025 Posted March 27, 2025 Hey @VicMoore, I've been testing different iterations of dedicated channels. Is there a way to have a channel setup to only show movies with the category "comedy" or even perhaps 2 different categories "romance" and "comedy"? I played with different versions of the query string but couldn't get it to pull anything.
VicMoore 755 Posted March 28, 2025 Author Posted March 28, 2025 @Jatorwe must think alike. I am working on that right now. Once I finish the base code, I will get up with you to discuss the finale details. Right now, I analyze your Media Libraries and graph out the distribution of Genres. I then allow you to quickly build channels from that data. I even want to include an option that will build the entire EPG automatically. Since you can have as many EPGs as you like this should not be too difficult but will take some time. Vic 1
speechles 2062 Posted March 28, 2025 Posted March 28, 2025 (edited) 1 hour ago, Ninko said: @speechlesDid you get my last message? I saw it but I didn't reply back. My bad on that. I meant to circle back. But you mean the last message in this thread? I haven't asked for help yet because I cannot experience the crash. Has the Roku app crashed on you when using the MyTV Plugin? I will work with you on these crashes on the Roku to solve them. If you know of some way to cause them with media let me know. Maybe access to your server so we can login and experience the issue first hand? If that were possible we can solve the problem since we see all the logs. The crash is something that should not be happening in the app. The error should be ignored by the app or if this is something fatal to playback it should throw up a dialog/message to let the user know this item is presently unplayable for some reason. Since it isn't doing either of those and just rudely exiting the app in a crash this makes it a bug with a very high priority. Thank you for any help you can provide. Edited March 28, 2025 by speechles
VicMoore 755 Posted April 6, 2025 Author Posted April 6, 2025 (edited) Attached is the latest code. I have corrected many bugs and have added new functionality. I have tested it for several days and have built very large EPGs. @Jatorhas also been testing the code. I also added a quick way to build channels. Soon I will add a feature for creating a starter set of channels by analyzing your Emby libraries and from that analysis assembling the channels automatically. Vic Edited June 12, 2025 by VicMoore 1
VicMoore 755 Posted April 6, 2025 Author Posted April 6, 2025 In the TV platform C# code, I simplified interfacing with the various Emby clients because I didn't understand much about these clients. My knowledge has improved over the last year, so I plan now to make the TV Platform perform better and work with more devices. My attention is turning to this task. Vic 1
VicMoore 755 Posted April 8, 2025 Author Posted April 8, 2025 (edited) I added a feature that will create a set of starter channels from your Emby Database under two conditions. You can do this when you add a new TV Source or when you select "TV Guide 1" and have no channels defined. In both cases a purple "Starter Channels" button appears. Click this button and the starter channels will appear. I have only tested this on my Emby DB. Let me know if it works on your system. Vic Edited June 12, 2025 by VicMoore 2
VicMoore 755 Posted April 8, 2025 Author Posted April 8, 2025 Did the "Starter Channels" work for anybody? Vic
VicMoore 755 Posted April 9, 2025 Author Posted April 9, 2025 (edited) I improved the channel build process and added needed error notifications. I am turning now back to improving the TV Platform. Vic Edited June 12, 2025 by VicMoore
VicMoore 755 Posted April 9, 2025 Author Posted April 9, 2025 I was thinking that a cool idea would be to allow users to save and restore their channels to a thumb drive. Vic 1
feerlessleadr 173 Posted April 9, 2025 Posted April 9, 2025 hi @VicMooreI just tried out the latest version, and it is very intuitive to use, really great work. I am still having the same issue where the guide order is not working as I would have expected. I have a channel setup for Stargate where I want to play episodes from each of the 3 Stargate shows in premiere date order. However, when I set the Media Play Order for the 3 shows to 'Premiere date', the guide still plays each show in sequential order (i.e. Stargate SG1 S1E01, then Stargate Atlantis S01E01, then SGU S01E01, then Stargate S1E02, Stargate Atlantis S01E02, etc.).
VicMoore 755 Posted April 9, 2025 Author Posted April 9, 2025 Hello @feerlessleadrI am busy with the family tonight. I will study your note tomorrow. Vic
