roormonger 6 Posted May 12, 2025 Posted May 12, 2025 I agree with @Jatora truly random random would be awesome. I am waiting till a release when backup and restore is fully working to test it again. I want this next time to be the last for remaking channels lol.
Jator 13 Posted May 12, 2025 Posted May 12, 2025 1 hour ago, roormonger said: I agree with @Jatora truly random random would be awesome. I am waiting till a release when backup and restore is fully working to test it again. I want this next time to be the last for remaking channels lol. Ideally a true random would be awesome, but even absent that, if we could have something like Random 1 (C->F->B->E->A-.D) -> Random 2 (B->F->D->A->E->C) stacked, then E wouldn't always follow A. If a 3rd and 4th Random series was created, then having Random 1 -> Random 2 -> Random 3 -> Random 4 would basically give you in essence a Randomized list, even though if you scrolled through long enough you could identify a pattern.
VicMoore 755 Posted May 13, 2025 Author Posted May 13, 2025 @roormongerI appreciate your testing. I will have the backup code ready in a few days. Vic
roormonger 6 Posted May 13, 2025 Posted May 13, 2025 1 hour ago, VicMoore said: @roormongerI appreciate your testing. I will have the backup code ready in a few days. Vic Take your time.
VicMoore 755 Posted May 14, 2025 Author Posted May 14, 2025 (edited) @roormongerPlease look at the Backup and Restore in the myTV plugin below. I checked it several times and it worked OK. I don't know if all variations work. Vic Edited May 31, 2025 by VicMoore
VicMoore 755 Posted May 15, 2025 Author Posted May 15, 2025 (edited) Everything in myTV is much faster now. I streamlined the code and removed all unnecessary code. Builds now go quickly. Hopefully I didn't break anything. You will need to do a fresh plugin install. Vic Edited May 31, 2025 by VicMoore
grzes2411 3 Posted May 16, 2025 Posted May 16, 2025 On LG Smart TV if I play a channel then emby sees as if I am playing a movie that is currently airing on the channel, and in web app, android, Samsung smart tv, windows app emby sees as playing a tv channel.
roormonger 6 Posted May 17, 2025 Posted May 17, 2025 On 4/19/2025 at 7:44 PM, Jator said: Sorry, when you say "remove the old TV Service", are you referring to the the plugin itself (ie remove the plugin before installing the new version) or uninstalling all old channels created by previous version? Or something else? The "Sports Movie" channel was a new channel, so I assumed it was using the latest version of the plugin as I always restart the server after I download a new version of your plugin. It means doing this.
VicMoore 755 Posted May 17, 2025 Author Posted May 17, 2025 @roormongerYes, you have to remove the tuner (delete it). The good news is that from now own you can save and restore your channels. Vic
roormonger 6 Posted May 17, 2025 Posted May 17, 2025 1 hour ago, VicMoore said: @roormongerYes, you have to remove the tuner (delete it). The good news is that from now own you can save and restore your channels. Vic So I finally updated the plugin. There was one thing I noticed while making my usual channels. The calendar for min/max premiere date is missing and just typing the date in that field does not work. It won't even populate the preview query if the min/max premiere date query type is chosen.
roormonger 6 Posted May 17, 2025 Posted May 17, 2025 (edited) Oh, also just tried to make a backup. Got an error "TypeError: window.showSaveFilePicker is not a function" But you are definitely right. The plugin is much faster. I was also able to make all of my channels in one shot. I was not able to do that before. If I made too many at a time the EPG build would always fail so I used to just do it maybe eight or so at a time. Edited May 17, 2025 by roormonger
VicMoore 755 Posted May 17, 2025 Author Posted May 17, 2025 @roormongerI will fix the calendar issue. What browser are you using? I have only tested on Edge and Chrome on a windows OS. The showSaveFilePicker is OS and browser dependent. What OS are you using? Vic
roormonger 6 Posted May 17, 2025 Posted May 17, 2025 33 minutes ago, VicMoore said: @roormongerI will fix the calendar issue. What browser are you using? I have only tested on Edge and Chrome on a windows OS. The showSaveFilePicker is OS and browser dependent. What OS are you using? Vic Zen browser (Firefox based) and windows 11
VicMoore 755 Posted May 17, 2025 Author Posted May 17, 2025 (edited) @roormongerThe "minMax" menus are fixed. Could you please try using the Edge Browser to test the backup? The showSaveFilePicker is not supported in Zin or Fire Fox. Vic Edited May 31, 2025 by VicMoore
roormonger 6 Posted May 18, 2025 Posted May 18, 2025 (edited) 5 hours ago, VicMoore said: @roormongerThe "minMax" menus are fixed. Could you please try using the Edge Browser to test the backup? The showSaveFilePicker is not supported in Zin or Fire Fox. Vic myTV.dll 587 kB · 1 download Using edge worked fine. Also tried in Arc browser (chromium based). Didn't work. Calendar also works now. Thank you. As an idea... What if you just made backing up a scheduled task and have the backup land in the same folder as Emby's backups? That way it wouldn't matter what browser was used. Well, I am just guessing anyway. I have no idea how feasible any of that is. Also, would it be simpler to only backup the channel names, numbers, and rules used to make them. Then just let the channels rebuild themselves after a restore. That way if you have added new media since that backup was taken, it will just automatically be included in the restore. Edited May 18, 2025 by roormonger 1
VicMoore 755 Posted May 18, 2025 Author Posted May 18, 2025 @roormongeryou and I think alike. I tried your suggestion for backups first. It can't be done because of the security model of the browsers. By making you pick a file name to fetch or save to forces the user to be involved in the activity. This makes it more difficult for a virus to access your file system. Now, having said that, it is possible to backup within the browser. I can implement your idea that way. 11 hours ago, roormonger said: Also, would it be simpler to only backup the channel names, numbers, and rules used to make them. Then just let the channels rebuild themselves after a restore. That way if you have added new media since that backup was taken, it will just automatically be included in the restore. Actually, this is much harder to do. My way is just one page of code. Vic
roormonger 6 Posted May 18, 2025 Posted May 18, 2025 17 minutes ago, VicMoore said: @roormongeryou and I think alike. I tried your suggestion for backups first. It can't be done because of the security model of the browsers. By making you pick a file name to fetch or save to forces the user to be involved in the activity. This makes it more difficult for a virus to access your file system. Now, having said that, it is possible to backup within the browser. I can implement your idea that way. Actually, this is much harder to do. My way is just one page of code. Vic I mean a scheduled task in Emby. Then just dump the txt file it generates into a folder in the Emby folder structure. Like for example the backups folder that the Emby server backup plugin puts it's backups. I saw another plugin that saved files to the logs folder. Or what about plugins/configurations?
VicMoore 755 Posted May 18, 2025 Author Posted May 18, 2025 @roormongerGreat Idea, I will start working on it. Vic
VicMoore 755 Posted May 20, 2025 Author Posted May 20, 2025 (edited) @roormongerTry the code below. It implements your idea for backups. If the filePicker is not supported, then the backup is stored and retrieved from the Plugin Area. It needs testing. Vic Edited May 27, 2025 by VicMoore
VicMoore 755 Posted May 23, 2025 Author Posted May 23, 2025 A problem that I struggle with is duplicate media within my Emby libraries. So, I now check for duplicate media across the Emby libraries when you start myTV. I will post the code later today. Vic
VicMoore 755 Posted May 26, 2025 Author Posted May 26, 2025 (edited) Attached is the latest code. Many things have been added. Vic The introduction has been updated. Edited May 31, 2025 by VicMoore
VicMoore 755 Posted May 31, 2025 Author Posted May 31, 2025 I will be doing things with the family for a while. A will check every few days for bug reports. Vic
