Bangloud 1 Posted February 16, 2025 Posted February 16, 2025 hi all, Got a fire tv and 4 firesticks in house all connect to server ok.I have a firestick in my bar thats hard wired to a router in there that is hard wired to the main router in house but set up as a separate network.my firestick in there wont connect to my server i have tried with the emby connect scanning QR code on screen and adding pin.The pin gets accepted and goes to next screen but when it says select server there isnt one there. I have a plex server working on same stick and network that works fine any ideas please.
Solution Luke 42243 Posted February 17, 2025 Solution Posted February 17, 2025 Hi there, did you first link your server with Emby Connect? Emby Connect
Bangloud 1 Posted February 17, 2025 Author Posted February 17, 2025 Thanks for reply Luke no sorry bit of a noob how would I do that tia
Bangloud 1 Posted February 17, 2025 Author Posted February 17, 2025 I was wondering if it was the emby for fire app from play store I can remember plex had a simular thing that plex app from store would not work if you got invited to join a server you had to add plex through web browser to their website and download app that way then would work.
ebr 16336 Posted February 17, 2025 Posted February 17, 2025 19 hours ago, Bangloud said: a separate network.my firestick in there wont connect to my server Hi. Is there a route between the networks? 7 hours ago, Bangloud said: Thanks for reply Luke no sorry bit of a noob how would I do that tia He provided a link with instructions in his message.
Bangloud 1 Posted February 17, 2025 Author Posted February 17, 2025 sorted now thanks. it was the emby connect need enabling and email putting in within user settings on server, thanks 1
