BigIrn 10 Posted March 10, 2025 Posted March 10, 2025 (edited) Something that I've noticed with the successful movies and tv shows the m3u URL created look like this: TV Shows: http://url:80/series/username/password/1032455.mkv <--the link will try to download the movie in firefox Movies: http://url:80/movie/username/password/1266241.mkv <-- the link will try to open a tv episode in firefox Any way of somehow using the url format to capture all the movies and shows? Edited March 10, 2025 by BigIrn update
BigIrn 10 Posted March 10, 2025 Posted March 10, 2025 Nevermind I manually did it in texteditor and now have a m3u for movies and series. Trying to run them the plugin now. I left the keywords section blank and hope the plugin knows where to place the movies.
mickle026 652 Posted March 10, 2025 Author Posted March 10, 2025 6 hours ago, BigIrn said: Something that I've noticed with the successful movies and tv shows the m3u URL created look like this: TV Shows: http://url:80/series/username/password/1032455.mkv <--the link will try to download the movie in firefox Movies: http://url:80/movie/username/password/1266241.mkv <-- the link will try to open a tv episode in firefox Any way of somehow using the url format to capture all the movies and shows? Yes , I will add that.
mickle026 652 Posted March 10, 2025 Author Posted March 10, 2025 (edited) @BigIrnTry this one. I still have not finished the other modifications, but i have added the detection you asked for. I haven't tested it. removed as not writing strm files Edited March 10, 2025 by mickle026
gillmacca01 220 Posted March 10, 2025 Posted March 10, 2025 So I am working away from home all week for at least the next 5 weeks, only home at weekends. So as I have managed to get it to work on my QNAP with the correct configuration of the ignore words, I thought I would give it a go on the laptop again (with the same configuration as my QNAP). 14 minutes for start to finish...fast enough for me
BigIrn 10 Posted March 10, 2025 Posted March 10, 2025 (edited) 6 minutes ago, gillmacca01 said: So I am working away from home all week for at least the next 5 weeks, only home at weekends. So as I have managed to get it to work on my QNAP with the correct configuration of the ignore words, I thought I would give it a go on the laptop again (with the same configuration as my QNAP). 14 minutes for start to finish...fast enough for me Mine still seems to be running since this morning at 3am EST. It’s working though. Safe travels. Edited March 10, 2025 by BigIrn
sftech13 25 Posted March 10, 2025 Posted March 10, 2025 On 3/8/2025 at 7:12 PM, mickle026 said: I am now detecting the system architecture, cpu and memory to calculate the max parallel writes I can do without causing thread locking or cpu maxed out conditions. WOW....This changes my script alot, never thought of it before. Your plugin is awesome. Good work. I tested it this morning. 1
BigIrn 10 Posted March 11, 2025 Posted March 11, 2025 (edited) I'm running the macos/m4 mini and just want to share my log for reference. I *think* it's done, I can't really quantify it without doing a terminal script to read the VOD folder and comparing it to Smarter IPTV live. Edited March 15, 2025 by GrimReaper Attachment removed
gillmacca01 220 Posted March 11, 2025 Posted March 11, 2025 4 hours ago, BigIrn said: I'm running the macos/m4 mini and just want to share my log for reference. I *think* it's done, I can't really quantify it without doing a terminal script to read the VOD folder and comparing it to Smarter IPTV live. ScheduledTask-[M3UToStrm]10.Mar.2025 - 21.51.14.txt 166.7 MB · 0 downloads That's one of the steps I need to do. Compare the original m3u and what has been output, to see if I am missing anything
mickle026 652 Posted March 11, 2025 Author Posted March 11, 2025 I am currently rewriting the "brain" of all this, and thus re-writing the subsidiary parts too - Its taking me a bit longer. There are a few issues in the original that I have noted. 1. If you log the output, when the log gets large, there can be a cross threaded file lock which "can" cause the process to just exit/miss files etc. *This was hard to detect* 2. Some ignore words didn't seem to be being captured. The core couldn't be multithreaded in its original form. Status: I have re-written the core, that is now multithreaded as well as everything else, so it processes the m3u file across all cores simultaneously (i.e. on my pc reads and interprets 16 m3u entries simultaneously, categorises them etc), as well a all the I/O operations and logging. I have re-written the logger altogether. Its complicated to explain, but it works. I have re-written the I/O file writer. So that now queues and writes across all cores simultaneously, also prevents thread locks, overloads, queue buffer overflow etc.. I have re-written the ignore handler, that is still being tested but appears to be corrected. There is still more to do as all of this is new and replacing the older code. Full Verbose Logging mode is only taking 19 mins now, compared to most of the day before! It might take me a few more days but I should be able to post a full working version soon. 5
fbrassin 47 Posted March 11, 2025 Posted March 11, 2025 I don't know if it is just my m3u file, but in mine movies and series are easy to recognise. MOVIES: #EXTINF:-1 tvg-id="" tvg-name="Mune Il Guardiano Della Luna" tvg-logo="http://locandine.ddns.net:25461/images/9BsCIVc3tLhPXE4UK0PtZojfkCR_big.jpg" group-title="Animazione",Mune Il Guardiano Della Luna http://xxx:12345/movie/user/password/262574.mkv Serie: #EXTINF:-1 tvg-id="" tvg-name="Alaska: gli alieni sono tra noi S01 E08" tvg-logo="https://image.tmdb.org/t/p/w300/z2L3Aw9RDmpMcruij7tODi8mGnq.jpg" group-title="Serie Discovery+",Alaska: gli alieni sono tra noi S01 E08 http://xxx:12345/series/user/password/262574.mkv Is it possible to tell plugin that the ones with movie is a movie and the ones with series are tv shows instead of force for every single movie not recognised to go in movies and vice versa? 1
sftech13 25 Posted March 11, 2025 Posted March 11, 2025 4 minutes ago, fbrassin said: I don't know if it is just my m3u file, but in mine movies and series are easy to recognise. MOVIES: #EXTINF:-1 tvg-id="" tvg-name="Mune Il Guardiano Della Luna" tvg-logo="http://locandine.ddns.net:25461/images/9BsCIVc3tLhPXE4UK0PtZojfkCR_big.jpg" group-title="Animazione",Mune Il Guardiano Della Luna http://xxx:12345/movie/user/password/262574.mkv Serie: #EXTINF:-1 tvg-id="" tvg-name="Alaska: gli alieni sono tra noi S01 E08" tvg-logo="https://image.tmdb.org/t/p/w300/z2L3Aw9RDmpMcruij7tODi8mGnq.jpg" group-title="Serie Discovery+",Alaska: gli alieni sono tra noi S01 E08 http://xxx:12345/series/user/password/262574.mkv Is it possible to tell plugin that the ones with movie is a movie and the ones with series are tv shows instead of force for every single movie not recognised to go in movies and vice versa? There is an option by grouping, maybe you can ask for a user defined placement in the options. So you can put keywords, etc. in there and it will sort them
mickle026 652 Posted March 11, 2025 Author Posted March 11, 2025 (edited) The next version, when it is released incorporates this, it was asked for further back in this thread and I have added it into the new code already. It is already tested and working. It will also recognise continuous stream URLs as live tv when it's ready. It's getting close, I still have a few parts to finish, I don't have a huge amount left to do. Edited March 11, 2025 by mickle026 2 1
BigIrn 10 Posted March 13, 2025 Posted March 13, 2025 I don't know if it's just me but it seems like the pluigin has been running for 2 days....how can I tell? Is it set to run again in scheduler?
mickle026 652 Posted March 13, 2025 Author Posted March 13, 2025 (edited) 51 minutes ago, BigIrn said: I don't know if it's just me but it seems like the pluigin has been running for 2 days....how can I tell? Is it set to run again in scheduler? Maybe you ran into one of the quirks mentioned above when it just exits for no reason On 11/03/2025 at 10:52, mickle026 said: There are a few issues in the original that I have noted. 1. If you log the output, when the log gets large, there can be a cross threaded file lock which "can" cause the process to just exit/miss files etc. *This was hard to detect* 2. Some ignore words didn't seem to be being captured. This no longer happens on the version I am testing right now. It looks pretty similar, but it almost all new. There are a few more options, such as what to output, what to log etc. I am not far off posting it, I have a few more things to finish off, so it might be ready by this weekend. (I hope ) So far it seems to be a LOT more accurate, using all the ignore words, outputting and cleaning up correctly (I think anyway) I still have to add in code to use the inclusion words, but there isn't a lot more to do. Its almost detecting everything properly now without the inclusion words. 13.Mar.2025 - 15:51:26 channelName: EN - Lucifer (US) S02 E13 13.Mar.2025 - 15:51:26 Sanitized Channelname: EN - Lucifer (US) 13.Mar.2025 - 15:51:26 Detected TV Shows - URL contains the word '/Series/' 13.Mar.2025 - 15:51:26 Adding TV show: EN - Lucifer (US) S02 E13 13.Mar.2025 - 15:51:26 groupTitle Folder omitted due to IgnoreGroupTitleFolder setting. 13.Mar.2025 - 15:51:26 Item [581288] Adding to Folder: D:\VODS\TV Shows\EN - Lucifer (US)\Season 02 Edited March 13, 2025 by mickle026 2
BigIrn 10 Posted March 14, 2025 Posted March 14, 2025 So I went to see if the movies on the server matched what was on the m3u and I found a lot of garbage I don't want. Basically anything not EN or UK... 126745 movies to sort through. Here is how did some quick array pivot table to see what it looked like. The hardest one I have is how to put in an arabic letter into the ignore list. Once I get a concise list of what I DO WANT I want to figure out how to consolidate the folders or just them all into genres. I wouldn't want to accidentally have a friend over and the For Adults pops up while we're scrolling lmao Source Movies ÍSLANDS MOVIES 11 ÍSLANDS MOVIES 4K 3840P 1 AL - ARKIVA 1980/2022 2646 AL - MË TË REJAT 1064 AL - PËR FËMIJË 75 AMAZON DOCU-MOVIES 14 AMAZON DOCU-MOVIES 4K 3840P 10 AMAZON KIDS 21 AMAZON KIDS 4K 3840P 4 AMAZON MOVIES 178 AMAZON MOVIES 4K 3840P 88 APPLE+ KIDS 9 APPLE+ KIDS 4K 3840P 2 APPLE+ MOVIES 40 APPLE+ MOVIES 4K 3840P 34 ASIA MOVIES (MULTI-SUBS) 404 BE - DOCU-MOVIES (NL) 2 BG - БЪЛГАРИЯ ФИЛМ 713 BG - БЪЛГАРИЯ ДЕЦА 78 BG - ПОСЛЕДНИ ДОПЪЛНЕНИЯ 65 BG - MOMVIES 73 BN - BENGALI 281 BR - KIDS 22 BR - MOVIES 238 CHRISTIAN MOVIES 70 CN - CHINA FILM 13 DANISH FILM 96 DE - BUD SPENCER & TERENCE HILL 43 DE - AMAZON PRIME PRODUKTION 16 DE - ANIME 4K 3840P 13 DE - ANIME FILME 144 DE - APPLE+ FILME PRODUKTION 40 DE - BLURAY FILME 245 DE - BOLLYWOOD 71 DE - DISNEY+ PRODUKTION 62 DE - DOKUMENTATION 140 DE - FILME 3D 44 DE - FILME 4K 3840P 859 DE - FILME ALT & 2023 7404 DE - FORMULA 1 7 DE - FUSSBALL 110 DE - IMDB TOP 100 100 DE - JAMES BOND 007 26 DE - KINDER 3D 4 DE - KINDER FILME 491 DE - KINDER FILME 4K 3840P 65 DE - MARVEL VS DC 24 DE - NETFLIX PRODUKTION 516 DE - NEUE FILME & 2025 424 DE - STUDIO GHIBLI 23 DE - WRESTLING 15 DISCOVERY+ MOVIES 6 DISNEY+ KIDS 54 DISNEY+ MENA KIDS 3840P 11 DISNEY+ MOVIES EU 107 DISNEY+ MOVIES MENA 3840P 74 DREAMWORKS ANIMATION 25 EN - 2020 & OLD 1200 EN - ACTION 974 EN - ADVENTURE 286 EN - Biblical 69 EN - BOXING 8 EN - CHRISTMAS 589 EN - COLLECTIONS 450 EN - COMEDY 1019 EN - CONCERTS 188 EN - DOCUMENTARIES 714 EN - DRAMA 1881 EN - HORROR 638 EN - IMDB TOP 250 250 EN - KIDS 727 EN - KIDS 4K 3840P 43 EN - MANGA/ANIME 134 EN - MOVIES 4K 3840P 607 EN - MUSICAL 158 EN - NEW RELEASE 4860 EN - ROMANCE 311 EN - SCIENCE FICTION 200 EN - THRILLER 692 EN - UFC 64 EN - WESTERNS 264 EN - WORKOUT 18 EN - WWE 393 ES - AMAZON PRIME 9 ES - APPLE TV+ 2 ES - DISNEY+ 2 ES - DOCUMENTALES 119 ES - INFANTILES Y FAMILIAS 427 ES - NETFLIX 299 ES - PARAMOUNT+ 1 ES - PELÍCULAS 2945 ES - PELÍCULAS 2024 627 ES - PELÍCULAS 2025 36 ES - PELÍCULAS 4K 3840P 342 ES - PELÍCULAS ANIMACION 46 ES - PELÍCULAS ANTIGUAS Y SAGAS 246 ES - PELÍCULAS CLASICO 107 ES - PELÍCULAS TERROR 201 ES - PRIME+ 135 EX - MOVIES 786 FOR ADULTS 896 FR - 2021 ANCIEN FILM 1973 FR - ACTEURS FRANCAIS 117 FR - ACTION 690 FR - AMAZONE 13 FR - ANIMEE 621 FR - ART MARTIAUX 82 FR - ASIATIQUE 92 FR - BASKETBALL 33 FR - BOX OFFICE 26 FR - COMBAT FILMS 126 FR - COMEDIE 994 FR - CRIME 210 FR - CYCLISME 17 FR - DISNEY 173 FR - DOCUMENTAIRS 330 FR - DRAME 1036 FR - ENFANTS 350 FR - ENFANTS 4K 3840P 94 FR - F1 17 FR - FANTASTIQUE AVENTURE 133 FR - FILM 1940-1980 248 FR - FILM 2022 123 FR - FILM 2023 435 FR - FILM 2024 653 FR - FILM 4K 3840P 730 FR - FILMS EN SAGA 4K 3840P 102 FR - FOOTBALL 13 FR - GOLF 9 FR - GUERRE FILMS 155 FR - HANDBALL 3 FR - HISTORIQUE BIOPIC 170 FR - HORREUR 299 FR - LE DRENIER AJOUTEE 29 FR - MANGA 91 FR - MOTO 37 FR - MUSIQUE 40 FR - NETFLIX 2025 11 FR - NETFLIX FILMS 395 FR - PARAMOUNT+ 47 FR - RUGBY 11 FR - SCIENCE-FICTION 215 FR - THRILLER 399 FR - VOSTFR 62 FR - WRC 19 GR - APPLE+ 66 GR - CHRISTMAS MOVIES 169 GR - DISNEY+ 206 GR - DOCUMENTARY 53 GR - GREEK THEATER 52 GR - NETFLIX 526 GR - ΠΑΙΔΙΚΑ 308 GR - ΕΛΛΗΝΙΚΕΣ ΤΑΙΝΕΣ 138 GR - ΚΑΡΑΟΚΕ 45 GR - ΚΙΝΗΜΑΤΟΓΡΑΦΟΣ 2293 GR - PRIME AMAZON 235 IL - סרטים 2022 + ישן 74 IL - סרטים 2023 + האחרון 35 IL - דיסני+ סרטים 154 IL - FREE TV - סרטים 128 IN - BOLLYWOOD'S 203 IN - CAM & NEW RELEASE 23 IN - EN HINDI 220 IN - GUJARATI NATAK 33 IN - HINDI 2528 IN - KANNADA 401 IN - KIDS 535 IN - MALAYALAM 401 IN - MARATHI 42 IN - NEW RELEASE 156 IN - PUNJABI 342 IN - TAMIL 466 IN - TELUGU 269 IR - PERSIAN کلاسیک دوبله 421 IR - PERSIAN کارتون 404 IR - PERSIAN MOVIES 790 IR - PERSIAN SUB/DUB 4430 IR - PERSIAN قدیمی 495 IT - 2019 & VECCHIO 12 IT - 4K MOVIES 25 IT - AVVENTURA AZIONE 122 IT - CACCIA 21 IT - CARTONI ANIMATI 58 IT - CLASSICO 473 IT - COMEDIA 126 IT - DRAMA ROMANTICO 164 IT - FANTASTICO FANTASCIENZA 74 IT - HORROR THRILLER 100 IT - NUOVA VERSIONE 2125 JP - JAPANESE FILM 69 JP - NETFLIX 26 KU - BADINI 437 KU - CARTOON BADINI 74 KU - CARTOON SORANI 89 KU - KURDISH MOVIES SUB 45 KU - SORANI 476 LA - NIÑOS 167 LA - PELÍCULAS 295 MARVEL MOVIES (MULTI) 12 MARVEL MOVIES 3840P (MULTI) 12 MT - MOVIES 105 NETFLIX ANIMI 16 NETFLIX ASIA 213 NETFLIX DOCU-MOVIES 41 NETFLIX HEVC 88 NETFLIX KIDS 245 NETFLIX KIDS 4K 3840P 6 NETFLIX MOVIES 3362 NETFLIX MOVIES 4K 3840P 113 NL - 2022 & OUD 2131 NL - 4K KINDEREN 2 NL - BIOSCOOP 659 NL - BIOSCOOP 4K 3840P 24 NL - KERST FILMS 76 NL - KINDEREN 326 NL - NPO+ 1 NL - VIDEOLAND 1196 NL - VIDEOLAND KIDS 38 NORDIC BARN 4K 3840P 25 NORDIC BECK COMPLETE 51 NORDIC FILM 4K 3840P 259 NORDIC FILM 2022 & OLD 2538 NORDIC FILM NEW RELEASE 791 NORDIC KIDS 300 NORDIC MUSIC 9 NORGE BARN 7 NORGE FILM 103 OSN+ MOVIES 4K 3840P 32 PARAMOUNT PICTURES 201 PH - PHILIPPINES FILM 131 PK - NAATS NASHEED 99 PK - KIDS 4 PK - NAATS 135 PK - PAKISTANI MOVIES 298 PL - ŚWIĄTECZNIE 42 PL - DZIECI 86 PL - FILMY 4K 334 PL - KIDS 4K 25 PL - KINO 1650 PT/BR - AMAZON PRIME 6 PT/BR - ANIMAÇÃO 123 PT/BR - APPLE TV+ 38 PT/BR - DOCUMENTACAO 18 PT/BR - FILMES 1960-2023 3318 PT/BR - FILMES 2024-2025 103 PT/BR - NETFLIX 181 PT/BR - TERROR 182 QC - ANIMATION 12 QC - DOCUMENTAIRE 59 QC - FILMS NOUVELLE VERSION 137 QC - FILMS VIEILLE 190 QC - NETFLIX 16 QC - NOËL 60 QC - SPECTACLES 56 RO - MOVIES 935 RU - KIDS 948 RU - MOVIES 905 RU - NEW RELEASE 252 RU - RUSSIAN 2021&OLD 581 SO - SOMALIA MOVIES 87 SOCCER AFL 11 SOCCER AMERICAN FOOTBALL 305 SOCCER BASEBALL 256 SOCCER BASKETBALL 578 SOCCER FOOTBALL 1246 SOCCER FORMULA 1 24 SOCCER HOCKEY 281 SOCCER RUGBY 501 SOCCER UFC 43 SUOMEN ELOKUVAT 7 SVENSKA 2020 & GAMMAL 3306 SVENSKA AUDIOBOOKS 17 SVENSKA BARN 377 SVENSKA FILM 244 SVENSKA NYA UTGÅVAN 632 TOP KIDS BLURAY (MULTI-SUBS) 97 TOP MOVIES BLURAY (MULTI-SUBS) 1395 TR - ALT YAZI 74 TR - COCUK FILM 445 TR - IMD FILMER 58 TR - SINEMA 1793 TR - YESIL CAM SINEMA 495 UFC ARABIA 4 UNIVERSAL 258 VIAPLAY ÍSLANDS KRAKKAR 24 VIAPLAY ÍSLANDS KVIKMYNDIR 236 VIAPLAY KIDS 43 VIAPLAY MOVIES 121 رياضه متنوعه 168 أفلام جزائرية 31 أفلام رعب 790 أفلام آسيوية 2022 264 أفلام أجنبية 2018 70 أفلام أجنبية 2019 191 أفلام أجنبية 2020 629 أفلام أجنبية 2021 767 أفلام أجنبية 2022 866 أفلام أجنبية 2023 704 أفلام أجنبية 2024 545 أفلام أجنبية 2025 51 أفلام أجنبية قديمه 3752 أفلام أجنبيه فائقة الوضوح 678 أفلام أجنبيه تصوير سينمائي 12 أفلام أطفال فائقة الوضوح 63 أفلام أسيوية 2023 156 أفلام أسيوية 2024 154 أفلام أسيوية 2025 13 أفلام أسيوية قديمه 57 أفلام ألمانيه 2023 54 أفلام ألمانيه 2024 82 أفلام ألمانيه 2025 6 أفلام ألمانيه قديمه 131 أفلام شاهد الأصلية 129 أفلام شامية 29 أفلام خليجية 49 أفلام هندية 2023 203 أفلام هندية 2024 199 أفلام هندية 2025 8 أفلام هندية قديمه 735 أفلام هندية مدبلجة 68 أفلام كريم عبد العزيز 16 أفلام كوميديه 8 أفلام ليبيا 22 أفلام محمد هنيدي 20 أفلام مغربية 181 أفلام مدبلجة للعربية 78 أفلام مصرية 75 أفلام اطفال مدبلجة 86 أفلام اطفال مترجمة 679 أفلام احمد حلمي 26 أفلام احمد السقا 19 أفلام احمد عز 23 أفلام اسلامية 9 أفلام الكريسماس 95 أفلام انمي 91 أفلام تركية 230 أفلام تونسيه 80 أفلام نجوم العرب 21 أفلام عربية حديثه 67 أفلام عربية فائقة الوضوح 44 أفلام عربية قديمه 990 أفلام عربية كلاسيك 138 أفلام عربية تصوير سينمائي 31 مسرحيات خليجية 79 مسرحيات مغربية 21 مسرحيات مصرية 59 مسرحيات عربيه 64 افلام وثائقية 214 افلام هاني رمزي 13 افلام دريد لحام 30 افلام مسيحية 113 افلام عادل امام 100 الجزيرة الوثائقية 84 Grand Total 126745
mickle026 652 Posted March 14, 2025 Author Posted March 14, 2025 1 hour ago, BigIrn said: So I went to see if the movies on the server matched what was on the m3u and I found a lot of garbage I don't want. Basically anything not EN or UK... 126745 movies to sort through. Here is how did some quick array pivot table to see what it looked like. The hardest one I have is how to put in an arabic letter into the ignore list. Once I get a concise list of what I DO WANT I want to figure out how to consolidate the folders or just them all into genres. I wouldn't want to accidentally have a friend over and the For Adults pops up while we're scrolling lmao Source Movies ÍSLANDS MOVIES 11 ÍSLANDS MOVIES 4K 3840P 1 AL - ARKIVA 1980/2022 2646 AL - MË TË REJAT 1064 AL - PËR FËMIJË 75 AMAZON DOCU-MOVIES 14 AMAZON DOCU-MOVIES 4K 3840P 10 AMAZON KIDS 21 AMAZON KIDS 4K 3840P 4 AMAZON MOVIES 178 AMAZON MOVIES 4K 3840P 88 APPLE+ KIDS 9 APPLE+ KIDS 4K 3840P 2 APPLE+ MOVIES 40 APPLE+ MOVIES 4K 3840P 34 ASIA MOVIES (MULTI-SUBS) 404 BE - DOCU-MOVIES (NL) 2 BG - БЪЛГАРИЯ ФИЛМ 713 BG - БЪЛГАРИЯ ДЕЦА 78 BG - ПОСЛЕДНИ ДОПЪЛНЕНИЯ 65 BG - MOMVIES 73 BN - BENGALI 281 BR - KIDS 22 BR - MOVIES 238 CHRISTIAN MOVIES 70 CN - CHINA FILM 13 DANISH FILM 96 DE - BUD SPENCER & TERENCE HILL 43 DE - AMAZON PRIME PRODUKTION 16 DE - ANIME 4K 3840P 13 DE - ANIME FILME 144 DE - APPLE+ FILME PRODUKTION 40 DE - BLURAY FILME 245 DE - BOLLYWOOD 71 DE - DISNEY+ PRODUKTION 62 DE - DOKUMENTATION 140 DE - FILME 3D 44 DE - FILME 4K 3840P 859 DE - FILME ALT & 2023 7404 DE - FORMULA 1 7 DE - FUSSBALL 110 DE - IMDB TOP 100 100 DE - JAMES BOND 007 26 DE - KINDER 3D 4 DE - KINDER FILME 491 DE - KINDER FILME 4K 3840P 65 DE - MARVEL VS DC 24 DE - NETFLIX PRODUKTION 516 DE - NEUE FILME & 2025 424 DE - STUDIO GHIBLI 23 DE - WRESTLING 15 DISCOVERY+ MOVIES 6 DISNEY+ KIDS 54 DISNEY+ MENA KIDS 3840P 11 DISNEY+ MOVIES EU 107 DISNEY+ MOVIES MENA 3840P 74 DREAMWORKS ANIMATION 25 EN - 2020 & OLD 1200 EN - ACTION 974 EN - ADVENTURE 286 EN - Biblical 69 EN - BOXING 8 EN - CHRISTMAS 589 EN - COLLECTIONS 450 EN - COMEDY 1019 EN - CONCERTS 188 EN - DOCUMENTARIES 714 EN - DRAMA 1881 EN - HORROR 638 EN - IMDB TOP 250 250 EN - KIDS 727 EN - KIDS 4K 3840P 43 EN - MANGA/ANIME 134 EN - MOVIES 4K 3840P 607 EN - MUSICAL 158 EN - NEW RELEASE 4860 EN - ROMANCE 311 EN - SCIENCE FICTION 200 EN - THRILLER 692 EN - UFC 64 EN - WESTERNS 264 EN - WORKOUT 18 EN - WWE 393 ES - AMAZON PRIME 9 ES - APPLE TV+ 2 ES - DISNEY+ 2 ES - DOCUMENTALES 119 ES - INFANTILES Y FAMILIAS 427 ES - NETFLIX 299 ES - PARAMOUNT+ 1 ES - PELÍCULAS 2945 ES - PELÍCULAS 2024 627 ES - PELÍCULAS 2025 36 ES - PELÍCULAS 4K 3840P 342 ES - PELÍCULAS ANIMACION 46 ES - PELÍCULAS ANTIGUAS Y SAGAS 246 ES - PELÍCULAS CLASICO 107 ES - PELÍCULAS TERROR 201 ES - PRIME+ 135 EX - MOVIES 786 FOR ADULTS 896 FR - 2021 ANCIEN FILM 1973 FR - ACTEURS FRANCAIS 117 FR - ACTION 690 FR - AMAZONE 13 FR - ANIMEE 621 FR - ART MARTIAUX 82 FR - ASIATIQUE 92 FR - BASKETBALL 33 FR - BOX OFFICE 26 FR - COMBAT FILMS 126 FR - COMEDIE 994 FR - CRIME 210 FR - CYCLISME 17 FR - DISNEY 173 FR - DOCUMENTAIRS 330 FR - DRAME 1036 FR - ENFANTS 350 FR - ENFANTS 4K 3840P 94 FR - F1 17 FR - FANTASTIQUE AVENTURE 133 FR - FILM 1940-1980 248 FR - FILM 2022 123 FR - FILM 2023 435 FR - FILM 2024 653 FR - FILM 4K 3840P 730 FR - FILMS EN SAGA 4K 3840P 102 FR - FOOTBALL 13 FR - GOLF 9 FR - GUERRE FILMS 155 FR - HANDBALL 3 FR - HISTORIQUE BIOPIC 170 FR - HORREUR 299 FR - LE DRENIER AJOUTEE 29 FR - MANGA 91 FR - MOTO 37 FR - MUSIQUE 40 FR - NETFLIX 2025 11 FR - NETFLIX FILMS 395 FR - PARAMOUNT+ 47 FR - RUGBY 11 FR - SCIENCE-FICTION 215 FR - THRILLER 399 FR - VOSTFR 62 FR - WRC 19 GR - APPLE+ 66 GR - CHRISTMAS MOVIES 169 GR - DISNEY+ 206 GR - DOCUMENTARY 53 GR - GREEK THEATER 52 GR - NETFLIX 526 GR - ΠΑΙΔΙΚΑ 308 GR - ΕΛΛΗΝΙΚΕΣ ΤΑΙΝΕΣ 138 GR - ΚΑΡΑΟΚΕ 45 GR - ΚΙΝΗΜΑΤΟΓΡΑΦΟΣ 2293 GR - PRIME AMAZON 235 IL - סרטים 2022 + ישן 74 IL - סרטים 2023 + האחרון 35 IL - דיסני+ סרטים 154 IL - FREE TV - סרטים 128 IN - BOLLYWOOD'S 203 IN - CAM & NEW RELEASE 23 IN - EN HINDI 220 IN - GUJARATI NATAK 33 IN - HINDI 2528 IN - KANNADA 401 IN - KIDS 535 IN - MALAYALAM 401 IN - MARATHI 42 IN - NEW RELEASE 156 IN - PUNJABI 342 IN - TAMIL 466 IN - TELUGU 269 IR - PERSIAN کلاسیک دوبله 421 IR - PERSIAN کارتون 404 IR - PERSIAN MOVIES 790 IR - PERSIAN SUB/DUB 4430 IR - PERSIAN قدیمی 495 IT - 2019 & VECCHIO 12 IT - 4K MOVIES 25 IT - AVVENTURA AZIONE 122 IT - CACCIA 21 IT - CARTONI ANIMATI 58 IT - CLASSICO 473 IT - COMEDIA 126 IT - DRAMA ROMANTICO 164 IT - FANTASTICO FANTASCIENZA 74 IT - HORROR THRILLER 100 IT - NUOVA VERSIONE 2125 JP - JAPANESE FILM 69 JP - NETFLIX 26 KU - BADINI 437 KU - CARTOON BADINI 74 KU - CARTOON SORANI 89 KU - KURDISH MOVIES SUB 45 KU - SORANI 476 LA - NIÑOS 167 LA - PELÍCULAS 295 MARVEL MOVIES (MULTI) 12 MARVEL MOVIES 3840P (MULTI) 12 MT - MOVIES 105 NETFLIX ANIMI 16 NETFLIX ASIA 213 NETFLIX DOCU-MOVIES 41 NETFLIX HEVC 88 NETFLIX KIDS 245 NETFLIX KIDS 4K 3840P 6 NETFLIX MOVIES 3362 NETFLIX MOVIES 4K 3840P 113 NL - 2022 & OUD 2131 NL - 4K KINDEREN 2 NL - BIOSCOOP 659 NL - BIOSCOOP 4K 3840P 24 NL - KERST FILMS 76 NL - KINDEREN 326 NL - NPO+ 1 NL - VIDEOLAND 1196 NL - VIDEOLAND KIDS 38 NORDIC BARN 4K 3840P 25 NORDIC BECK COMPLETE 51 NORDIC FILM 4K 3840P 259 NORDIC FILM 2022 & OLD 2538 NORDIC FILM NEW RELEASE 791 NORDIC KIDS 300 NORDIC MUSIC 9 NORGE BARN 7 NORGE FILM 103 OSN+ MOVIES 4K 3840P 32 PARAMOUNT PICTURES 201 PH - PHILIPPINES FILM 131 PK - NAATS NASHEED 99 PK - KIDS 4 PK - NAATS 135 PK - PAKISTANI MOVIES 298 PL - ŚWIĄTECZNIE 42 PL - DZIECI 86 PL - FILMY 4K 334 PL - KIDS 4K 25 PL - KINO 1650 PT/BR - AMAZON PRIME 6 PT/BR - ANIMAÇÃO 123 PT/BR - APPLE TV+ 38 PT/BR - DOCUMENTACAO 18 PT/BR - FILMES 1960-2023 3318 PT/BR - FILMES 2024-2025 103 PT/BR - NETFLIX 181 PT/BR - TERROR 182 QC - ANIMATION 12 QC - DOCUMENTAIRE 59 QC - FILMS NOUVELLE VERSION 137 QC - FILMS VIEILLE 190 QC - NETFLIX 16 QC - NOËL 60 QC - SPECTACLES 56 RO - MOVIES 935 RU - KIDS 948 RU - MOVIES 905 RU - NEW RELEASE 252 RU - RUSSIAN 2021&OLD 581 SO - SOMALIA MOVIES 87 SOCCER AFL 11 SOCCER AMERICAN FOOTBALL 305 SOCCER BASEBALL 256 SOCCER BASKETBALL 578 SOCCER FOOTBALL 1246 SOCCER FORMULA 1 24 SOCCER HOCKEY 281 SOCCER RUGBY 501 SOCCER UFC 43 SUOMEN ELOKUVAT 7 SVENSKA 2020 & GAMMAL 3306 SVENSKA AUDIOBOOKS 17 SVENSKA BARN 377 SVENSKA FILM 244 SVENSKA NYA UTGÅVAN 632 TOP KIDS BLURAY (MULTI-SUBS) 97 TOP MOVIES BLURAY (MULTI-SUBS) 1395 TR - ALT YAZI 74 TR - COCUK FILM 445 TR - IMD FILMER 58 TR - SINEMA 1793 TR - YESIL CAM SINEMA 495 UFC ARABIA 4 UNIVERSAL 258 VIAPLAY ÍSLANDS KRAKKAR 24 VIAPLAY ÍSLANDS KVIKMYNDIR 236 VIAPLAY KIDS 43 VIAPLAY MOVIES 121 رياضه متنوعه 168 أفلام جزائرية 31 أفلام رعب 790 أفلام آسيوية 2022 264 أفلام أجنبية 2018 70 أفلام أجنبية 2019 191 أفلام أجنبية 2020 629 أفلام أجنبية 2021 767 أفلام أجنبية 2022 866 أفلام أجنبية 2023 704 أفلام أجنبية 2024 545 أفلام أجنبية 2025 51 أفلام أجنبية قديمه 3752 أفلام أجنبيه فائقة الوضوح 678 أفلام أجنبيه تصوير سينمائي 12 أفلام أطفال فائقة الوضوح 63 أفلام أسيوية 2023 156 أفلام أسيوية 2024 154 أفلام أسيوية 2025 13 أفلام أسيوية قديمه 57 أفلام ألمانيه 2023 54 أفلام ألمانيه 2024 82 أفلام ألمانيه 2025 6 أفلام ألمانيه قديمه 131 أفلام شاهد الأصلية 129 أفلام شامية 29 أفلام خليجية 49 أفلام هندية 2023 203 أفلام هندية 2024 199 أفلام هندية 2025 8 أفلام هندية قديمه 735 أفلام هندية مدبلجة 68 أفلام كريم عبد العزيز 16 أفلام كوميديه 8 أفلام ليبيا 22 أفلام محمد هنيدي 20 أفلام مغربية 181 أفلام مدبلجة للعربية 78 أفلام مصرية 75 أفلام اطفال مدبلجة 86 أفلام اطفال مترجمة 679 أفلام احمد حلمي 26 أفلام احمد السقا 19 أفلام احمد عز 23 أفلام اسلامية 9 أفلام الكريسماس 95 أفلام انمي 91 أفلام تركية 230 أفلام تونسيه 80 أفلام نجوم العرب 21 أفلام عربية حديثه 67 أفلام عربية فائقة الوضوح 44 أفلام عربية قديمه 990 أفلام عربية كلاسيك 138 أفلام عربية تصوير سينمائي 31 مسرحيات خليجية 79 مسرحيات مغربية 21 مسرحيات مصرية 59 مسرحيات عربيه 64 افلام وثائقية 214 افلام هاني رمزي 13 افلام دريد لحام 30 افلام مسيحية 113 افلام عادل امام 100 الجزيرة الوثائقية 84 Grand Total 126745 The new version has genre grouping if you enter a provider API key. I have to test that yet It also sorts much better and accurately. I am very close to posting it. I am hoping it'll be done by Sunday evening. So from your list it looks like the saved m3u is not respectful of utf or ansi, I will check that, thanks. 1
BigIrn 10 Posted March 15, 2025 Posted March 15, 2025 1 hour ago, mickle026 said: The new version has genre grouping if you enter a provider API key. I have to test that yet It also sorts much better and accurately. I am very close to posting it. I am hoping it'll be done by Sunday evening. So from your list it looks like the saved m3u is not respectful of utf or ansi, I will check that, thanks. Who's API key would I need? The guy I got strong from?
mickle026 652 Posted March 15, 2025 Author Posted March 15, 2025 2 hours ago, BigIrn said: Who's API key would I need? The guy I got strong from? No, it has fields for tmdb, omdb and tvdb API keys, it pulls into from them. You can get your own API key on these sites for personal use. Once I finish the next bit I have to do I might post it, so you guys can test it out. I wanted to test it a bit more first, but i don't mind posting it. I tested it creating the vod folders and cleaning up I tested the tmdb IDs being pulled from tmdb and added to the movie names. I haven't tested the genres yet, it pulls them, but I haven't tested if the genre folder creates yet. The code is there to do it, but it hasn't been checked. I tested the split m3u creation. I tested many different options work as the should, on/off for selecting outputs I have converted (well rewritten actually) most of the code to use all cpu cores instead of single threaded, speed has vastly increased. Because it is basically rewritten, almost completely, it's not even the same plugin anymore, it looks very similar and does the same thing but a lot better I think. It shouldn't be long now, I'm have a day off from work Sunday so I am hoping to finish it then if I don't have time Saturday. 1
BigIrn 10 Posted March 15, 2025 Posted March 15, 2025 5 hours ago, mickle026 said: No, it has fields for tmdb, omdb and tvdb API keys, it pulls into from them. You can get your own API key on these sites for personal use. Once I finish the next bit I have to do I might post it, so you guys can test it out. I wanted to test it a bit more first, but i don't mind posting it. I tested it creating the vod folders and cleaning up I tested the tmdb IDs being pulled from tmdb and added to the movie names. I haven't tested the genres yet, it pulls them, but I haven't tested if the genre folder creates yet. The code is there to do it, but it hasn't been checked. I tested the split m3u creation. I tested many different options work as the should, on/off for selecting outputs I have converted (well rewritten actually) most of the code to use all cpu cores instead of single threaded, speed has vastly increased. Because it is basically rewritten, almost completely, it's not even the same plugin anymore, it looks very similar and does the same thing but a lot better I think. It shouldn't be long now, I'm have a day off from work Sunday so I am hoping to finish it then if I don't have time Saturday. I'll be happy to be your QA analyst if you need to organize tickets and nice to haves out on Git. I can run a windows VM and trash it alongside my dev mac to test things out. I'm trying to get better about using Docker so bare with me. If I get bored I might even try running ubuntu or something. I'm in US EST but retired and like to tinker at all hours. I started importing the data from the m3u in python to create a report comparing what movies converted successfully, the ones that didn't and the ones that are going to TV Shows folder. I got bored and switched to Excel but now I'm creating a SAS dataset I can put into a database. I want to compare the original m3u to the output and create a foreign key to tie the datasets together so I can slice and dice and see where there are issues. Like for example below. I only ran the curated movie m3u and not the TV one and deleted any possible tv shows or live tv. It still put movies under TV: I need to test your latest version and report back how long it takes me. I'm still working on filtering what I want and how to ignore what I don't. Some streams that are filetype mp4 are not playing on emby or other players so it might be a host issue. Haven't had any issues with mkv. Sorry to bombard you so much but something that occurred to me, do people use the Live TV feature? I haven't tried it out yet so what would be the upside to using it instead of the Live TV section already on the dashboard. I'll give it a go with some coffee later. Thanks again @mickle026!!! I'll be the first to toast one for you on St Paddys. Don't feel rushed, this is by far miles ahead than when I first downloaded it. I can make it work completely fine as is, just the folder navigation is cumbersome.
gillmacca01 220 Posted March 15, 2025 Posted March 15, 2025 (edited) @BigIrn How do you add your VODs to Emby. Do you create a new library(s), or import it into your current Movie/TV Shows libraries? I would like to import into my current libraries, so I can still use continue watching, but if I did that I would have duplicates Edited March 15, 2025 by gillmacca01
gillmacca01 220 Posted March 15, 2025 Posted March 15, 2025 @mickle026when the new version gets released, will we have to setup from scratch, or will it still use the current configuration file?
BigIrn 10 Posted March 15, 2025 Posted March 15, 2025 1 hour ago, gillmacca01 said: @BigIrn How do you add your VODs to Emby. Do you create a new library(s), or import it into your current Movie/TV Shows libraries? I would like to import into my current libraries, so I can still use continue watching, but if I did that I would have duplicates That would be a fantastic idea! I hope that is the goal, eventually merge VOD streams with Live, Movie, TV. I will set up a VM later today and test that theory. I'll take a few movies that I know are already duped in just the VOD section and see how it reacts to the same movie in the "official movie" section. Disclaimer, unless you back up your media religiously, do not try this at home lol I'm still playing with the inclusion words. I should be able to just include or just exclude. @gillmacca01Once I get this in a cleaner automated manner, I'll share with you my google sheet/Excel pivot table and report where you can plug in your media directory and compare it to the m3u output so you know you're capturing everything you want or where it's going. The log is great for basic troubleshooting but the verbose is overkill. There should be a happy medium with folders, hierarchy and count of media so you can do a quick sniff test. 1
BigIrn 10 Posted March 15, 2025 Posted March 15, 2025 On 3/13/2025 at 11:42 AM, mickle026 said: Maybe you ran into one of the quirks mentioned above when it just exits for no reason This no longer happens on the version I am testing right now. Right on yeah I mentioned file locking really early on in this thread. I’m glad you got it working. I was afraid to open the log or make folder/file changes while it was running.
