gillmacca01 220 Posted March 21, 2025 Posted March 21, 2025 This is just 2 examples, but there are many more - I'm wondering if I have configured them wrong
gillmacca01 220 Posted March 21, 2025 Posted March 21, 2025 (edited) Also while I am causing you a headache, is there a way to ignore items that are not in a group. Latest m3u has a lot of content that are not in groups and I am not interested in them. example: group-title="",EN - Two Word Blending Letter O Learn to Read, Beginning Reader, Pre-Reader Phonics Lesson Edited March 21, 2025 by gillmacca01
BigIrn 10 Posted March 21, 2025 Posted March 21, 2025 Ok I created a new folder on my C drive "Streaming" instead of "VOD". If this doesn't work maybe I need to move the download folder into a user folder (r/w issues?) I have 13gb free space on win11. Is that an issue?
BigIrn 10 Posted March 21, 2025 Posted March 21, 2025 (edited) EDIT: I can't spell disregard. I had the m3u in the wrong folder. Edited March 21, 2025 by BigIrn spelling
BigIrn 10 Posted March 21, 2025 Posted March 21, 2025 (edited) 1 hour ago, mickle026 said: I still have no idea why your system is crashing. You have a heck of a lot of sql errors 2025-03-20 18:01:34.915 Info App: Sqlite: 787 - abort at 26 in [insert into AncestorIds2 (ItemId, AncestorId, Distance) values (1205,1205,0)]: FOREIGN KEY constraint failed Do you have your VOD folder monitored by emby ? If you do can you check, outputting to one that is not, and see if you get the issue? - I am starting to wonder if something in the output is not interpreted properly by Emby and causing this. Thanks @mickle026for splitting up the logs. It's running now and here is the log fron the start Edited March 21, 2025 by BigIrn
mickle026 653 Posted March 21, 2025 Author Posted March 21, 2025 (edited) 1 hour ago, gillmacca01 said: This is just 2 examples, but there are many more - I'm wondering if I have configured them wrong I will look at why the "contains" are not being honoured, I doubt i will get time today, and I am working a double back-to-back shift so it might be as late as Monday before I get to this.. I can add an option to ignore items not in groups if you wish. Some m3u suppliers don't use grouping at all, so an option here like a checkbox would be best Example: #EXTINF:-1,IN-MM - King of Kotha (2023) There is nothing but the channel/movie name Edited March 21, 2025 by mickle026 1
gillmacca01 220 Posted March 21, 2025 Posted March 21, 2025 No problem. I am working away again next week, so wouldn't be able to test till Friday, unless you release a version of the plugin that can be updated from within Emby
BigIrn 10 Posted March 21, 2025 Posted March 21, 2025 Still the same. 1916 Movies 3255 Movies 21.Mar.2025 - 10:59:42 Build Version: 1.0.0.120 21.Mar.2025 - 10:59:42 Avaliable Memory: 4.00 GB 21.Mar.2025 - 10:59:44 CPU Cores: 2: Logical Processors (Max Threads): 4, Hyperthreading: True 21.Mar.2025 - 10:59:44 Using max 4 threads 21.Mar.2025 - 10:59:44 Ignore [Contains]: 21.Mar.2025 - 10:59:44 Ignore [StartsWith]: 4K,AF -,AF|,AJ -,AL -,AR -,AR-ANM -,AR-KID -,AR-,BE -,BE|,BG -,BR -,CN -,DE (BLURAY),DE -,DE|,DK -,DK|,ES -,ES|,ÈS - ,ES .,ES- ,EX -,EX - ,EX -,EXYU ,FI -,FR -,FR - ,FR-,FR|,GR -,GR|,IL -,IL|,IN -,IN-,IN|,IR -,IR-,IS -,IT -,IT|,JP -,JP|,KR -,KR|,KU -,KU|,LA -,LAT -,LAT-,LATT -,LAT.. -,LATINO,MT -,MT|MT,NF -,NF - ,NF-,NF - ,NL 24,NL FILMS,NL F,NL HBO,NL M,NL NETFLIX,NL R,N -,NL -,NL ,NL|,NO -,NO|,PK -,PL -,PT -,PT ;,PT|,QC -,QFR -,RO -,RU -,RU|,RX ,SC -,SC|,SE -,SE|,SH -,TOP -,TOD -,TR -,TR|,VIU -,WIT-,XU -,XU|,###,(DE),(FR),(GR),(IR),(KR),(RU),(TR),FOR ADULTS,XXX,XXL 21.Mar.2025 - 10:59:44 Include [Contains]: 21.Mar.2025 - 10:59:44 Include [StartsWith]: EN ,EN -,EN|,US ,US| 21.Mar.2025 - 10:59:44 Task Started at: 3/21/2025 10:59:44 AM 21.Mar.2025 - 10:59:44 ----------------------------------------------------------------------- 21.Mar.2025 - 10:59:44 Create Movie Stream Files From M3U Scheduled Task Triggered. 21.Mar.2025 - 10:59:44 ----------------------------------------------------------------------- 21.Mar.2025 - 10:59:44 Input File 1: C:\Streaming\M3U\tv_channels_b3e6755ebfe2.m3u 21.Mar.2025 - 10:59:44 Loading M3U file. 21.Mar.2025 - 10:59:44 Reading local file: C:\Streaming\M3U\tv_channels_b3e6755ebfe2.m3u 21.Mar.2025 - 10:59:44 Loading m3u File Total execution time: 0 ms 21.Mar.2025 - 10:59:45 No Input File 2 21.Mar.2025 - 10:59:45 No Input File 3 21.Mar.2025 - 10:59:45 Total Input Files: 1 21.Mar.2025 - 10:59:45 Total m3u Items: 1112414 ScheduledTask-[M3UToStrm]21.Mar.2025 - 10.59.42.txt FileWriteDebugLogging [M3UToStrm]21.Mar.2025.txt
gillmacca01 220 Posted March 21, 2025 Posted March 21, 2025 No rush for this at the moment, but I am still seeing some movies identified as tv shows and I can see a pattern - I'm sure you'll see it in the 2 screenshot (i currently have 6 mis-identified)
mickle026 653 Posted March 21, 2025 Author Posted March 21, 2025 10 minutes ago, gillmacca01 said: No rush for this at the moment, but I am still seeing some movies identified as tv shows and I can see a pattern - I'm sure you'll see it in the 2 screenshot (i currently have 6 mis-identified) Yes it's a date pattern picked up as season/ episode. I can fix this.
BigIrn 10 Posted March 21, 2025 Posted March 21, 2025 (edited) 6 hours ago, mickle026 said: I still have no idea why your system is crashing. You have a heck of a lot of sql errors 2025-03-20 18:01:34.915 Info App: Sqlite: 787 - abort at 26 in [insert into AncestorIds2 (ItemId, AncestorId, Distance) values (1205,1205,0)]: FOREIGN KEY constraint failed Do you have your VOD folder monitored by emby ? If you do can you check, outputting to one that is not, and see if you get the issue? - I am starting to wonder if something in the output is not interpreted properly by Emby and causing this. words are hard Edited March 21, 2025 by BigIrn
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 Quick question. In the override fields, do I need to enter the group name from the downloaded m3u or the name of the folder created by the plugin?
mickle026 653 Posted March 22, 2025 Author Posted March 22, 2025 13 minutes ago, gillmacca01 said: Quick question. In the override fields, do I need to enter the group name from the downloaded m3u or the name of the folder created by the plugin? from the m3u, the folders are renamed after the m3u is parsed. Ignore happens during the parsing of the m3u. 1
mickle026 653 Posted March 22, 2025 Author Posted March 22, 2025 (edited) @gillmacca01I ran through your newest m3u with the |EN| TURKISH SERIES in it using the ignore words contains "TURKISH" and it WAS ignored, I'm off back to work on the second part of my double shift in a minute so I will run it with "TURKISH SERIES" and check back later just to see if there may be a problem with words containing spaces , there shouldn't be but I will check.. Second **FILTER** entry. 1st was kept because it had EN 2nd was ignored (removed) because it had TURKISH as per your other question, from below you can see group title retains the |EN| and channelname/Moviename has the | removed before the ignore phase (this needs clarification in the plugin page) The log entries are out of order too, the Checking {Ignore] contains is requested to written to the log before **FILTER** Ignoring ... 21.Mar.2025 - 17:34:09 tvgName: EN - Uzak Sehir - Far Away (2024) S01 E01 21.Mar.2025 - 17:34:09 groupTitle: |EN| TURKISH SERIES SUB 21.Mar.2025 - 17:34:09 channelName: EN - Uzak Sehir - Far Away (2024) S01 E01 21.Mar.2025 - 17:34:09 logoUrl: https://image.tmdb.org/t/p/w185/bEjz0Qyyc07ydF7nWdJMX98R8Ev.jpg 21.Mar.2025 - 17:34:09 Checking [Include] Contains 21.Mar.2025 - 17:34:09 Checking [Include] StartsWith 21.Mar.2025 - 17:34:09 **FILTER** Keeping [channelName] [161770]: EN - Uzak Sehir - Far Away (2024) S01 E01 :Filtered by: 'EN ' 21.Mar.2025 - 17:34:09 Checking [Include] StartsWith, Include: True 21.Mar.2025 - 17:34:09 **FILTER** Ignoring [groupTitle] [161770]: |EN| TURKISH SERIES SUB :Filtered by: 'TURKISH' 21.Mar.2025 - 17:34:09 Checking [Ignore] Contains 21.Mar.2025 - 17:34:09 tvgName: EN - Uzak Sehir - Far Away (2024) S01 E02 21.Mar.2025 - 17:34:09 groupTitle: |EN| TURKISH SERIES SUB 21.Mar.2025 - 17:34:09 channelName: EN - Uzak Sehir - Far Away (2024) S01 E02 21.Mar.2025 - 17:34:09 logoUrl: https://image.tmdb.org/t/p/w185/bVjQa9ZJPwXVwzyXKJ2upKUYRRP.jpg Edited March 22, 2025 by mickle026
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 I used ignore Turkish series because I didn't want the possibility that there is a movie that contains Turkish
mickle026 653 Posted March 22, 2025 Author Posted March 22, 2025 32 minutes ago, gillmacca01 said: I used ignore Turkish series because I didn't want the possibility that there is a movie that contains Turkish It is ignored here, and not in the VOD folder either .... 22.Mar.2025 - 11:56:03 tvgName: EN - Uzak Sehir - Far Away (2024) S01 E01 22.Mar.2025 - 11:56:03 groupTitle: |EN| TURKISH SERIES SUB 22.Mar.2025 - 11:56:03 channelName: EN - Uzak Sehir - Far Away (2024) S01 E01 22.Mar.2025 - 11:56:03 logoUrl: https://image.tmdb.org/t/p/w185/bEjz0Qyyc07ydF7nWdJMX98R8Ev.jpg 22.Mar.2025 - 11:56:03 Checking [Include] Contains 22.Mar.2025 - 11:56:03 Checking [Include] StartsWith 22.Mar.2025 - 11:56:03 **FILTER** Keeping [channelName] [161797]: EN - Uzak Sehir - Far Away (2024) S01 E01 :Filtered by: 'EN ' 22.Mar.2025 - 11:56:03 Checking [Include] StartsWith, Include: True 22.Mar.2025 - 11:56:03 **FILTER** Ignoring [groupTitle] [161797]: |EN| TURKISH SERIES SUB :Filtered by: 'TURKISH SERIES'
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 So the question is, why it's not ignoring for me?
mickle026 653 Posted March 22, 2025 Author Posted March 22, 2025 53 minutes ago, gillmacca01 said: So the question is, why it's not ignoring for me? The only difference I can see at the moment is you haven't removed language codes in the output, but that should not matter as that is done later. That should not be the reason. I can't check right now, just arrived back at work
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 6 minutes ago, mickle026 said: The only difference I can see at the moment is you haven't removed language codes in the output, but that should not matter as that is done later. That should not be the reason. I can't check right now, just arrived back at work No problem. I'm now running it with verbose logging on my laptop to see what happens. I have deleted the previous m3u's and vod files, so it will be a fresh download
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 I believe I have fixed it, but not sure why it's fixed. I've just re-run it (after trying several times with the files not be ignored), and the only difference is, I have ticked 'Clean Up/remove and residual empty output folders ' option. The folders had strm's in them, but this time they have been removed - maybe I misunderstood what the option is suppose to do
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 (edited) AAARRRGGHHH. Solve one problem, and another one appears (although it may have already been there, but I was looking at others stuff) I have a folder created called 'EN CHILDRENFAMILY'. m3u calls the folder |EN| CHILDREN/FAMILY Entered in the override field, but still be detected as tv shows Edited March 22, 2025 by gillmacca01
mickle026 653 Posted March 22, 2025 Author Posted March 22, 2025 Ok the / will be removed because the filesystem can't use it as part of the folder name. What is the extinf line and does the URL contain "/movie/" ? If it does have you URL detect on?
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 2 minutes ago, mickle026 said: Ok the / will be removed because the filesystem can't use it as part of the folder name. What is the extinf line and does the URL contain "/movie/" ? If it does have you URL detect on? #EXTINF:-1 tvg-id="" tvg-name="EN - Book Of Dragons (2011) How To Train Your Dragon" tvg-logo="https://www.themoviedb.org/t/p/original/xgfaG98tsVYodytUkdRA1c4ajtA.jpg" group-title="|EN| CHILDREN/FAMILY",EN - Book Of Dragons (2011) How To Train Your Dragon http://hidden/movie/hidden/hidden.mp4 URL detect on - did you mean this
mickle026 653 Posted March 22, 2025 Author Posted March 22, 2025 (edited) Yes, if that is on and it detects /movie/ in the URL it will assign it as a move and won't rely on other checks. Is this failing with this movie? Edited March 22, 2025 by mickle026
gillmacca01 220 Posted March 22, 2025 Posted March 22, 2025 The top level folder is being put under tv shows, but contains 50 movies - i have only added movies to Emby at the moment, so I can easily see which ones are misidentified. Haven't checked every single one, but they are all under EN children/family
